7 Replies Latest reply: Oct 27, 2011 2:01 PM by Jaap H RSS
    pixelFormatSupported
    Jaap H Community Member
      Hey guys,
      Trying to get into the pixelFormats here.
      I'm adjusting the SDK's Cross Dissolve in order to find out if it's possible to write a transition that only supports PrPixelFormat_BGRA_4444_32f.
      This way I can get into making quality plugins without having to write seperated code for different PixelFormats.
      "Starting in CS4, plug-ins no longer need to support 8-bit BGRA at a minimum."
      - I say: let PP handle the nessesary conversions. Let me focus on just the BGRA4444_32f
      So I'm banishing some lines of code:
      static prMALError GetPixelFormatsSupported(EffectHandle theData)
                prMALError result = esNoErr;
        switch((*theData)->pixelFormatIndex)
      /*                    case 0:
                                    (*theData)->pixelFormatSupported =  PrPixelFormat_BGRA_4444_8u;
                                    break;
                          case 1:
                                    (*theData)->pixelFormatSupported =  PrPixelFormat_VUYA_4444_8u;
                                    break;
        // These pixel formats are only available in Premiere Pro 2.0 and later
                          case 2:
                                    if ((*theData)->version >= 9)
                                              (*theData)->pixelFormatSupportedPrPixelFormat_BGRA_4444_32f;
        else
                                              result = esBadFormatIndex;
        break;
      /*                    case 3:
                                    (*theData)->pixelFormatSupported =  PrPixelFormat_VUYA_4444_32f;
                                    break;
        default:
                return result;
      So we are down to the one and only PrPixelFormat_BGRA_4444_32f
      I wanted to see what happens.
      But I didn't got the feeling it wasn't working, because it still showed the YUV sign in the effects tab.
      So I messed around with this: Banished some other lines of code so it would only support 8u.
      Well, at some point all the signs (32-bits and YUV) where gone in the Effects tab.
      Now I want them back. But I can't...
      I keep reloading the plug-in by restarting PP - nothing
      I'm holding shift at the start of PP to refresh all the plugins. - nothing.
      Redownloaded the fresh SDK pack, recompiled the cross dissolve with nothing changed - nothing.
      started to get frustrated...
      told the plugin not to cache itself, but to reload each time pp is started by adding:
              case esCacheOnLoad:
                  result = esDoNotCacheOnLoad;
                  break;
      to the selector switch: PREMPLUGENTRY DllExport xEffect (short                               selector,   EffectHandle           theData)
      looked at the ~/library/adobe/premiere pro/5.5/plugin loading.log   and found:
      Loading /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore/Cross_Dissolve.bundle
      The registry tells us not to cache so the plugin will be loaded from disk.
      Loading from disk...
      This plugin was recognized by loader 3dbe9220-aa71-4c9d-9342-4c239a83a825.
      - So this is OK. - but then again it doesn't change anything with the recogition for being 32-bits enabled
      So the SDK Cross Dissolve transition listed in the Effects tab still isn't showing me the 32bits sign, even with a freshly compiled original that should support both 32-bits color and YUV.
      What am I missing here?
      Cheers,
      Jaap
        • 1. Re: pixelFormatSupported
          Getting a step closer:
          It seems that deleting the:
          ~/library/preferences/com.adobe...5.5.plist
          wil get PP to update the 32-bits color and YUV icons behind the plugins in the effects tab
          Now the code above with only the PrPixelFormat_BGRA_4444_32f as being supported by the plugin doesn't work.
          A) PP doesn't show a 32-bits color icon.
          B) it acts as if the plugin would still support PrPixelFormat_BGRA_4444_8u (or YUV_8u) and doesn't launch the RenderDissolve32f  function.
          "Starting in CS4, plug-ins no longer need to support 8-bit BGRA at a minimum. If required, Premiere can make intermediate format conversions in the render pipeline, although these inter- mediate conversions will be avoided if possible."
