37 Replies Latest reply on Oct 20, 2011 7:17 AM by keltoid
    Don't see Lighting effects filter in PS CS5
    John_Nolan Level 1
      I've installed CS5, and, although the Lighting effects filter seems to be in the plug in folders, it doesn't show up in the menus. I've removed PS and reinstalled, but still no go.
      I have this: "/Applications/Adobe Photoshop CS5/Plug-ins/Filters/Lighting Effects.plugin" and a Lighting Styles folder in the same path.
      PS 12.0 x64,
      Mac OS 10.6.3
      MacBook Pro Intel Core 2 Duo
      Any ideas what to do?
        • 2. Re: Don't see Lighting effects filter in PS CS5
          DKCMO Level 1
          .....and why, I might ask, in software used by Photographers around the world are picture package and contact sheet OPTIONAL.
          • 3. Re: Don't see Lighting effects filter in PS CS5
            gh65656757dxgfx Adobe Employee
            The Contact Sheet and Picture Package functionality has moved to Bridge and the AOM (Adobe Output Module). We still provide the plugins as an optional install.
            • 4. Re: Don't see Lighting effects filter in PS CS5
              Ben M Adobe Community Professional
              This may sound crazy but if those plugins are working for 64-bit Windows, does the Photoshop team plan on making them 64-bit Mac compatible during the CS5 release?
              • 5. Re: Don't see Lighting effects filter in PS CS5
                DKCMO Level 1
                Those apps in Bridge aren't as user friendly.   In filling orders and preparing proofs I need to be able to move fast within Photoshop... and to print at 360 dpi for Epson....  can't do that in Bridge apps.
                • 6. Re: Don't see Lighting effects filter in PS CS5
                  Level 7
                  On Windows, we didn't have to rewrite the plugins to work with a completely new API -- so it was easy to port to 64 bit (only minor changes were needed).
                  On Macintosh, you pretty much have to rewrite the UI code to work on 64 bit.  That's more work than we had time for in the case of some plugins (especially a few with ugly UI code).
                  • 7. Re: Don't see Lighting effects filter in PS CS5
                    Level 4
                       Since I can't afford a new machine in order to upgrade to CS5, I don't know whether to sigh in relief and revel in Schadenfreude over this shortcoming, or to gasp in astonishment.
                    Plug-ins supported in 32- and 64-bit Windows, and only 32-bit Mac OS:
                        * Lighting Effects
                        * Extract (Use Refine Mask under the Selection menu)
                        * Variations
                        * Web Contact Sheet II (Web Photo Gallery)
                        * Layer Comps to WPG
                        * PatternMaker
                        * PhotoMergerUI
                        * Picture Package
                        * Embed / Read Digimarc Watermark
                        * Firewire
                        * Firewire DLL
                    Ouch!
                    Wo Tai Lao Le
                    我太老了
                    • 8. Re: Don't see Lighting effects filter in PS CS5
                      DKCMO Level 1
                      Looks like I'll be running in 32-bit most of the time.  That's a shame.
                      • 9. Re: Don't see Lighting effects filter in PS CS5
                        c.pfaffenbichler Level 9
                        If you are concerned about efficiency you should definitely look into Scripting.
                        Printing is, as far as I can tell, unfortunately not good/easy to Script; but if you should have a hotfolder-setup with your RIP-software Scripts can be fairly useful.
                        • 10. Re: Don't see Lighting effects filter in PS CS5
                          Chris,
                          Thanks for the explanation.  But on a more  basic level you are saying that the features weren't ready for the CS5 launch but will still be developed,  ie: a download later through an update during the CS5 lifecycle.  Just as long as they were not being deprecated, that's all my concern was.
                          • 11. Re: Don't see Lighting effects filter in PS CS5
                            DKCMO Level 1
                            I think I will look into scripting.... although I'm pretty sure my brain is full.....
                            • 12. Re: Don't see Lighting effects filter in PS CS5
                              Level 7
                              We probably won't offer those plugins as downloads - the update represents too much work, and after a short time we run into revenue recognition problems (thanks FASB).
