This just keeps getting weirder and weirder!
Further to the problems with merged help and multiple browsers, I now have dissapearing folders!
I have reconstructed my original help project numerous times now in an attempt to perm any combination that works and it just seems to be getting worse.
I have a folder structure in the Project Manager view which I recreate each time when I re-import all the original html files etc.
In the Project Manager, the folder which contained the file is missing (yet it still exists in Windows Explorer)
I have to delete the entry in the root.fpj file to allow me to recreate the folder but when I hit the return key the folder dissapears again (but not always).
I thought I would be clever and keep a backup copy of the project before merging but the folder dissapeared from that too.
Any clues anyone?
Hi there
Can you please share the exact path and name of the missing folder?
Cheers... Rick
Attached is a screenshot showing the path to the folder in Windows Explorer and lack of in RH Project manager.
Bthe entry for the missing folder is still visible in the root.apj file. Deleting the entry allows you to create in again in RH Project Manager but it the vanishes again.
I am running RH9.0.1.232 with the security paches installed.
Regards
Steve
S drive suggests the project is on a network drive.
See item 120 at http://www.grainge.org/pages/snippets/snippets.htm
Projects need to be run locally.
Hi Peter,
It is actually being run locally. S: is a subst drive created on C:
subst s: /d
subst s: C:\STHELP
Regards
Steve
Partitions I understand but I am not sure what you mean by substring.
To be honest neither do I. This is a method of working that the company has used for a long time.
A folder is created on the local drive for example, HELP. Then add to it and run the “S” batch file. The HELP folder then becomes a “local drive” called S: which can be mapped to the Network repository.
In effect, ALL files are run local including the RH executables.
I spoke to our IT guy and he explained the SUBST is for substitution.
I think you need to speak to your IT and ascertain whether this really is a local drive or a network drive made to look local. What you are seeing is the sort of problem that can occur with network drives.
I can pull the string out of the back of my laptop and the I still have the drive. It is a local drive.
To be sure though, I opened the local folder and worked from there that is, C: STHELP (name of the folder declared as the S: drive) rather than the subst S: drive itself. Unfortunately, the same thing occurs.
Try a network cable instead of string.
I'm sorry but I have no idea what is causing this. Hopefully having established where the project is Rick will be able to offer something as he knows more about CHMs than I ever will.
Right now its 5am where he is so sit tight.
Thanks for looking anyway.
I am seriously at the point of creating a mammoth help project which will involve importing the content from the other 32 projects. This would avoid the problem with the merged help opening in new windows all the time however, if the folders are still disappearing then I would not be able to create the essential structure needed. Sort of caught between a rock and a hard place ☹
Does it have to be merged CHMs? Could the help sit on a server so that your developers could work with merged webhelp? Merged CHMs seem to be giving grief these days.
Unfortunately, the help is not just for developers. It is for a commercially distributed product and is installed on customer PCs as part of the installer package. Apart from the obvious issues of disappearing folders, my only concern with “mammoth” project would be the time it would take to display the help. The total buckets of CVHMs weighs in at 34MB!
I just created a new, blank HTML project.
In Project manager view I created a folder called URL
Save all and close the project.
Re-open the project and the folder is no longer in view
Create another folder called “crap”
Close and re-open
Folder is gone!!
Are there reserved words or is RH just being polite
I think this calls for an uninstall and reinstall
How exactly are you creating the new project?
Start > Programs > Adobe >Adobe RoboHelp 9 > RoboHelp HTML
Create New > Blank Project
Enter title for project (STARS) etc. > Finish
Create folder called URL
Close and re-open
Pop goes the bubble
Try going to Tools > Options and ticking Clear Project Cache. See if that fixes the problem.
I decided to uninstall (currently purging the registry) and then reinstall the Adobe suite (I have Acrobat 9 as well) before I opened a vein. Will try your suggestion when I am up and running again (although there should be no cache to clear)
Yes there will. The CPD is the cache and that is part of each project, not the installation.
Suggest you don't clear the cache (delete the CPD) at first. If the problem has gone away you will know it was the reinstall. If you defer clearing the cache and the problem persists until you do, again you will know what fixed it. Useful if this happens again.
Unfortunately, I created a brand new project so there should have been no cache to clear and yet still the folders disappear!
Nonetheless please try ticking that check box after creating a new project with some new folders. I have seen something similar and am trying to rule it out.
Hoorah! Having reinstalled RH 9 created a new project with folder names as before, they remain visible even after restarting the project. Even better, on opening the old project with invisible folders, they have also decided to come out to play. All is well with the world again ☺
Now I just have the merged help problem ☹
I am pleased to announce the re-installation of RH9 has definitely cured the vanishing folders but not the multiple help windows.
Each merged help link opens the chm of the merged help in its own window instead of the parent. Curiously, the link from the parent opens the first page of the child chm in the parent window as it should. It is only when you drill down that the child chm opens in its own window?
Just when you thought it was safe to go back in the water!
My folders no longer vanish as soon as I create them, but the links DO!
Create a new project
Import the original html files
Merge the child chms
Compile the help
Check the HHP file - lists all the files
OOPS! broken links
Fix the links by re-importing the files into the now empty folders (3 out of 16)
TOC looks ok, no broken links
Recompile the help
Multiple help windows again
Check the HHP file – no section
Re-import the original files
Check the TOC (ok)
Check for broken links (none)
Close the project
Open the project
The same links are all broken again and the folders “look” empty
I am so fed up with this now that I have delivered a sub-set of my projects to Adobe to see if they can come up with an answer because this is wasting so much time that I do not have!
If you have any other ideas though, they would be most be most appreciated.
Cheers
An almost broken
Steve
