40. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dec9 Jul 13, 2010 6:16 AM (in response to cs0122)But, your using a laptop. What size is your laptop screen? Turn on Clear Type on Windows 7 and go through the calibration process that will sharpen and clear up words.
41. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
cs0122 Jul 13, 2010 6:56 AM (in response to dec9)Laptop, desktop... a monitor is a monitor. Trust me... ADOBE went through all of the things already. Photographers (good ones) only use high res screens. NO FIX. Tried it all UI, resolution, Clear Type blah blah blah There is NO FIX to this problem unless you decide to lower your resolution. This laptop I have ... no way am I stepping back down to a lower res. This problem has nothing to do with clarity but Adobe's software not being in sync with Windows PC systems.
42. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dec9 Jul 13, 2010 7:13 AM (in response to cs0122)All monitors are different. The UI looks a whole lot bigger on my 25 inch computer monitor then it does on my 17.1 inch laptop monitor. Computer monitor is 1920 x 1200 and the laptop is 1920 x 1080. The 17.1 laptop monitor is more compact to squeeze in the 1920 x 1080 thus making everything smaller.
Now, don't get me wrong, I do understand what you are writing about and your concern about scaling. However, if you want a high resolution screen like my laptop screen it is common sense that things will be smaller unless the resolution is adjusted down. For me, PS on the laptop, is not a problem as I know pretty much where everything is at and what it reads.
Yes the UI is smaller but that is expected and just the way it is until Adobe can work in a UI adjustment for laptops.
43. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
cs0122 Jul 13, 2010 7:20 AM (in response to dec9)I'm using a 17" monitor at 1920 x 1200 resolution. Yes, we agree that it's something that Adobe has to fix. I can see the menues, etc., but only when my face is inches from my laptop. It's like working blind. Horrible. My neck has been sore since I got CS4 when I first noticed the problem. My old laptop had low resolution so I used CS3 fine, but as a photographer I had to upgrade to a better resolution screen. UI is at large, but doesn't matter. As a photographer I can't set my resolution lower than 1920 x 1200. If you have any suggestions please let me know. I hate to give up Photoshop but at this point I feel like I have no choice. Thx.
44. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dec9 Jul 13, 2010 7:33 AM (in response to cs0122)I will play around with the laptop and maybe I can come up with something. I also tried the UI set a Large but it did not make a difference. There is a setting in windows where the display can be changed from the default 100 percent to 125 percent. However, making it 125 percent also introduces the 3 headed mouse problem in Photoshop so that won't help matters.
There is also a custom DPI setting in Windows 7 that can adjust UI pixels per inch. Not sure if that will work with the Adobe PS UI. I need to get on my laptop and check it out.
45. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dec9 Jul 13, 2010 9:38 AM (in response to cs0122)I played with that adjustment. Turns out the option is the same thing as changing the DPI just a different name. So nothing has changed and had zero effect on the Adobe PS UI.
46. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
TLL... Jul 13, 2010 10:02 AM (in response to Honeydew56)Perhaps this is yet another reason to stay with CS3? I use a 21 / 26" duel monitor @work and a dual 21" setup @home and the UI is great. So what this post is all about is the Adobe UI genui behind CS4/5 either were working @800x600 or are all 20/20 eagle eyes? Kinda sad to have all that VISUAL power in front of you and be hampered because you CAN'T SEE the interface. How ironic...
47. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
rob_adams Sep 6, 2010 6:28 AM (in response to cs0122)Just changed from a 24" 1920x1200 to a dell 30" 2560x1600 - same issue here.
Menu fonts and buttons are tiny. Razor sharp, but tiny. Tried the UI settings, tried windows ppi adjustments (worked everywhere, but PS btw).
IF I set my 30" monitor to 1920x1200 they are readable, but hey, why am I wasting the screen real estate.
Come on Adobe - fix this!
