1. Re: Keep original file names in HTML Web Gallery
MarkDas Feb 9, 2011 10:36 AM (in response to MarkDas)Ok, I'm not a coder, but have enough street-smarts to have found the script that's doing the renaming. I could--and might have to--through trial and error, figure out the fix myself, but if anybody could help, here's where the culprit script is:
C:\Program Files\Common Files\Adobe\Bridge CS5 Extensions\Adobe Output Module\mediagallery\resources\htmlgallery\cutName.js
I'd greatly appreciate anyone's help here. Here's the current text of "cutName.js":
function getName(name){
var len;
var i;
var displayName = "";
for (i = 0; i < name.length; i++) {
var hexValue = name.charCodeAt(i);
var value = parseInt(hexValue, 10);
if (value == 32)
displayName += " ";
else
displayName += name.substr(i, 1);
var table = document.createElement("table");
table.style.visibility = "hidden";
var body = document.createElement("tbody");
table.appendChild(body);
var tr = document.createElement("tr");
body.appendChild(tr);
var td = document.createElement("td");
td.setAttribute("noWrap","true");
td.setAttribute("text-align","center");
td.innerHTML = "<font size=\"2\">" + displayName + "</font>";
tr.appendChild(td);
document.body.insertBefore(table, null);
len = td.offsetWidth;
try {
table.parentNode.removeChild(table);
} catch (e) {}
if (len >= 150) {
break;
if (i != name.length) {
displayName = "";
var lastName = displayName;
if (value == 32)
displayName += " ";
else
td.innerHTML = "<font size=\"2\">" + displayName + "...</font>";
tr.appendChild(td);
try {
} catch (e) {}
if (len >= 150) {
displayName = lastName + "...";
break;
return displayName;
function addSpace(name, width)
for (var i = 0; i < name.length; i++) {
td.width = width;
td.setAttribute("word-break","break-all");
td.innerHTML = "<font size=\"3\">" + displayName + name.substr(i, 1) + "</font>";
tr.appendChild(td);
var len = td.offsetWidth;
try {
} catch (e) {}
if (len > width) {
displayName += " ";
return displayName;
2. Re: Keep original file names in HTML Web Gallery
Curt Y Feb 9, 2011 11:05 AM (in response to MarkDas)This post may be of no help, but seem to remember
some post similar to this several months ago. My memory could be
wrong, but seems like I remember the problem with a permission issue on a network drive. Since it did not have write permission it had to write in another place and the name was changed. Are you using a network drive.?
3. Re: Keep original file names in HTML Web Gallery
MarkDas Feb 9, 2011 11:35 AM (in response to Curt Y)Thanks for your reply, Curt.
Nope, it's not a network drive. I've read the post you refer to as well, and I don't think that's really the issue.
I suggest you try outputting a gallery and see if it doesn't rename your image names as well. I'm sure it will...Again, the disply name will be correct, but the actual file name when you try to save the image from the gallery will be different.
It's apparantly an intentional thing that Adobe has written into CS5. Other photographer friends complain about it as well, as it really 'kills the deal' in HTML galleries. If I didn't want my images copied and saved, I'd simply make a Flash gallery instead.
The Adobe script posted above is even named "cutName.js," showing clear intent on behalf of Adobe to do just that
I've since played a bit with some alterations in the script, and had some success on altering the output of the finished gallery, but since I'm not a coder, it's all trial and error for me...
4. Re: Keep original file names in HTML Web Gallery
Curt Y Feb 9, 2011 12:45 PM (in response to MarkDas)Never tried a web gallary, don't even know how to do it.
Might visit the Bridge Scrips forum and see what they say. http://forums.adobe.com/community/bridge/bridge_scripting
5. Re: Keep original file names in HTML Web Gallery
chaoxie Feb 9, 2011 10:40 PM (in response to MarkDas)Hi Mark
This renaming behavior is by designed in Bridge CS5 but since many customer don't want that so now we are considering changing on this. thanks!
6. Re: Keep original file names in HTML Web Gallery
MarkDas Feb 10, 2011 8:34 AM (in response to chaoxie)Hi Chaoxie,
Thanks for your reply. I'm assuming you're an Adobe employee by your response. If so, I can't stress enough the urgency behind this needed fix...
Bridge CS5 is otherwise nearly perfect. The speed with which it handles RAW conversions, the controls over image manipulation within RAW, the speed with which web galleries from RAW files are made are all amazing. The "look" of the HTML Lightroom web gallery is gorgeous.
The problem is, EVERY client of mine has complained about the renaming. It's so bad that it's actually angered some very long-time and very loyal commercial customers, and I've since had to revert to making web galleries in Photoshop. But for whatever reason, making the galleries the old way in Photoshop is agonizingly slow, taking about 10 times as long as within Bridge CS5.
So I'm asking that, while we wait for Adobe to fix the problem in an update, could you possibly fix the script above so that the re-naming doesn't occur, and post it ASAP, so I and others can implement the fix without waiting for a formal update?
