2 Replies Latest reply on Oct 23, 2011 8:45 PM by Xavier Beautoir
    Error while loading services: Failure in Loader: VerifyError: Error #1014
    Xavier Beautoir
      I have a library that, after it loads, I see this error in the console:
      Failure in Loader: VerifyError: Error #1014: Class mx.collections::ArrayCollection could not be found.
      I had the same problem with another library, except it had a problem with IToken. I got around this problem by changing the default linkage of libraries in build path from external to merge into code. That did not work this time.
      Merging Flex libraries into service libraries does not seem to be anything close to the correct way to deal with this. Besides, it didn't some the problem every time.
      What is the best way to keep these sorts of dependency errors from arising? The RSLs are included with Web apps, but not with libraries.
