Hi again Ron
I'm not sure what method you actually used to extract your
files, so I'll go with a method I'm familiar with.
If you have RoboHelp installed on a PC, a nifty thing is
installed on the context menu that displays when you right click a
.CHM file inside Windows Explorer. You should see an option labeled
"Convert to source". Click that and you should see something called
the HTML Help Studio. If you look at the files that appear inside
the left pane of this application, you should see a file bearing
the extension of .GLO. This is the file containing the Glossary
entries. So that should help you get the Glossary back.
The same pretty much applies with the browse sequences. But
the extension here is .BRS.
I'm not sure I'd totally give up on your map files. When I
look at this tool, if I expand the top level item (aptly named "Top
Level") I see something labeled "#IVB". If you click this item, you
see something that sure looks an awful lot like map ids in the
window on the right. You could click the window on the right, press
Ctrl+A to select all, then Ctrl+C to copy to the Windows Clipboard.
Then paste the whole shebang into a new fresh instance of Notepad.
I'm not sure if you can get away with this, but you can try saving
that Notepad file as the desired ".h" file and who knows? Maybe it
will work? If it doesn't work outright, maybe it will at least give
you something to use as a template or guide to rebuild the .h.
Cheers... Rick