                              • 13. Re: Don't see Lighting effects filter in PS CS5
                                Diablo Venom Level 1
                                The fish always rots from the head first.
                                • 14. Re: Don't see Lighting effects filter in PS CS5
                                  katieDAMRONpotter
                                  here's a question for you because i'm also running mac OSX and cs5 had been working just fine - all of my filters, including lighting effects, showing up and then one day it stopped showing up. i've reinstalled three times and it won't come back... so... what do i do now?!
                                  • 15. Re: Don't see Lighting effects filter in PS CS5
                                    Bit late and anyway it might not be any of my business, but could you explain what »revenue recognition problems« means here?
                                    Personally I consider Lighting Effects as no big loss and I don’t especially miss Contact Sheet or Picture Package either (in contrast to PDF Presentation), but obviously there are a few customers out there who do – so how much complaining to whom would they have to do to justify the expense?
                                    • 16. Re: Don't see Lighting effects filter in PS CS5
                                      DKCMO Level 1
                                      Adobe just spent $223,000 on one full page ad in the Wall Street Journal.... so don't talk to me about expense    I still like CS5... just not the incompatibility of the mentioned plug ins with 64-bit....  I also get the feeling they are on the way out.
                                      • 17. Re: Don't see Lighting effects filter in PS CS5
                                        Level 7
                                        In a nutshell:  We can't add functionality after we ship without charging more for it (at least not without changing half our corporate accounting and scaring investors, or running afoul of accounting standards, auditors, regulators, etc.).
                                        FASB changed rules several years back to try and halt bad practices by a few software vendors, and ended up hurting everyone else in the process.
                                        • 18. Re: Don't see Lighting effects filter in PS CS5
                                          Yeah, well, that sounds annoying.
                                          • 19. Re: Don't see Lighting effects filter in PS CS5
                                            Penny wise, pound foolish. When you only look at numbers and models, you wind up screwing the pooch.
                                            • 20. Re: Don't see Lighting effects filter in PS CS5
                                              - JM - Level 3
                                              hi chris, I'm not picking on you, I actually think this is kinda cool that this was actually said "out loud", I do appreciate the honesty.
                                              if a company releases new features that they don't charge for, it hurts everyone else?  yikes!
                                              This is just a decision that Adobe has made, I have plenty of software from companies that offer new features during updates and don't charge for them. They are just on a different level of the food chain. Let's be honest, Adobe is sitting in a pretty good place with little to no competition. Adobe should be applauded for playing the game well and having a great product. But industry standards are man-made creations, unlike gravity and therefore can be changed.
                                              regards,
                                              j
                                              • 21. Re: Don't see Lighting effects filter in PS CS5
                                                Level 7
                                                Read again: the FASB rule change is what hurts everyone, by forcing bad changes in revenue recognition.
                                                This is partly an Adobe decision (in that we can't just change accounting rules mid-stream without causing other problems), and mostly a FASB decision.
                                                We have been trying to get the FASB rules changed for a while, without success.
                                                I wish things could be changed so we could deliver more for our customers mid-cycle, but we're constantly hamstrung by the new revenue recognition rules.
                                                • 22. Re: Don't see Lighting effects filter in PS CS5
                                                  Level 4
                                                  Chris Cox wrote:
                                                  …wish things could be changed so we could deliver more for our customers mid-cycle, …
                                                  If that ever happened, it would be such a shocking surprise that it would induce a heart attack in me.
                                                  • 23. Re: Don't see Lighting effects filter in PS CS5
                                                    I hope your cardiac situation is not as bad as all that.
                                                    And anyway, the Adobe Labs are, it seems, able to fly under the radar
                                                    occasionally and provide stuff like Configurator, which I consider
                                                    quite a beneficial feature.
                                                    • 24. Re: Don't see Lighting effects filter in PS CS5
                                                      - JM - Level 3
                                                      adobe labs probably avoids the problem because it falls under R&D and doesn't generate any real $$.
