17 Replies Latest reply on May 30, 2012 8:10 PM by Charles VW
    Audition CS5.5 Crashes Immediately After Start-Up.
    Tim RG
      Hello,
      I'm running Audition off a MacBook Pro Version 10.6.6 -- immediately after attempted start-up and I receive a message informing me that the application has quit unexpectedly. I attempt to reopen the application but to no avail. Any suggestions?
        • 1. Re: Audition CS5.5 Crashes Immediately After Start-Up.
          Charles VW Adobe Employee
          Rename the following folder to something else (e.g. "4.0_backup").   This will simulate clearing your preferences
          ~/Library/Preferences/Adobe/Audition/4.0
          Launch Audition, and then post what is in the "Audition Log.txt" file that is created in the new 4.0 folder that will be created the next time you launch Audition.
          You also didn't mention if this has always happened since you installed and activated the product, or if it started after something else.
          • 2. Re: Audition CS5.5 Crashes Immediately After Start-Up.
            Tim RG Level 1
            This was a problem that only started today. Prior, however, it would crash when I attempted to change from Waveform View to Multitrack View or when running CPU intensive or High Latency effects. Everything works fine now. Thanks,
            Tim
            • 3. Re: Audition CS5.5 Crashes Immediately After Start-Up.
              Glad to hear you're up and running again.   The method I outlined above is sort of an all or nothing sledgehammer move.   In the future, you may wish to hold the [ Shift ] key while starting Audition as that will "ignore" any previous preferences upon startup.
              However, if it does happen again, I'd like to work with you to figure out the actual cause, because if we can narrow it down, we can figure out some other behavior in the future than whatever is crashing it right now.   Be sure to send in those crash logs with comments...
              • 4. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                HIeuLQ Level 1
                Hello. My Audition can not start. Please help me
                Here is the log file
                Log file created: 10/16/2011 8:24:39 PM
                Ticks = 0      <4132> <AuLog.Startup> <5> Application: Audition
                Ticks = 0      <4132> <AuLog.Startup> <5> Version 4.0
                Ticks = 16      <4132> <AuLog.Startup> <5> Build: 1815
                Ticks = 218      <4132> <AuLog.Startup> <5> AuUI initialization sequence started...
                Ticks = 218      <4132> <AuLog.Startup> <5> Initializing Crash Recovery
                Ticks = 234      <4132> <AuLog.Startup> <5> Initializing AuDSP
                Ticks = 250      <4132> <AuLog.Startup> <5> Initializing AuBackEnd
                Ticks = 312      <4132> <AuLog.Startup> <5> Initializing AuApplication
                Ticks = 312      <4132> <AuLog.Startup> <5> AuApplication initialization sequence started...
                Ticks = 312      <4132> <AuLog.Startup> <5> Initializing XML Loader
                Ticks = 359      <4132> <AuLog.Startup> <5> Initializing Application Settings
                Ticks = 359      <4132> <AuLog.Startup> <5> Intializing dva unit test and console
                Ticks = 359      <4132> <AuLog.Startup> <5> Initializing Audio Device
                Ticks = 452      <4132> <AuLog.Startup> <5> Initializing XMP System
                Ticks = 468      <4132> <AuLog.Startup> <5> Initializing AMIO Host
                Ticks = 468      <4132> <AuLog.Startup> <5> AMIO Host initialization sequence started...