Windows 7 64 bit, Photoshop cs5 (64 bit) Dell 30" running @ 2560x1600
Rob
49. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
cs0122 Sep 6, 2010 6:59 AM (in response to rob_adams)Hi,
I had CS4 and had this same problem. I fought and fought and fought with Adobe about this exact same thing. I told them I wanted my money back. So they gave me CS5 for free and told me that it was 'probably fixed'. Same problem in CS5. Again I spoke to another person who said I have to turn my resolution on my screen down. I told them what was the point in me getting a monitor with a resolution of 1920 x 1200 if I couldn't use it. Of course none of the people I spoke with could answer that. They know about this problem and have not fixed it. I finally gave up...they wouldn't give me my money back. I will when I get a minute go to my local news channel and complain to see if they can put it on their show. The usually get things fixed once it's been aired on the news. I'm wondering if this is a PC thing or is it happening to Macs too. I'm having a feeling this is not happening to the macs which have the 1920x1200 resolution. I hope everyone complains, complains, complains about this problem so that they do something about it and we can use the software. I hate it.
Again, the only way to resolve this problem is to turn your monitor way down in the resolution.
Cathy
50. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
thesimcat Sep 14, 2010 10:17 AM (in response to Noel Carboni)I'm surprised that you are surprised that this could be illegal. It makes perfect sense to me that it could.
Requiring large type is a disability I would think.
A book and software aren't even a little similar, software is alive. When I buy a book I know to buy large print, when I buy software I assume I will be able to adjust the text size somehow, someway, preferably simply.
So, I have just installed my lovely new CS5 on my lovely new windows 7 computer and sure enough, most of CS5 is not legible to me. When I change the entire computers font view everything becomes grossly huge. This is all completely unfair, ridiculous and should be illegal.
Ageism at it's best.
s
51. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
susiem@vom.com Sep 29, 2010 4:49 PM (in response to cs0122)I also have the same "too small toolbar and interface on Adobe Photoshop Elements 7 and 9." Tried all suggestions above. None worked. Support was no help. It is very frustrating. I can hardly stand to use the program.
52. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
retrophilell Sep 8, 2011 9:34 AM (in response to Honeydew56)Add me to the ever-growing list of users who find this UNACCEPTABLE. Whoever reported this probalem as "possibly solved" isn't dealing with the problem. Attached is a screenshot of the menu size, compared to 12-point text shown at 100%. See menu font size at very top of image, and welcome screen text at lower right. Adjusting the Windows text display settings does NOTHING to CS5 menus. Changing the screen resolution is NOT a fix. Adobe is ignoring this issue!
53. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Noel Carboni Sep 8, 2011 10:06 AM (in response to retrophilell)Out of curiosity, what's the PPI on your monitor?
-Noel
54. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:31 AM (in response to Honeydew56)I have tried EVERYTHING EXCEPT changing my screen resolution, and NOTHING WORKS to fix this.
Changing screen resolution is UNACCEPTABLE. I bought a high def monitor so that I would have excellent visibility and increased resolution. I am partially sighted and was ASSURED severl times over the phone by the sales person that CS5 addressed this problem. I am the president of our local camera club and I CANNOT USE PS CS5!. And many other members of our group have had problems with it also.
It is unacceptable that the software that is supposed to be the industry standard is way behind the times when addressing usability issues as well as ADA standards.
I have called to discuss this matter with Adobe on more than one occasion and was told that I should have checked the website before buying and that the sales staff was not necessarily well-informed about the resolution issue. I specifically called to order over the phone so that I could express my concern about this issue in past versions and get assurance from a live lperson that it was no longer an issue in CS5. If I have to dig and get all my info myself from the web, why have a live sales staff at all, and if you do, why do they not have the honest information?
To be fair, I purchased the CS5 suite, and it's interesting that some of the sofware is accessible and some is not. Dreamweaver is not as bad as Photoshop but Bridge is just as bad. So the foundation for the capability to fix this problem is there, just not implemented properly across the board.
I have been using Corel PaintShop Pro Photo for many years, and that software has ALWAYS allowed me to adjust the size of the menus and dialog boxes. There are many times when I wish I could use PS Cs5 but in all honesty, I can do just about enything that software does using PaintShop Pro, and it's MUCH LESS EXPENSIVE.
Sandy Jo Becker Hyman
[signature deleted by host]
55. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:32 AM (in response to Noel Carboni)Resolution is 1680 x 1050, and that's a step down from the recommended
native res of 1920x1200.
56. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Noel Carboni Sep 8, 2011 12:01 PM (in response to sjhpubs)That didn't answer my question, as you have not said what your monitor size is, physically.
But it did highlight one possible issue: You're using a desktop setting other than the native size of your LCD display... Do you realize that will cause resampling in the monitor and make everything look quite a bit fuzzier? It may actually be that the sharper display at the smaller size will be more contrasty and end up easier for you to see...
-Noel
57. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:32 AM (in response to Noel Carboni)Actually, I have a 24" wide screen monitor.
And, I decreased the resolution to see if it would make a difference with PS
CS5. It did not make any usable difference. So I will reset it back to the
native resolution. Adobe tech support actually urged me to decrease the
resolution in order to be able to use PS! But, as you said, that defeats
the purpose of having this monitor.
All other programs allow me to reset the font size or they default to my
windows settings which I have customized to be able to see things. But
Adobe is just about the ONLY vendor that does not comply with this.
58. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Noel Carboni Sep 8, 2011 2:05 PM (in response to sjhpubs)Yes, it's well known that parts of the Adobe UI are fixed in size.
I have always thought it may be because they support both Mac and PC operation with the same code, and that may put some constraints on the flexibility of what either one can do. However, I'm sure Adobe listens to users, and if enough folks request better compliance to the accessibility settings perhaps they'll put some effort into making it easier to see.
There's another site that's better than this one for making suggestions:
http://feedback.photoshop.com/photoshop_family/
-Noel
59. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:33 AM (in response to Noel Carboni)Thank you. I will do post on the other site as well. However, I must say
that every software vendor deals with mac vs pc and Adobe is the only one
that is not only not compliant but also does not seem to be interested in
really listening to what users are saying--lots of us have been complaining
about this one issue for a very long time, both online and on the phone.
They seem not to care and that feels like arrogance to me.
60. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
I agree, it can seem like that.A possibility is that because of the Photoshop base design - remembering that some of the code goes back 20 years, it's more difficult to change than you might think. Even though the Mac was ahead of the PC in just about all things graphic way back then, people weren't really thinking about making user interfaces conform to accessibility settings. Just having graphically-rendered text on the screen was still somewhat new and exciting!
There are a number of things that I have always wondered why they have been left the way they are - besides the inflexible UI is the fact that not all the filters have been updated to work on the more common 16 bits/channel data nowadays. The reality probably boils down to Adobe simply trying to maximize profits and minimize expenses and risk - they just doesn't want to spend the money on development that it would take to revisit some of these things. Development managers thus have limited resources and simply can't devote everyone to revamping something they feel already works pretty well.
There are also those who would say changes to the UI - which seem likely if they were to revisit all the controls and dialogs to make them resizeable - would be ill-received by some users who are used to it being kept the way it is across many versions. In short, they may feel they can't please all the people all the time.
Last but not least, something to think about... I began to have some trouble seeing the screen some years ago, then by chance I asked my opthalmologist whether anyone ever asks for "computer glasses", optimized for the arms-length distance typical between user and display screen, which is typically longer than that for reading glasses. Once having had a pair of such glasses made, I have found doing computer work MUCH less stressful on the eyes.
-Noel
61. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:34 AM (in response to Noel Carboni)Noel,
Having been a system programmer and technical writer for decades, and
understanding the investment that has to be made to make things accessible,
I understand everything you are saying, but, I have been using PaintShop Pro
for decades--I don't know when PhotoShop first arrived on the scene but when
Jasc developed the original version of PSP, it was very different from what
it is today, and they just announced the latest version which is very
different in UI from the previous version. They actually revamped it to
look and feel more like PhotoShop. But it's still accessible--and they are
not the "industry standard" with the same budget that Adobe has. So I would
think that it's in Adobe's best interest to comply with standards that have
actually been around for a long time now. And, if they are reluctant to
change the UI for fear of upsetting some Mac users, they are truly missing
the boat. All those loyal older users are getting more visually impaired
over time and the younger ones are used to dealing with all kinds of
software that runs on both pc and mac platforms. If they want their type
size extra small they can set it to be that way.