                                                      But this whole thing is sounding way more complicated than it is. FASB is not a government organization and revenue recognition is just a fancy way of determining what's left in your wallet at the end of the month. The bottom line is that customers generate the bottom line not investors.
                                                      I'm not an accounting whiz by any stretch of the imagination but I would guess that this FASB hocus pocus is about the contract that is established with the customer at the beginning of the product cycle. And I can't imagine that updating the Mac to fully 64bit would contradict this?  Or is the Mac version CS4.9 and the PC version is 5.0? This seems to be more about choice than law.
                                                      • 25. Re: Don't see Lighting effects filter in PS CS5
                                                        Level 7
                                                        If you think it's about choice, I welcome you to take it up with the CFO of our company (and all the other affected corporations).
                                                        We want to do more, but we can't because of the revenue recognition rules set by FASB.
                                                        • 26. Re: Don't see Lighting effects filter in PS CS5
                                                          - JM - Level 3
                                                          well, I didn't say it was your choice : )
                                                          FASB seems to be bent on establishing a consistent point to book revenue based upon a vendor customer contract?
                                                          The example that I like is an airplane ticket, you purchase the ticket, the revenue is booked but the work has not been delivered. So, it seems that work does not necessarily have to be completed when you stick the DVD in the box. Consider all of the following up work, fixing bugs, customer support etc. this is just written into the customer contract, and I would doubt that your contract is the same as Microsoft, or even your new best friend Apple. Adobe writes the contract..... and therefore choice.
                                                          The original question in this discussion is circling around some features ( 64bit plugins ) that exist in the PC version but not the Mac and were excluded because it was too much work to complete by the time the product was deemed ready to ship. That was a choice.
                                                          Or, just give away new features in a similar fashion as Adobe Labs, or call it beta. That would be a choice.
                                                          ( btw how do software companies hire beta testers but don't pay them? even interns can no longer be hired for free )
                                                          • 27. Re: Don't see Lighting effects filter in PS CS5
                                                            China Carnella Level 1
                                                            New to Adobe with CS5 and working on a 64 bit Mac. Do not have the checkbox above "Locked" that says "Open in 32 bit". Mine says "Shared Folder." Shared Folder is the only box I have the option of checking. I do not seem to have any way to get to my lighting effects! I have an assignment due tomorrow evening, so can anyone help me figure out what to do? I am new to this Mac and new to Photoshop with CS5. Thanks. P.S. I am using the Student Version of CS5 Design Premium which I called on about ten times and was assured by Adobe ten times that it was exactly the same as the non-student version.
                                                            • 28. Re: Don't see Lighting effects filter in PS CS5
                                                              Level 4
                                                              China Carnella wrote:
                                                              …Do not have the checkbox above "Locked" that says "Open in 32 bit". Mine says "Shared Folder."
                                                              China,
                                                              It sounds like you are selecting the Photoshop folder in the Finder.  You need to highlight the Photoshop application icon, not the folder that contains it.
                                                              … the Student Version of CS5 Design Premium which I called on about ten times and was assured by Adobe ten times that it was exactly the same as the non-student version.
                                                              It is.  Absolutely identical, except for the price.
                                                              ____________
                                                              Wo Tai Lao Le
                                                              我太老了
                                                              • 29. Re: Don't see Lighting effects filter in PS CS5
        bonkaboostudios
        Maybe I'm late to this 'party', but I've recently upgraded to CS5 and went to use the Lighting Effect and was bewildered it wasn't there...then I came across this thread and thought "WHAT?!  This won't be fixed until the next version release (which is my own conclusion from the posts by Chris)".  Here's the deal, they were available in the LAST release and now they're gone...how can that not be addressed in an 'update' for free?  Or as one post put it, at least release a 'beta' version of the missing plug-ins/filters until then for our sake, the users.
        BTW, no offense is targeted at you personally, Chris .
        Overall, really liking CS5.  But hey, it'd be a perfect world if I didn't throw a complaint! Again......
