Thanks Harvey for the Correction. The first line of my
previous posting should have read:
If you go into the !SSL! folder to the folder for Flash
output there is an HHK file.
I will include here concise instructions for a solution that
worked for myself and Maura in case someone doesn't want to read
through all the previous postings:
1. Back up your main project folder and all its contents.
2. Generate FlashHelp output. (Even if you primary layout is
WebHelp or HTML Help)
3. Go to your main project folder and DELETE the .XPJ and
.CPD files.
4. Go to the !SSL! folder inside the main project folder.
Find the FlashHelp folder. Copy the .HHK file from the FlashHelp
folder into your main project folder overwriting the existing .HHK
file. (Alternately you can open both files in NotePad and copy the
entire contents of the .HHK file in the FlashHelp folder and paste
it into the .HHK file from the main project folder overwriting any
existing data, then save the file.
5. Find the .HHP in the main project folder, right click on
it and choose EDIT. The .XPJ and .CPD you deleted in step 3 will be
regenerated and your project will open and should function
properly.
Remember as Harvey suggested above to make sure you don't
have any unusual characters in your file names as this can cause
corrupted files in RH and the problem might reoccur.
Please see the following TechNote for more information:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=rb_34906
Thanks to Harvey, Brian and Maura for their valuable input
into this solution.
