4 Replies Latest reply on Oct 24, 2011 4:52 AM by Arnie_S
    the html doesn't  show the list of  actions
      i'm using a imac and macbook pro (mac os 10.6.8) with photoshop cs5 extended me version -- the tutorial works fine in photoshop, but the html doesn't show the list of actions...
        • 1. Re: the html doesn't  show the list of  actions
          Mira D Adobe Employee
          Hi Eran,
          Did you install the ScriptListener Plugin?
          To install the ScriptListener plug-in, please copy the file ScriptListener.plugin from Adobe Photoshop CS5/Scripting/Utilities/ and paste it into the folder Adobe Photoshop CS5/Plug-ins/Automate/.
          • 2. Re: the html doesn't  show the list of  actions
            I seem to have the same problem as Eran, the tutorial is working atleast the before and after part of it.
            ScriptListener Plugin is installed and the log is appearing on my deasktop.
            not sure if it is  recording, when i open the log is empty.
            • 3. Re: the html doesn't  show the list of  actions
              wil_li Adobe Employee
              One way to check whether or not the ScriptListener Plugin is working properly is to see if a) it is creating/updating the ScriptingListenerJS.log file on the Desktop and b) if that file actually contains anything.  For both Eran and Maaskeikke, it sounds like the log file *is* being created but that it is empty.  If that's the case, it seems like this might be an issue with the Script Listener Plugin, and I'm not sure exactly what to recommend.  I'll ask the folks who wrote the Script Listener if they have any thoughts and post an update on this forum.
              Here's one other thing to note: sometimes, the Script Listener does not write out instructions immediately after they are demonstrated in Photoshop.  In my experience, if you save the document at the end of your recorded demonstration, that often "flushes" all instructions to the Script Listener log file.  Please let me know if this helps.
              • 4. Re: the html doesn't  show the list of  actions
                I have the same problem.  Running on a Macbook Air, Lion OS.  I tried saving the file at the end of the tutorial, but that didn't seem to help.