                Ticks = 484      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
                Ticks = 515      <4132> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
                Ticks = 530      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
                Ticks = 593      <4132> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
                Ticks = 640      <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000  AIFF (Apple/SGI) aiff
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020012      IMA ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020020      GSM 6.10
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020040      12 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020041      16 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020042      24 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000  AU (Sun/NeXT) au
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030030      32kbs G721 ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030031      24kbs G723 ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000  AVR (Audio Visual Research) avr
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000  CAF (Apple Core Audio File) caf
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000  FLAC (FLAC Lossless Audio Codec) flac
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000  HTK (HMM Tool Kit) htk
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00100002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000  IFF (Amiga IFF/SVX8/SV16) iff
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000  MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000  MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000  MPC (Akai MPC 2k) mpc
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00210002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000  OGG (OGG Container format) oga
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00200060      Vorbis
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000  PAF (Ensoniq PARIS) paf
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000  PVF (Portable Voice Format) pvf
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000  RAW (header-less) raw
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040020      GSM 6.10
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040040      12 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040041      16 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040042      24 bit DWVW
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040021      VOX ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000  RF64 (RIFF 64) rf64
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000  SD2 (Sound Designer II) sd2
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000  SDS (Midi Sample Dump Standard) sds
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110001      Signed 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000  SF (Berkeley/IRCAM/CARL) sf
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000  VOC (Creative Labs) voc
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000  W64 (SoundFoundry WAVE 64) w64
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0012      IMA ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0013      Microsoft ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0020      GSM 6.10
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000  WAV (Microsoft) wav
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010002      Signed 16 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010003      Signed 24 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010004      Signed 32 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010005      Unsigned 8 bit PCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010006      32 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010007      64 bit float
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010010      U-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010011      A-Law
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010012      IMA ADPCM
                Ticks = 655      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010013      Microsoft ADPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010020      GSM 6.10
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010030      32kbs G721 ADPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000  WAV (NIST Sphere) wav
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070001      Signed 8 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070002      Signed 16 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070003      Signed 24 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070004      Signed 32 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070010      U-Law
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070011      A-Law
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000  WAVEX (Microsoft) wav
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130002      Signed 16 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130003      Signed 24 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130004      Signed 32 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130005      Unsigned 8 bit PCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130006      32 bit float
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130007      64 bit float
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130010      U-Law
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130011      A-Law
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130012      IMA ADPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130013      Microsoft ADPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130020      GSM 6.10
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130030      32kbs G721 ADPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000  WVE (Psion Series 3) wve
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00190011      A-Law
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000  XI (FastTracker 2) xi
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0051      16 bit DPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0050      8 bit DPCM
                Ticks = 671      <4132> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
                Ticks = 671      <4132> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
                Ticks = 671      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
                Ticks = 796      <4132> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
                Ticks = 811      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
                Ticks = 811      <4132> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
                Ticks = 827      <4132> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
                Ticks = 827      <4132> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
                Ticks = 842      <4132> <AuLog.Startup> <5> Session Host initialization sequence started...
                Ticks = 858      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
                Ticks = 967      <4132> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
                Ticks = 967      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
                Ticks = 1045      <4132> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
                Ticks = 1045      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
                Ticks = 1154      <4132> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
                Ticks = 1170      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
                Ticks = 1217      <4132> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
                Ticks = 1217      <4132> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
                Ticks = 1279      <4132> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
                Ticks = 1279      <4132> <AuLog.Startup> <5> Session Host initialization sequence complete.
                Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Clipboard Manager
                Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Preset Manager
                Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing Favorites Manager
                Ticks = 1310      <4132> <AuLog.Startup> <5> AuApplication initialization sequence complete.
                Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing AsyncQueueManager
                Ticks = 1310      <4132> <AuLog.Startup> <5> Initializing AuUI
                Ticks = 1732      <4132> <AuLog.Startup> <5> Initializing AuScripting
                Ticks = 1747      <4132> <AuLog.Startup> <5> Setting up temp directories
                Ticks = 2184      <4132> <AuLog.Startup> <5> AuUI initialization sequence complete.
                • 5. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                  HIeuLQ Level 1
                  I use Window 64 bit and this is Audition CS5, slash window appear and program die immediately.
                  • 6. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                    Did you try the advice given above to ignore or remove your preferences?
                    %USERPROFILE%\AppData\Roaming\Adobe\Audition\4.0
                    Alternatively, try the methods in this FAQ to provide more context.
                    • 7. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                      HIeuLQ Level 1
                      Yup, I tried this. But then it still crash.   I just did nothing. Install trial version, open it and it stop immediately.
                      • 8. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                        • 9. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                          rossnano
                          Audition crashes upon startup ever since I installed it.  Tried above methods and the alternative FAQ, but nothing has worked.
                          Here is the log.
                          Log file created: 10/24/2011 12:32:40 AM
                          Ticks = 15      <2584> <AuLog.Startup> <5> Application: Audition
                          Ticks = 15      <2584> <AuLog.Startup> <5> Version 4.0
                          Ticks = 15      <2584> <AuLog.Startup> <5> Build: 1815
                          Ticks = 140      <2584> <AuLog.Startup> <5> AuUI initialization sequence started...
                          Ticks = 140      <2584> <AuLog.Startup> <5> Initializing Crash Recovery
                          Ticks = 140      <2584> <AuLog.Startup> <5> Initializing AuDSP
                          Ticks = 140      <2584> <AuLog.Startup> <5> Initializing AuBackEnd
                          Ticks = 218      <2584> <AuLog.Startup> <5> Initializing AuApplication
                          Ticks = 218      <2584> <AuLog.Startup> <5> AuApplication initialization sequence started...