Your help is GREATLY appreciated... Thanks Adobe.
7. Re: Keep original file names in HTML Web Gallery
jackthegiantslayer Mar 10, 2011 7:14 PM (in response to chaoxie)Yes, this is a huge problem for me too. What on earth were Adobe developers thinking, renaming the files?!?!? I use these galleries to generate download links for larger resolution images that clients can download, and clients want the file named the way I NAMED THEM. WTF?
8. Re: Keep original file names in HTML Web Gallery
grape jan Apr 9, 2011 10:41 AM (in response to jackthegiantslayer)I agree -- please please fix this problem soon. Not having the right file names on the html files is slowing my production time waaaay down! I anxiously await this fix!
9. Re: Keep original file names in HTML Web Gallery
PolarMedia.ca Apr 13, 2011 8:38 AM (in response to chaoxie)Same problem here... !!
I like Bridge CS5, but their is 2 major problems that are slowing me down in a day, they are :
- output for web file renaming (don't want that at all)
- impossibility to add a simple watermark/copyrigt to image when output for web (it was so simple back to Photoshop CS1, now I have to go by Lightroom do get this)
10. Re: Keep original file names in HTML Web Gallery
G0B0T May 5, 2011 3:45 AM (in response to MarkDas)Four years ago we were all better off with "web photo gallery" within Photoshop. It was simple, quick, painless and fast. Heck, we could even tweak the scripts and create custom layouts.
Then Bridge came along, stole it and broke it. Who's driving the ship here? Captain *******' Kangaroo?
To get back to the good olde days:
Web Photo Gallery in Photoshop CS4
http://www.gieson.com/Library/projects/utilities/photoshop/index.html
See also:
Quick Gallery
http://www.gieson.com/Library/projects/utilities/QuickGallery/index.html
11. SOLVED: Keep original file names in HTML Web Gallery
MarkDas May 5, 2011 10:46 AM (in response to G0B0T)Hi G0B0T,
Thanks for the suggestion. Problems with that are:
You must first convert your raw files to JPEGs, then wait for an agonizingly slow processing in PS. I love the way CS5 can take all of your adjusted/corrected RAW images and make a much more aesthically pleasing HTML gallery in mere seconds, even with hundreds of RAW originals.
Fortunately, I've figured out the solution. This will still leave you with an "underscore" leading off the filename, but will otherwise return the original file name to the actual JPEG file (both thumb and large) within the gallery...
This works for Windows. I imagine the Mac solution is similar. Props to William Zauscher for helping to write the code.
I take no responsibliity for any damage caused to your computer, Photoshop or Bridge in implementing the following...
In Windows, browse to C:\Program Files\Common Files\Adobe\Bridge CS5 Extensions\Adobe Output Module\mediagallery\resources\scripts
In the file named "galleryCreator.jsxinc" find and replace the lines:
AOM.AmgGalleryCreator.createUniqueFileName = function(filePath, jpgFile, createMode)
var alteredName;
while (true)
alteredName = "_";
for (var i=0; i<10; i++)
alteredName += Math.floor(Math.random() * 10);
alteredName += ".jpg";
var f = new File(filePath + alteredName);
if (!f.exists)
break;
return alteredName;
}...with the following:
var alteredName;
while (true)
alteredName = "_";
alteredName += jpgFile += ".jpg";
if (!f.exists)
break;
return alteredName;
You can cut and paste the above. Obviously, save a version of the original file somewhere in case of screwups...
Cheers!
-Mark
12. Re: Keep original file names in HTML Web Gallery
PolarMedia.ca May 6, 2011 6:49 AM (in response to MarkDas)scripts... codes... hacks... plugins...
All okay options, but hey, hello Adobe! I've payed arround 2 000 $ for this software. Any chance that you find the real permanent solution ?
...getting inspired by some solutions here, and then send us all a fix to it or an update ?
Thanks.
13. Re: SOLVED: Keep original file names in HTML Web Gallery
Adam Read Oct 19, 2011 12:50 PM (in response to MarkDas)That hack to the galleryCreator.jsxinc file worked for me. However, I changed the alteredName = "_"; to alteredName = ""; to get rid of the leading underscores. My server is set up to not serve any file that begins with an underscore. I started doing this so that Dreamweaver design notes didn't get served but found it useful for other things as well, like coldfusion includes.
14. Re: SOLVED: Keep original file names in HTML Web Gallery
rschletty Oct 25, 2011 9:51 AM (in response to Adam Read)I also need a real and immediate fix to this problem of renaming files. My files were carefully named using A Better Finder Rename by Frank Reiff. Why should Adobe think that I want my photos renamed to cryptic, meaningless character strings?
I will do the hack to the galleryCreator.jsxinc but that is not a happy thing to have to do when I have paid so much for CS 5 and 5.5.