          But It seems PP still requiers me to have my transitions to be 8-bit BGRA supported. True?
          Is it time for me to get into ScaleConvert()?
          Cheers,
          Jaap
          • 2. Re: pixelFormatSupported
            Rallymax
            The list of supported pixelformats is stored as an array so you have to start with an index of 0.
            Simply commenting out the handling cases won’t work – it’ll just fall through for those cases.
            You need to modify the PixelFormats[] array that is originally created so that Premiere knows what PixelFormats are supported.
            That means that you’ll end up with a
            PixelFormats[] = ; only
            Once you’ve done that change you can change the handling function too…
            if( (theData)->pixelFormatIndex == 0 && (theData)->version >= 9)
            (*theData)->pixelFormatSupported =  PrPixelFormat_BGRA_4444_32f;
                        else
                        return result;
            • 3. Re: pixelFormatSupported
              Thank you Rallymax,
              You have been very helpfull.
              This solved my issue.
              I keep testing and trying things to improve my skills.
              Now stangely the SDK guide says plugins no longer need to support BGRA8 at minimum.
              But for a transition to work properly, I found it still needs to handle BGRA8 in order to show the transition in the effect-control-window.
              Otherwise PP gives a serious error.
              Anyone knows if this is correct?
              Cheers.
              • 4. Re: pixelFormatSupported
                Rallymax Community Member
                Unfortunately plugin development isn’t as easy as we all would like but at least it is open for us to develop on.
                I suspect that the Editing Mode you’re in has a Player that doesn’t support BGRA_4444_32f and does (because of legacy) support BGRA_4444_8u thus the preview window requires BGRA_8u support to work.
                If you do want to support BGRA_4444_8u then you should be able to make common code by converting the 8u to 32f and then continuing your plugin as 32f. (Likewise you should do a YUV_32f to BGRA_32f –although if you don’t know a lot about rec601 and rec709 colorspaces I HIGHLY recommend that you DO NOT start doing this).
                Here’s a quick mock up off the top of my head…
                float The32fFrame = (float)TheFrame;
                int do_32f_to_8u = 0;
                switch((*theData)->pixelFormatSupported)
                case PrPixelFormat_BGRA_4444_8u:
                // Flag to un-convert at the end
                do_32f_to_8u = 1;
                The32fFrame= malloc(heightrowstride4);
                // Convert 0..255 (_8u) buffer to 0.0…1.0 (_32f)
                // Change this to SSE|2|3|4 intrinsics for a 4x or 8x speedup!
                for(int h=0;h<height;h++)                     // Height
                for(int w=0;w<width;w++)         // Width
                for(int p=0;w<4;p++)    // Plane
                                        The32fFrame[4hrowstride+ 4*w + p] =
                (float)TheFrame[4h rowstride + 4*w + p]/(float)255.0);
                // Now fall through and process as BGRA_32f
                case PrPixelFormat_BGRA_4444_32f:
                // IMPLEMENT YOUR FILTER/TRANSITION HERE
                break;
                            default:
                                        return WHATEVER THE ERROR CODE IS FOR UNSUPPORTED;
                //Run a loop that un-does the floating point conversion if necessary.
                if(do_32f_to_8u)
                // Change 32f back to 8u
                TheFrame[4h rowstride + 4*w + p] =
                (unsigned int)((float)255.0 * The32fFrame[4h rowstride + 4*w + p]);
                            free(The32fFrame);
                return prNOERR;
                ·         Where “rowstride” is the actual stride of the row, not the frame width.
                • 5. Re: pixelFormatSupported
                  Oops a mistake
                  Should be
                  The32fFrame= malloc(heightrowstride4*sizeof(float));
                  • 6. Re: pixelFormatSupported
                    This too…
                    new version with “w” to “p” fix…
                    for(int p=0;p<4;p++)    // Plane
                    • 7. Re: pixelFormatSupported
                      Thanks Rallymax,
                      This is clear to me.
                      And a fast way to get the 8bits compatibility.
                      Cheers.