As for glasses, I understand that too--and I am wearing such glasses, but I
was born with a visual limitation so there is a limit to how much my vision
can be improved with glasses.
I do appreciate your trying to help.
Thank you,
62. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Noel Carboni Sep 8, 2011 6:15 PM (in response to sjhpubs)No problem; I'm happy to have a good conversation on this subject. I'm right there with you in wishing Adobe would make their UI compliant with the modern accessibility features.
I hope you don't mind my taking it a bit further...
Jasc/Corel may have evolved their PaintShop Pro UI differently than Adobe, but then they haven't moved up to embrace 64 bit operation, they don't have a Mac version, they don't have a raw converter worth mentioning, and they don't have all the gee whiz new features of the late versions of Photoshop either. Sounds like Adobe was working on the meat of their application while the window dressing was being changed in PaintShop. Honestly, I don't really see a fair comparison there, and the market bears this out, with Photoshop bringing in something like 7 times more $$ for one license. Looking just at product success, I'd say Adobe could be argued to have been making the better business decisions and doing the more difficult engineering.
-Noel
63. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:35 AM (in response to Noel Carboni)Well, Noel, you might be right but take a look at the newly released PSP Pro
X4 Ultimate just announced. I just downloaded it and I think you would be
surprised at some of what is in it.
Having said that, there is no way for me to know what I am missing by not
using PhotoShop (much like I don't know what I cannot see), because I have
not been able to use it.
64. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Noel Carboni Sep 8, 2011 6:39 PM (in response to sjhpubs)sjhpubs wrote:
Well, Noel, you might be right but take a look at the newly released PSP Pro X4 Ultimate just announced. I just downloaded it and I think you would be surprised at some of what is in it.
I've been doing that all day, as it turns out, since I have plug-in installers to update.
-Noel
65. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 11:38 AM (in response to Noel Carboni)What do you think of it? I have not had a chance to really play with it
yet.
66. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
retrophilell Sep 9, 2011 8:42 AM (in response to Noel Carboni)Mine is 1900 x 1200 (native). It's a 64-bit, Windows7 system, and everything else on it looks beautiful. Super-sharp, great color. I also have really good computer glasses (for farther distance than reading glasses). I think when more people upgrade to newer, bigger, higher-resolution monitors this is going to be an ongoing problem for Adobe unless they can get their act together. My previous system was 32-bit, XP with a native res. of 1024 x 768. I had no problem with the Adobe UI at that point, but our IT dept. is upgrading our equipment, and this is what I have now. Just to reiterate ... all other user interfaces look fine and are sharp, clear, and readable. Adobe CS5 UI's are sharp and clear, just very tiny and therefore not particularly readable. If I can't read it, I can't use it.
68. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dhawn6 Sep 9, 2011 7:57 PM (in response to sjhpubs)I called adobe sales, to see if cs 5.5 had fixed the problem of not being able to adjust the size on my high res moniter. The sales person assured me it had been fixed. I purchashed 5.5. I still have not figured out if it is fixed, Still looks the same.
69. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Sounds like either extreme miscommunication or out and out fraud to me.
Virtually NOTHING about the UI has been changed between Photoshop CS5 and Photoshop CS5.1 (AKA 12.1, which comes as part of CS5.5).
How did you ask the question, specifically?
-Noel
70. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dhawn6 Sep 11, 2011 8:34 PM (in response to Noel Carboni)I got on the store chat line, I asked if the ui was fixed for larger viewing, and if it was I would be interested in the new version, he paused, checked and then said it had been taken care of in the 5.5 version. I ordered the new version and have not been able to find the fix. I use photoshop a lot, and by sitting close to the screen, and using computer glases and straining. I am able to read the menues, so I am able to use the program. (I also have excellent eye site) I could use it much better if it was like other window programs. For what photoshop costs, you think they would at least want their users to easily read the interface and keep up with new technology, especially after several complaints for over a year. It looks like I can only hope for a fix in the next version. I also could revert back to 5 year old monitors with less resolution, but I need the high res for some delicate art work.
71. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 12:18 PM (in response to dhawn6)Would you please post this in other places and also call adobe and register
your complaint? I think that if a critical mass of people do this, at some
point they will have to listen.
