I have one parent RH project and 32 child RHprojects. In creating links to each of the child projects, that project was merged with the parent.
Instead of all content being displayed in the parent window, each child is opening in its own browser.
These projects were upgraded to V9.0 and the HHP file was showing absolute paths to child chm files. I have tried:
I have followed the instructions from Peter and Karen regarding Merged help but alas, no luck
I resorted to rebuilding the parent project from scratch using RH9.0 Iinitially no HHP file)
Remerged all of the child projects into the parent and compiled the parent
HHP file appears and lo and behold, relative paths
All child content opens in parent window
All prayers answered, almost!
If I edit the project and recompile I am back to square one with multiple browsers opening. Inspecting the HHP file revealed that the [Merged File] section is now missing.
I have tried recompiling with the child chm files in the root of the parent and without. The result is still the same.
I am pulling my hair out with this one so if anyone has an idea I should be most grateful
Cheers
Steve
I had the problem with one chm constantly falling out of the merge. To fix that, I had to manually edit the xpj file in a text editor, ensuring all (correct) chms were listed in the <mergedhelpfiles> tag. The format should look like this (in RH6, but I think should be the same in RH9):
<mergedhelpfiles>
<file>
<name>MyHelp.chm</name>
<comments></comments>
</file>
</mergedhelpfiles>
HOWEVER. I think this might force the hardcoded paths problem, for which the only workaround I found was to double-compile every time I needed a new parent. If you're using Peter's setup with almost no content in the parent, then, I believe this should be fairly infrequent.
(Double-compile = Compile. Open hhp and delete hardcoded paths. Recompile.)
Anyway, see if this is any help
Amber
Thanks for that. Actually, I didn't quite go down the redirect path, instead I latched onto the fact that only upgraded projects have the problem with merged help, not projects created in RH9.0. Even so, in the freshly created project, the XPJ file contains the line:
<MergedHelpCollectionFilename>rhmhelp.apj</MergedHelpCollectionFilename>
however, the file rhmhelp.apj does not seem to exist!
This is seriously doing my head in and the release deadline is looming.
Try manually adding the merged chms into the xpj like I suggested in my first post.
Tried amending the .xpj file and as suggested and compiling the collections to an external topic. Reviewed the HHP file and as suspected, it does indeed hard-wires an absolute path to the child chm files.
I am open to suggestions. I have rebuilt the parent so many ways now and nothing seems to fix this.
Unfortunately, I think if Peter's solution for a permanent fix didn't work, then the double-compile is the only workaround I know of. At least with that method you do get the merge to work.
I'll just list the steps in full:
1. Compile the help.
2. Open the hhp file in a text editor.
3. In the MERGED FILES section, delete all the paths, leaving only chm file names.
4. Recompile in Robohelp.
Amber
Edit: Actually, I just re-read, and the merge is still working, just opening in a separate window? I'll try to track down that setting I mentioned earlier.
Okay, I don't have RH9, but check in a location similar to this.
Open the single source layout you use to build you chms. Make a note of what you have set for Default Window. There should be an Advanced Settings section or button. Open that dialog box. There should be a TOC Settings tab. Check that the Default Window on that tab is either <Default> or the same window name you made a note of earlier.
See if that helps with the opening problem.
Regarding the separate window for child chms, I seem to recall a setting somewhere that configures the window to use for the TOC. Possibly in the Output definition in an Advanced button somewhere.I don't have access to RH just at the moment to check.
We upgraded to RH9 about 9 months ago. Prior to our upgrade, we were using RH7. Our Help solution consists of one parent project with 30-some merged children. In RH7, we had the issues that everyone else has with the full file paths appearing in the HHP file, and we used the “double-compile” solution mentioned here to work around it. Unfortunately, the double-compile solution does not work in RH9. No matter how many times you edit the HHP and recompile, the full file paths appear in the output.
We thought for a while that we had found a solution. Over time, we had stopped following the typically workflow for merging projects. So we backed up and started over, using the recommended steps. After merging all the children into the parent using this method, the merge list in the HHP file was fine. Over time, however, especially when more than one person used the parent project (we have 5 different writers), the full file paths would come back, and the only way to fix them was to re-merge the children.
But I think we may have found a solution. It’s another workaround, but I think we’re going to try it for a while as it’s preferable to the alternative (re-merge every time we need to compile). If anyone else tries it, please post back here to report your success/failure. I’m a little concerned that this new workaround may introduce new issues that we just haven’t seen yet. I’ll post an update if we encounter any new problems.
Here’s our process.
A couple things to note:
Sit down and anchor yourself before reading on...
I hate to tell you this after what you have been through but the problem is allegedly fixed with the 9.0.2 Service Release.
Ha! Well now that we’ve got it working, I’m not sure that I want to tempt fate by installing an update. You say “allegedly.” Do you know anyone who has tried it?
Brenda
Can you not try it with the trial version on a spare machine?
I used "allegedly" as I haven't seen confirmation from real world users.
As the originator of this thread, I would like to point out that I believe my woes are at an end (he says bravely).
Despite following all the tips and tricks and workarounds (thanks to all those who responded), none proved to be a lasting success (even with 9.0.2).
The only solution that worked was to copy all of the chm files into the root of the parent, remerge them all and then compile the parent; the resulting chm file works fine with all content displaying in the single parent window (relative paths). Even editing the parent and re-compiling was a success, HOWEVER, closing the project proved fatal. Upon reopening the parent and re-compiling, absolute paths were re-established!
Now the good news. There have been a couple of Adobe updates, unfortunately I tend to just accept them and get on with things so I don’t know what they were or what they fixed however, my absolute/relative path issue has now been resolved! I can close and recompile to my heart’s content and all is as it should be.
Whether there was a RH update or an Acrobat update that changed some shared file(s) I neither know or care, I just wish that Adobe hadn’t “improved” that functionality in the first place, which caused such grief.
Currently, my RH build is 9.0.2.271 and it works. I am however, reluctant to install any more RH updates, at least on my main machine. As the old saying goes, “if it isn’t broken, don’t fix it!
Regards
Steve
Technical Author
SRH Systems Ltd
Braemar Court
1311B Melton Road
Syston
Leicestershire LE72EN
Tel : +44 (0)116 260 1051
Mob: +44 (0)776 929 8519
steve.norris@srhsystems.com
