4 Replies Latest reply on Oct 19, 2011 2:45 AM by vandrito
    Native extension on Mac OS X (Air 3)
    vandrito
      Hi
      I have a blocking issue for native extensions when targetting the MacOS-x86 platform. (in my case Snow Leopard)
      I succeded in packaging the ANE file, but I have this error when using it in my test app:
      [SWF] tekhnia.simpleAirNativeExtension - 2 871 octets après la décompression
      [SWF] simpleAirNativeExtensionTest.swf - 2 119 250 octets après la décompression
      Context: [object ExtensionContext] in /Users/vandrito/Documents/Projets/o3sui/.metadata/.plugins/com.adobe.flexbuilder.project. ui/ANEFiles/simpleAirNativeExtensionTest/macosx/simpleAirNativeExtension.ane
      ArgumentError: Error #3500: The extension context does not have a method with the name isSupported.
                at flash.external::ExtensionContext/_call()
                at flash.external::ExtensionContext/call()
                at tekhnia.org.simpleAirNativeExtension::simpleAirNativeExtension/isSupported()[/Users/vandr ito/Documents/Projets/o3sui/simpleAirNativeExtension/src/tekhnia/org/simpleAirNativeExtens ion/simpleAirNativeExtension.as:16]
                at simpleAirNativeExtensionTest/init()[/Users/vandrito/Documents/Projets/o3sui/simpleAirNati veExtensionTest/src/simpleAirNativeExtensionTest.mxml:15]
                at simpleAirNativeExtensionTest/___simpleAirNativeExtensionTest_WindowedApplication1_creatio nComplete()[/Users/vandrito/Documents/Projets/o3sui/simpleAirNativeExtensionTest/src/simpl eAirNativeExtensionTest.mxml:5]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.core::UIComponent/dispatchEvent()[E:\dev\4.y\frameworks\projects\framework\src\mx\core \UIComponent.as:13151]
                at mx.core::UIComponent/set initialized()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UIComponent.as:1818]
                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.y\frameworks\projects\framewo rk\src\mx\managers\LayoutManager.as:842]
                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.y\frameworks\projects \framework\src\mx\managers\LayoutManager.as:1180]
      In fact it seems that the initializer is not executed. This is my extension declaration file:
      <extension xmlns="http://ns.adobe.com/air/extension/3.1">
         <id>tekhnia.simpleAirNativeExtension</id>
         <versionNumber>1.0.0</versionNumber>
         <name>tekhnia.simpleAirNativeExtension</name>
         <copyright>@2011 OpenTekhnia, Techniware</copyright>
         <platforms>
            <platform name="MacOS-x86">
               <applicationDeployment>
                   <nativeLibrary>simpleAirNativeExtension.framework</nativeLibrary>
                   <initializer>initNativeExtension</initializer>
                   <finalizer>doneNativeExtension</finalizer>
               </applicationDeployment>
             </platform>
          </platforms>
      </extension>
      That's my *.m file in the xcode framework project:
      #import "simpleAirNativeExtension.h"
      FREObject isSupported(FREContext ctx,
                      void *functionData,
                      uint32_t argc,
                      FREObject argv[]) {
          FREObject retObj;
          FRENewObjectFromBool(1, &retObj);
          return retObj;
      // contextInitializer()
      // The context initializer is called when the runtime creates the extension context instance.
      void contextInitializer(void* extData, const uint8_t* ctxType, FREContext ctx,
                              uint32_t* numFunctions, const FRENamedFunction** functionsToSet) {
          *numFunctions = 1;
          FRENamedFunction* func = (FRENamedFunction*)malloc(sizeof(FRENamedFunction) * (*numFunctions));
          func[0].name = (const uint8_t*) "isSupported";
          func[0].functionData = NULL;
          func[0].function = &isSupported;
          *functionsToSet = func;
      // contextFinalizer()
      // The context finalizer is called when the extension's ActionScript code
      // calls the ExtensionContext instance's dispose() method.
      // If the AIR runtime garbage collector disposes of the ExtensionContext instance, the runtime also calls
      // contextFinalizer().
      void contextFinalizer(FREContext ctx) {
          // Nothing to clean up.
          return;
      // initMulticastSocket()
      // The extension initializer is called the first time the ActionScript side of the extension
      // calls ExtensionContext.createExtensionContext() for any context.
      void initNativeExtension(void** extDataToSet, FREContextInitializer* ctxInitializerToSet,
                               FREContextFinalizer* ctxFinalizerToSet) {
          *ctxInitializerToSet = &contextInitializer;
          *ctxFinalizerToSet = &contextFinalizer;
      // done()
      // The extension finalizer is called when the runtime unloads the extension. However, it is not always called.
      void doneNativeExtension(void* extData) {
          return;
      and that's my .h:
      //  simpleAirNativeExtension.h
      //  Created by Victor Andritoiu on 17/10/11.
      //  Copyright (c) 2011 OpenTekhnia. All rights reserved.
      #import <Foundation/Foundation.h>
      #include "Adobe Air/FlashRuntimeExtensions.h"
                               FREContextFinalizer* ctxFinalizerToSet);
      void doneNativeExtension(void* extData);
                            void *functionData,
                            uint32_t argc,
                            FREObject argv[]);
                              uint32_t* numFunctions, const FRENamedFunction** functionsToSet);
      void contextFinalizer(FREContext ctx);
      @interface simpleAirNativeExtension : NSObject
      @end
      And finally my AS3 code for the lib:
      package tekhnia.org.simpleAirNativeExtension
                import flash.external.ExtensionContext;
                public class simpleAirNativeExtension {
        /** extension context */
                          protected var context: ExtensionContext;
                          public function simpleAirNativeExtension() {
                                    context = ExtensionContext.createExtensionContext("tekhnia.simpleAirNativeExtension", "");
                                    trace("Context: " + context + " in " + ExtensionContext.getExtensionDirectory("tekhnia.simpleAirNativeExtension").nativePath);
                          public function isSupported(): Boolean {
                                    return context.call("isSupported") as Boolean;
      and for the app using it:
      <?xml version="1.0" encoding="utf-8"?>
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                           xmlns:s="library://ns.adobe.com/flex/spark"
                                                           xmlns:mx="library://ns.adobe.com/flex/mx"
                                                           creationComplete="init()">
        <fx:Script>
                          <![CDATA[
                                    import mx.events.FlexEvent;
                                    import tekhnia.org.simpleAirNativeExtension.simpleAirNativeExtension;
                                    protected function init(): void {
                                              var sane: simpleAirNativeExtension = new simpleAirNativeExtension();
                                              trace(sane.isSupported());
        </fx:Script>
        <fx:Declarations>
        <!-- Placer ici les éléments non visuels (services et objets de valeur, par exemple). -->
        </fx:Declarations>
      </s:WindowedApplication>
      If anybody succeeded in using extensions on MacOS, please first tell me that s possible then, maybe help me on getting the error that I make.
      Thanks a lot
      Victor
