Show 4 replies
1. Re: Rotating iphone 4 Video Questions...
JSS1138 Oct 15, 2011 9:03 PM (in response to Bruno2012)"iPhone" and "edit" in the same post.
UGH!!!!!
2. Re: Rotating iphone 4 Video Questions...
Colin Brougham Oct 16, 2011 6:25 AM (in response to Bruno2012)After you rotate the clip, use Scale (also found under Motion) to alter the size of the clip, and fit it into your sequence. You can either stretch it to fit, by disabling the Uniform Scale checkbox, or just decrease the clips size until you see its full height. You'll have a lot of black emptiness on top and bottom, in that case.
You can't rotate the "entire frame," since a sequence's dimensions are fixed. You have to edit in two different sequences if you really need that.
3. Re: Rotating iphone 4 Video Questions...
Bruno2012 Oct 17, 2011 1:00 PM (in response to JSS1138)Huge help, thanks.
4. Re: Rotating iphone 4 Video Questions...
Bruno2012 Oct 17, 2011 1:01 PM (in response to Colin Brougham)I don't have a problem creating two different sequences using the different
clips if I can combine them later on...
What is quick version of editing the second clip in another sequence to get
it "landscaped"?
