Problem with webservice AXIS
Avatar
Level 1
Hi ,
I have a webservice created with AXIS Java, and I try to get
the result .
The result of the webservice is a XML Document.
I have an Object wsQryProgress that is my webservice
wsQryProgress.doQueryWS is the only method in my webservice ,
and too I have a datagrid and binding with
dataProvider="{wsQryProgress.doQueryWS.lastResult}"
I don't know why the datagrid is empty
Here is my code I hope you can help me
quote:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="absolute" >
<mx:WebService id="wsQryProgress"
wsdl="
http://localhost/axis/services/QryProgress?wsdl"
useProxy="false" result="fin(event);"
fault="falla(event);">
<mx:operation name="doQueryWS">
<mx:request>
<in0>for each tblcredencial where chrusername =
'jlrueda@todito.com' no-lock</in0>
<in1>Credenciales</in1>
<in2>Credencial</in2>
<in3>idcredencial,chrusername</in3>
<in4>
http://www.toditocard.com/cgi-bin/tcardB/util/XML/wGenXml.p</in4>
</mx:request>
</mx:operation>
</mx:WebService>
<mx:Panel x="10" y="10" width="400" height="300"
layout="absolute" title="Usuarios tcard">
<mx:TextInput x="10" y="23" id="txtUser"/>
<mx:Button x="198" y="23" label="Enviar" id="btnSend"
click="SendUser();"/>
<mx:DataGrid x="10" y="70" id="dgUsuario"
dataProvider="{wsQryProgress.doQueryWS.lastResult}">
<mx:columns>
<mx:DataGridColumn headerText="idCredencial"
dataField="idcredencial"/>
<mx:DataGridColumn headerText="Username"
dataField="chrusername"/>
</mx:columns>
</mx:DataGrid>
<mx:Label x="10" y="229" text="&quot; &quot;"
id="lblqry"/>
</mx:Panel>
<mx:Script>
<![CDATA[
import mx.utils.ArrayUtil;
import mx.controls.Alert;
public var strQry:String;
public var strUrl:String = "
http://www.toditocard.com/cgi-bin/tcardB/util/XML/wGenXml.p";
public var strRoot:String = "Credenciales";
public var strRow:String = "Credencial";
public var strCampos:String = "chrusername,idcredencial";
[Bindable]
public var credenciales:Array;
public function EnviaQry(strUser:String):void
strQry = "for each tblcredencial where chrusername = '" +
strUser + "' no-lock:";
wsQryProgress.doQueryWS.send();
public function SendUser():void
EnviaQry(txtUser.text);
public function fin(e:Object):void{
Alert.show(e.result,"Result
XML",Alert.OK,this,null,null,Alert.OK);
public function falla(e:Event):void
txtUser.text=e.toString();
</mx:Script>
</mx:Application>
Avatar
Level 1
the result of the webservice is
<Credenciales>
<Credencial>
<idcredencial>934847</idcredencial>
<chrUsername>jlrueda@todito.com</chrUsername>
<Credencial>
</Credenciales>
Avatar
Former Community Member
Could there be something wrong here?
<mx:request>
<in4>
</mx:request>
Avatar
Level 1
like what??
I test the service with these params and I got this:
<soapenv:Envelope>
<soapenv:Body>
<doQueryWSResponse soapenv:encodingStyle="
http://schemas.xmlsoap.org/soap/encoding/">
<doQueryWSReturn href="#id0"/>
</doQueryWSResponse>
<multiRef id="id0" soapenc:root="0"
xsi:type="ns1:Document">
<Credenciales>
<Credencial>
<idCredencial>934847</idCredencial>
</Credencial>
</Credenciales>
</multiRef>
</soapenv:Body>
</soapenv:Envelope>
Avatar
This is a guess but maybe you need to define your
dataProvider like this?
dataProvider="{wsQryProgress.doQueryWS.lastResult.Credenciales}">
or
dataProvider="{wsQryProgress.doQueryWS.lastResult.Credenciales.Credencial}">
Avatar
Level 1
I tried it, but when I debug it , I got this message:
warning: unable to bind to property 'Credenciales' on class
'flash.xml::XMLNode' (class is not an IEventDispatcher)
What should I do?
Avatar
Level 3
Hi RafeFlex,
I think the problem is that your webservice is not returning
an Array or a collection (i.e. ArrayCollection). A SOAP response
of:
<Credenciales>
<Credencial>
<Credencial>
</Credenciales>
would be deserialized into an Object graph similar to this:
var o:Object = {Credencial: {idcredencial:"934847",
chrUsername:"jlrueda@todito.com"}};
The problem with this is that the dataProvider property on a
DataGrid expects you to assign an Array or ArrayCollection to it.
If you pass an Object, it puts it into the first position in a new
array it creates internally. It then looks for idcredencial and
chrusername properties (based on your DataGridColumn dataFields) on
this object and it won't find them because the object has only one
property on it: Credencial (which is the object you're trying to
display in the grid).
You should either update the web service to return an array,
or process the result yourself moving any nested
<Credencial>s into an Array to assign as the grid's
dataProvider. Or if you only ever get a single Credencial back in
your result, update your binding to:
dataProvider="{wsQryProgress.doQueryWS.lastResult.Credencial}".
I think you also need to change your second DataGridColumn's
dataField from "chrusername" to "chrUsername" to match the returned
value.
Best,
Seth
Avatar
Level 1
It seems the better is to change the webservice, just I don't
know how should be the result if it returns an array instead an
Document
