Topic keywords vs. index file keywords
Participant ,
Sep 06, 2006 Sep 06, 2006
What do you make of this (from RoboHelp Help):
Advantages of index file keywords:
You can merge index files with other projects (in HTML Help, binary indexes are required to merge projects).
Advantages of topic keywords
You can merge topic keywords from multiple .CHM files into a master project (Microsoft HTML Help projects only).
Both occurrences of "merge" are links that go to the same topic in RoboHelp Help.
So my question is, does it matter which method you use?
Until recently, my team's policy has been to save keywords in topics, because then the keywords are supposed to follow along when you reuse the topics in other projects (among other advantages). However, this doesn't work in practice, and it also doesn't work when you localize your help project -- the index is destroyed in both cases, with massive manual fixing necessary, as described in a separate thread.
This statement in RoboHelp Help also seems to be incorrect: "The master project must contain at least one index keyword that is associated with a topic or the index will be empty." We have merged helps with not a single keyword saved in a topic, and the index works great.
Therefore, my team is looking at changing our policy so that we always save keywords in the index file (HHK). Considering the problems in RoboHelp X5, is there ANY reason to save keywords in links?
Our output is either WebHelp or HTML Help, depending on the project. Some projects are merged, others aren't.
I would be really interested in others' thoughts and experiences in this matter. I don't feel that the help topics that describe the differences (advantages and disadvantages) are clear or correct.
Thanks.
/Eileen
419
Hi Eileen
Sorry to hear you have Index woes. I'm a bit confused as to how or why localizing your project would affect topic level keywords, unless the translators are also munging the code surrounding the keywords.
I think there is a slight misunderstanding with the merged index. You qouted: This statement in RoboHelp Help also seems to be incorrect: "The master project must contain at least one index keyword that is associated with a topic or the index will be empty." We have merged helps with not a single keyword saved in a topic, and the index works great.
What you didn't seem to clarify is if the Master of your merged helps was configured this way. You can certainly get away with a child or slave .CHM having no keywords. But it's always been my understanding that this is indeed a requirement for the Index to correctly function for merged .CHM files. It's not a RoboHelp thing either. It's designed behavior of the Microsoft HTML Help format.
Cheers... Rick
Participant ,
Sep 08, 2006 Sep 08, 2006
I couldn't find any error that translators may have made in the HTML tags containing the keywords. Of course, certain keywords (such as synonyms) became superfluous in the other languages and were deleted. Others were added. Indexes are not translated word for word. If they had been translated word for word, perhaps it wouldn't have been a problem. But that's not possible.
I'm not very experienced with merged helps, but I don't know what you mean by a Master being configured this way. The way we "merge" help projects is simply by adding them to the TOC of the main project, as described in RoboHelp Help:
quote:
Since the actual merging takes place at run time, you are simply placing references to other projects inside a master project (the master project does not actually contain the sub-project). Where are these references placed? You insert each reference in the master project's table of contents, placing it where you want the sub-project's TOC to appear.
Alternatively, it works to simply add the "child" help file as a Baggage File.
An any case, I searched through our help projects once again and could not find a single keyword that is saved in a help topic. They are ALL defined in HHK files. On the other hand, there are thousands of keywords, so I guess I could have missed one....
But whatever -- as long as the merge is working...
What doesn't work is saving keywords in topics that are then imported to another project or translated to another language. I sincerely hope that MM will do something about these problems in the upcoming release. At the very least, they need to correct the Help so that others aren't led down this road in vain.
/Eileen
RoboHelp Documentation
Download Adobe RoboHelp