Is 5.5 so much better that you have to keep it? If not, consider calling
them and letting them know that you want a refund--you were misinformed, as
others have been in the past, and the company is practicing unfair sales
procedures. If people call and are specifically told that something has
been fixed and then find out differently, that seems like grounds for legal
action unless they either refund your money or fix the problem and stop
lying to customers over the phone.
72. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
retrophilell Sep 12, 2011 3:48 PM (in response to sjhpubs)The only response I got was from @Adobe_Care (Twitter), who said, "You are right. The UI menu font is not resizeable. Give our engineers a challenge by requesting this feature here." (with follow-up link to adobe.ly/o2SpzS). I'm tempted to write to the board of directors (in 3-pt type, of course) rather than wait for Adobe engineers to come to their senses. It may not seem like a big deal to a lot of people, but it was a lot of not-so-big issues that caused our switch from Quark to InDesign a few years back.
73. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
dhawn6 Sep 12, 2011 5:02 PM (in response to sjhpubs)Well I relayed the info to several sites and adobe. I buy the production suite and the way they have it set up, if you don't purchase the upgrades and skip one you srtill have to pay for it on your next upgrade. So figure I might as well upgrade (There might be something useful)
74. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 12:18 PM (in response to dhawn6)But that's the point--they really rely on people just blindly (pardon the
punn) going ahead and upgrading. And actually that upgrade policy may not
in fact be true. When I called for CS5, I had Dreamweaver 4x or something
like that and elements 5, and they said that was enough for me to receive
the cs5 upgrade--they wanted my business! I honestly think your idea of
writing to them in 4 pt type is an excellent one. Perhaps, copy all the
entries here and convert them to 4 pt type.
75. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Sep 16, 2011 12:19 PM (in response to retrophilell)I just entered a feature request to "challenge" the adobe engineers at
http://adobe.ly/o2SpzS. If everyone who is reading this does the same thing
perhaps we can begin to make some headway.
76. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
blackdaug49 Oct 15, 2011 7:31 AM (in response to Honeydew56)Just had to jump in on this discussion. I am running windows 7 ultimate on new Dell with a 50 INCH HD moniter, and I can not see the toolbars or pallette either in photoshop. I bought Dreamweaver a few years back and essentially gave up using it because of the same problem. This is not some isolated intance with the original poster.
The funny thing is, in the other programs in Creative Suite that I am having to use, like In Design, the pallet is perfectly large. It is Photo shop that is the problem. I have to use this suite to create a publication, because it is what the printer insists on, but I am actually beign forced to use programs like Paint and Image to edit the pictures before I can place them.
77. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Honeydew56 Oct 15, 2011 1:22 PM (in response to Honeydew56)Since I am the one that originally started this thread, I would like to "reply" to my original post. I did get my money back from Adobe CS5. But I have found something else out. I have Photoshop Elements on my my laptop (running on Win7) and that also had the tiny menus plus instead of one pointer, I now had THREE to deal with and very aggravating. I was searching for an answer online. I found something that might help those that are struggling with the microscopic text in CS5. I went to START, then I right clicked on my PSE program in the listing, and clicked on PROPERTIES, then on COMPATIBILITY, I selected to run in XP. My PS Elements menu text is now fine and easy to read. All is fixed except for the triple cursor issue. I'd like to hear if setting the compatibility makes a difference for all of you CS5 and CS4 users.
78. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
Chris Cox Oct 15, 2011 1:32 PM (in response to Honeydew56)The triple cursor is a symptom of a video card driver bug plus something in the OS UI scaling code (disabling the OS UI scaling fixes it, as does updating the video card driver).
79. Re: CS5 Very small toolbar- Tried Preferences, Interface, Large and it doesn't work.
sjhpubs Oct 15, 2011 2:08 PM (in response to Honeydew56)NOPE! No difference in PhotoShop UI.
![function(){return A.apply(null,[this].concat($A(arguments)))} cs5 tiny UI fontsJPG.jpg](https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-3112589-40553/450-423/cs5+tiny+UI+fontsJPG.jpg)