                          Ticks = 218      <2584> <AuLog.Startup> <5> Initializing XML Loader
                          Ticks = 234      <2584> <AuLog.Startup> <5> Initializing Application Settings
                          Ticks = 234      <2584> <AuLog.Startup> <5> Intializing dva unit test and console
                          Ticks = 234      <2584> <AuLog.Startup> <5> Initializing Audio Device
                          Ticks = 359      <2584> <AuLog.Startup> <5> Initializing XMP System
                          Ticks = 359      <2584> <AuLog.Startup> <5> Initializing AMIO Host
                          Ticks = 359      <2584> <AuLog.Startup> <5> AMIO Host initialization sequence started...
                          Ticks = 374      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioAiff
                          Ticks = 374      <2584> <AuLog.Plug-in> <5> Audition AIFF Amio plug-in. ID: 775c126d-5387-4af8-aa44-2209d40b102a
                          Ticks = 374      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioLSF
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Loading libsndfile...
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00020000  AIFF (Apple/SGI) aiff
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020012      IMA ADPCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020020      GSM 6.10
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020040      12 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020041      16 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00020042      24 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00030000  AU (Sun/NeXT) au
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030030      32kbs G721 ADPCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00030031      24kbs G723 ADPCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00120000  AVR (Audio Visual Research) avr
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00120005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00180000  CAF (Apple Core Audio File) caf
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00180011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00170000  FLAC (FLAC Lossless Audio Codec) flac
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00170003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00100000  HTK (HMM Tool Kit) htk
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00100002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00060000  IFF (Amiga IFF/SVX8/SV16) iff
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00060002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000c0000  MAT4 (GNU Octave 2.0 / Matlab 4.2) mat
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000c0007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000d0000  MAT5 (GNU Octave 2.1 / Matlab 5.0) mat
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000d0007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00210000  MPC (Akai MPC 2k) mpc
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00210002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00200000  OGG (OGG Container format) oga
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00200060      Vorbis
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00050000  PAF (Ensoniq PARIS) paf
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00050004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000e0000  PVF (Portable Voice Format) pvf
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000e0004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00040000  RAW (header-less) raw
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040020      GSM 6.10
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040040      12 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040041      16 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040042      24 bit DWVW
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00040021      VOX ADPCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00220000  RF64 (RIFF 64) rf64
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220007      64 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00220011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00160000  SD2 (Sound Designer II) sd2
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00160003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00110000  SDS (Midi Sample Dump Standard) sds
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110001      Signed 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00110003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000a0000  SF (Berkeley/IRCAM/CARL) sf
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000a0011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00080000  VOC (Creative Labs) voc
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080010      U-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00080011      A-Law
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000b0000  W64 (SoundFoundry WAVE 64) w64
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0002      Signed 16 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0003      Signed 24 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0004      Signed 32 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0005      Unsigned 8 bit PCM
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0006      32 bit float
                          Ticks = 374      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0007      64 bit float
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0010      U-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0011      A-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0012      IMA ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0013      Microsoft ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000b0020      GSM 6.10
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00010000  WAV (Microsoft) wav
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010002      Signed 16 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010003      Signed 24 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010004      Signed 32 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010005      Unsigned 8 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010006      32 bit float
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010007      64 bit float
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010010      U-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010011      A-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010012      IMA ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010013      Microsoft ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010020      GSM 6.10
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00010030      32kbs G721 ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00070000  WAV (NIST Sphere) wav
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070001      Signed 8 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070002      Signed 16 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070003      Signed 24 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070004      Signed 32 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070010      U-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00070011      A-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00130000  WAVEX (Microsoft) wav
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130002      Signed 16 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130003      Signed 24 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130004      Signed 32 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130005      Unsigned 8 bit PCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130006      32 bit float
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130007      64 bit float
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130010      U-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130011      A-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130012      IMA ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130013      Microsoft ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130020      GSM 6.10
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00130030      32kbs G721 ADPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 00190000  WVE (Psion Series 3) wve
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 00190011      A-Law
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile major type: 000f0000  XI (FastTracker 2) xi
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0051      16 bit DPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> Libsndfile  subformat: 000f0050      8 bit DPCM
                          Ticks = 390      <2584> <AuLog.Plug-in.AmioLSF> <5> libsndfile version detected: libsndfile-1.0.23
                          Ticks = 390      <2584> <AuLog.Plug-in> <5> Audition libsndfile Amio plug-in. ID: caf0f3de-96be-4e2f-85a7-ac6e61310fcb
                          Ticks = 390      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioMp3
                          Ticks = 390      <2584> <AuLog.Plug-in> <5> Audition Mp3 Amio plug-in. ID: ea4740a7-e67e-4070-bed8-3bd3727779db
                          Ticks = 390      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioQT
