1. Re: Problems with RoboHelp 8 HTM and JavaHelp
Susan Darling Jun 1, 2009 2:03 PM (in response to SYGP)Hi. I too am experiencing the same "Java IO Exception" error when it's at the "Building Full-Text Search" part. Did you ever figure out a fix to this problem? Hope you or someone has an answer.
2. Re: Problems with RoboHelp 8 HTM and JavaHelp
Agnepal Oct 19, 2011 4:23 AM (in response to SYGP)Hi!
I'm still having the same problem I was hoping to find some solution, because it is really annoying.
I've noticed that this exception occurs after some minor modification in topic text (e.g. correcting a grammar mistake). Also, after generating JAVA help and viewing the results, the topics which have "?xml version="1.0" encoding="utf-8" ? at the beginning, won’t be displayed correctly and won’t be found in the search results.
So, I was not able to find the problem, although my colleague can modify the same help projects, and won’t get the same exception. So, my PC was changed, Robo Help installed freshly, but this problem still remains .
Well, any clues?
3. Re: Problems with RoboHelp 8 HTM and JavaHelp
Peter Grainge Oct 19, 2011 4:39 AM (in response to Agnepal)I have moved this thread to the Other Layouts category where it belongs as the problem is with a particular output.
I don't know the answer but hopefully SYGP or Susan Darling will come back with how they solved the problem.
4. Re: Problems with RoboHelp 8 HTM and JavaHelp
Agnepal Oct 19, 2011 5:06 AM (in response to Peter Grainge)Thanks for the reply.
There are two possible workarounds in this case:
1. Import the source again and do not change a thing.
2. Extract the damaged output file and delete the "?xml version="1.0" encoding="utf-8" line. Then compress .jar again.
Neither of these are timesavers
I'll be still hoping to see a solution for this problem.
5. Re: Problems with RoboHelp 8 HTM and JavaHelp
Peter Grainge Oct 19, 2011 5:15 AM (in response to Agnepal)Sounds like the time to report a bug.
The more people who report a bug or request a feature, the more likely it is to be actioned. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
6. Re: Problems with RoboHelp 8 HTM and JavaHelp
Agnepal Oct 19, 2011 5:45 AM (in response to Peter Grainge)Thank you, Peter!
