Sorry I have start a new thread, was unable to post reply to my same thread posted 2 days ago.
To answer your question,
What is inside,
C:\Windows\system32\macromed
in Flashinstall folder
=O====== M/11.0.1.152 2011-10-18+20-55-56.291 ========
0000 00000010 "C:\Users\sam\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\FZFKGNAZ\uninstall_flash_player_64bit[1].exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000018
0011
0012
0013 00000018
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036
0037
0038
0039
0040
0041
0042 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0043
0044
0045
0046
0047
0048 00000011 1
=X====== M/11.0.1.152 2011-10-18+20-56-02.562 ========
Inside C:\windows\syswow64\macromed\flash
there are 4 applications
Flash11c.ocx
FlashInstall
FlashUtil11c
Flashutil11c_ActiveX
I have install Adobe flash player 32 bit for IE8 from FAQ here, than why applications are in syswow64, is that a problem? Also in Mange Add-ons, I do not see shockwave Flash Object, but when I click on, All add-ons, it will appear and is Enable. If you need any more setting info, please let me know.
Please I need your help to resolve this issue,
Many thanks.
I assume from your last reply that there is not much you can do. By any chance, do you have Adobe technical support number for flash player, which you can emails me?
What is your operating system & version & edition?
I suggest that you download & run the uninstaller from the same FAQ entry, then restart your system.
Make sure that both C:\Windows\system32\Macromed\Flash and C:\Windows\syswow64\Macromed\Flash are completely empty before you try the installation again.
You need to run the 32-bit installer on 32-bit Windows, or the 64-bit installer on 64-bit Windows.
I have windows Vista 64 bit, also have IE 8, 32 bit and 64 bit.
I tried both 32 bit flash player from FAQ for IE 8 32 bit.
and 64 bit flash player for IE 64 bit.
After every uninstall, check if Macromed folders are empty, restart and try again from folders saved on desktop as admin, I also disable my CA security suite, and tried the whole process.
I am furious at Adob, why they force people to upgrade to their newer version. Their software should be able to identify, who has the compatible version for upgrade.
I do not understand this - did you run both 32-bit and 64-bit installers?
Since your OS is 64-bit you only need to run the 64-bit installer.
Nobody is "forcing" anyone to upgrade; you always have that choice. The installer at http://get.adobe.com/flashplayer/ will automatically install the correct version on your system. Only when there are problems, we recommend to download the direct installers.
No I am using one download at a time, so good to know that I only need 64 bit, I have tried every option, disable anti virus, unistall, delete all flash folders, restart, install, restart. delete cookies and temp folders, change setting in internet options under secuirty per other threads here. Download Safari, now youtube request to download 10 or newer version.
I am totally out of ideas, may be I will go to Best Buy. This is not fair......
Press Alt and X, move pointer to Safety, is ActiveX filtering unchecked?
Do you have Shockwave Flash Object enabled (http://forums.adobe.com/thread/885448) ?
Yes, shockwave player Object is enable in add ins in both IE and Safari.
I have IE 8, is there ActiveX Filtering option?
I disable CA internet security from Start up.
Start in safe mode, install
Restart
Both IE and Safari does not work, [youtube is keep on giving error " to run this programe, I need to install flashplayer 10 or above" which means old copy of flash is somewhere on computor.]
Yes, I delete flash folder from system 32 and syswow64. also click start , explore and delete flash folder from macromed32 and 64.
Carl Myers Jr, unable to follow your instructions.
ActiveX Filterin is new on IE9.
After reading every where on line for a clue to make flash player to work, I tried, https:/www.youtube.com, it works for the first clip and Dailymotion, which I believe has a built in flash player also works. But unable to use flash player in IE, Safari and FF.
Also I am unable to post a reply on this forum, using another computor to post a reply here. Keep on getting error to download flash player from Adobe.
Going to Internet Options, Security, what is your security level for Internet?
For internet, it is medium high but for trusted sites it is medium, I keep of changing medium high to medium, but due to CA internert security suite, I believe it is default to medium high.