        George
        • 30. Re: Don't see Lighting effects filter in PS CS5
        jolh Level 1
        "Lighting Effects" is a tool I have come to rely on periodically in PS.
        And I am appalled that Adobe is hiding behind this obviously bogus rationale, which conveniently limits their responsibility to deliver a fully functioning product.
        Perhaps if the Windows version of CS5 had also shipped without the feature, that might have opened the argument that Lighting Effects was outmoded.  But alas, that is not the case.
        No, Adobe chose to withhold this feature in the Mac version to hit a self-imposed deadline / budget.  And rather than integritously complete the job at some expense to the company and issue it as a delinquent - free - update, they are feigning a rather weak "hands-tied" rationale.
        "We can't add functionality after we ship without charging more for it (at least not without changing half our corporate accounting and scaring investors, or running afoul of accounting standards, auditors, regulators, etc.). "
        With all due respect Chris - Adobe already charged for it. You charged all these Mac users the same price as the Windows users who have this functionality - so either way you slice it, you unfairly charged the Mac users for functionality that you chose not to deliver.
        No challenge Adobe may have faced behind the scenes - either internal accounting effort, or technical rigor - can rationalize this fact away.  Adobe's budget and / or timeframe were not adequate to complete the product, and the company chose profit of X over X minus the work to do the job right.
        So the customers have every reason to expect Adobe to cough up an update - free of additional charges.
        • 31. Re: Don't see Lighting effects filter in PS CS5
        keltoid
        Its ridiculous to pay what we pay for this software and you just "take out" something that obviously a lot of people use!!  There is NO EXCUSE for it.
        • 32. Re: Don't see Lighting effects filter in PS CS5
        Jeffrey Tranberry Adobe Employee
        You can still use Lighting Effects if you run Photoshop in 32bit mode.
        Here are instructions on how to run Photoshop in 32bit mode. http://kb2.adobe.com/cps/828/cpsid_82824.html#main__How_to_run_Photoshop_CS5_in_32_bit_and _64_bit_modes
        Lighting Effects is an aging plug-in that did not make the transition to 64bit. We plan to replace it with newer, better technology in the future - similar to how we stopped development on the Extract filter in Photoshop CS4 in order to focus on replacing it with the newer, non-destructive Refine Edge technology in Photoshop CS5.
        It was one of those tough decisions. Not ideal for everyone in the short term, but I'm hopeful that people will see greater benefit in the long-run.
        While I'm commenting, one other workaround I've heard people use is to keep CS4 around and launch it side by side (at least on the mac) so they don't need to tinker with the 32bit mode switch and keep CS5 running.
        1 person found this helpful
        • 33. Re: Don't see Lighting effects filter in PS CS5
        keltoid Level 1
        Actually, no I can't.  It worked before, but it is still checked to open in 32 bit and L.Effects is grayed out. So... I have no clue why it won't do it now.  You?
        • 34. Re: Don't see Lighting effects filter in PS CS5
        keltoid Level 1
        And I tried it in my version of CS4 too and same thing.  No option to open in 32 bit - and no Lighting effects.
        Which surprised me.
        • 35. Re: Don't see Lighting effects filter in PS CS5
        keltoid Level 1
        I also don't have Artistic, Brush Strokes, Texture, Sketch, Video, Lens Correction, Filter Gallery or Vanishing Point... all greyed out.... I guess I should be happy I have gaussian blur because I'm gonna need to use it to do all these things, I guess.  lol.  (not really funny)
        Probably because I AM opening in 32 bit.
        • 36. Re: Don't see Lighting effects filter in PS CS5
        - JM - Level 3
        any chance your image is in CMYK color mode?
        • 37. Re: Don't see Lighting effects filter in PS CS5
        keltoid Level 1
        Jeff, you totally rock, I'm so embarassed.  I thought to check that and just went to my color and it was in RGB, but the file IS in CMYK.  I was on the right track but didn't check correctly - and you just made me check it again -- thank you so much!  I couldn't imagine why it worked before and not now.  THANK YOU.
