Hi guys.
I have a big problem, the flash player simply dosen't want to install, it simply dissapears, i gonna type the exact steps i took for this to happen.
Open mozilla firefox-Go to adobe site-find flash player-click on Download now- it takes me to download page all thing normal it pops up for download, after i download it i click on open containing folder and it takes me to the program, i right click then i click on Run As Administrator, HERE is the problem, after i click on OK (after it asks me for permission) Adobe Flash Player simply dissapears and no installer appears, however it does appear on the process list (using like 10k memory) and i must close it using end process since it only stays there doing absolutely nothing. Any help please?
Additional Info: OS: Windows 7 Ultimate x64
CPU: Core i5 760 @ 4GHz
RAM: 4GB at 1200Mhz (1333MHz normal)
PSU: 750W power-supply.
Have you tried uninstalling before installing the new player? Use the uninstaller here (http://kb2.adobe.com/cps/141/tn_14157.html) and then download the following installer and try it...
http://download.macromedia.com/pub/flashplayer/current/install_flash_player_64bit.exe
Thank you, i did uninstalled flash player before installing the new version but it did not worked, however the unninstaller you have provided worked
Not clear; so the same thing happens with the installer from the link in Josh's post?
Can you post the contents of the FlashInstall.log file in C:\Windows\syswow64\Macromed\Flash ?
The installer from Josh's post worked. As the content list is very long I will post one of the failed installs, tell me if I must post the entire content.
= M/11.0.1.152 2011-10-19+15-28-30.844 ========
0000 00000010 "C:\Users\<User Name Hidden>\AppData\Local\Temp\4674.dir\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash11c.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11c_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11c_ActiveX.dll
0006 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007
=X====== M/11.0.1.152 2011-10-19+15-28-32.731 ========
