2 Replies Latest reply: Oct 18, 2011 9:50 AM by dcacrobat RSS
    HTML 2 PDF Failure
    dcacrobat Community Member
      I write to report an issue during a scanning issue.  This is a Canon scanner that has a feature of scanning to a PDF.  Working with Adobe Acrobat 6.0 professional on a Vista Ultimate machine.  The specific message reads:
      There was an error while loading the plug-in HTML2PDF.api. The plugin failed to initialize.
      At the time I was not attempting to convert a URL to a PDF.  Seeking guidance on corrective measures.
        • 1. Re: HTML 2 PDF Failure
          Bill@VT CommunityMVP
          If your scanner is producing the PDF, then you do not have an Acrobat question. If you are scanning into Acrobat, that is a different issue. It sounds like you are using a scanner feature, not Acrobat.
          • 2. Re: HTML 2 PDF Failure
            Much thanks for your timely reply.  The scanner software requires that one must scan to an application.  The configuration has to point to an executable.  In program files I must select an executable,  in this case acrobat.exe.   Have been using this for years and never have seen a problem.  Continues guidance sought.