                          Ticks = 827      <2584> <AuLog.Plug-in> <5> Quicktime version detected: 0x07698000 7.6.9
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smi
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wav
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
                          Ticks = 858      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gp2
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp2
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3g2
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: 3gpp
                          Ticks = 873      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aifc
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: aiff
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: fli
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/flc
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime extension: flc,fli
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: giff
                          Ticks = 889      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
                          Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: gsm
                          Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-gsm
                          Ticks = 905      <2584> <AuLog.Plug-in> <5> Quicktime extension: gsm
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpeg
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mpeg
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-mpeg
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1v,m1a,m75,m15,mpm,mpv,mpa
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mpeg,mpg,m1s,m1a,mpm,mpa
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: midi
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/midi
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-midi
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: midi,mid,smf,kar
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mp3
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp3
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mp3
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpeg3
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpeg3
                          Ticks = 920      <2584> <AuLog.Plug-in> <5> Quicktime extension: mp3
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: pict
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: smil
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/smil
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mpegurl
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-mpegurl
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: smi,smil,sml
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: m3u,m3url
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sd2f
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-sd2
                          Ticks = 936      <2584> <AuLog.Plug-in> <5> Quicktime extension: sd2
                          Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: text
                          Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
                          Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ulaw
                          Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/basic
                          Ticks = 951      <2584> <AuLog.Plug-in> <5> Quicktime extension: au,snd,ulw
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: vfw
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-msvideo
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/avi
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/msvideo
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: avi,vfw
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: wave
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/wav
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-wav
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: wav,bwf
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: ac3
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/ac3
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-ac3
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: ac3
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: adts
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aac
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aac
                          Ticks = 967      <2584> <AuLog.Plug-in> <5> Quicktime extension: aac
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amc
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-mpeg
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: amr
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/AMR
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: amr
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: caff
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-caf
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: caf
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: cdda
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/aiff
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/x-aiff
                          Ticks = 983      <2584> <AuLog.Plug-in> <5> Quicktime extension: aiff,aif,aifc,cdda
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: celp
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/vnd.qcelp
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime extension: qcp
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: dvc
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/x-dv
                          Ticks = 998      <2584> <AuLog.Plug-in> <5> Quicktime extension: dv,dif
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: grip
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-sgi
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-photoshop
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-bmp
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/vnd.fpx
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/gif
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jpeg2000-image
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-jpeg2000-image
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/jp2
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pjpeg
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-macpaint
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/pict
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-pict
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/png
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-png
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-quicktime
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-targa
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/tiff
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: image/x-tiff
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: mpg4
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/mp4
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: audio/mp4
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime extension: mp4,mpg4
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: qhtm
                          Ticks = 1092      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/x-html-insertion
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: rtsp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-rtsp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/sdp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: application/x-sdp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: sdv
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: video/3gpp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime extension: 3gp
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime component main extension: utxt
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Quicktime mime type: text/plain
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Audition QuickTime Amio plug-in. ID: 01914214-f044-47f7-a43b-5e98267fafd0
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Loading AMIO plug-in: AmioWav
                          Ticks = 1107      <2584> <AuLog.Plug-in> <5> Audition Wave Amio plug-in. ID: 60df8553-00c8-4fd7-8a07-6f25e30ab79c
                          Ticks = 1107      <2584> <AuLog.Startup> <5> AMIO Host initialization sequence complete.
                          Ticks = 1123      <2584> <AuLog.Startup> <5> Session Host initialization sequence started...
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: FinalCutXML
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> FCP XML session plug-in. ID: 611577b8-4c4f-4253-a29d-f01516cdeb90
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: LegacyXML
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> Audition 3.0 XML session plug-in. ID: da4b6774-0370-4c6d-912b-bd0e3a763ef8
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: OmfSession
                          Ticks = 1139      <2584> <AuLog.Plug-in> <5> DQ OMF PLug-In. ID: 94debb27-326b-4457-92ba-84d6e6f75567
                          Ticks = 1154      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: PremiereProInterchange
                          Ticks = 1154      <2584> <AuLog.Plug-in> <5> Adobe Premiere Pro to Audition XML session interchange plug-in. ID: d22d3d0c-2f52-4651-bd94-f73eb80b7e2c
                          Ticks = 1154      <2584> <AuLog.Plug-in> <5> Loading Session plug-in: SesxNative
                          Ticks = 1154      <2584> <AuLog.Plug-in> <5> Audition Sesx plug-in. ID: e4fe4447-02d0-44c6-90c8-89d5083fcd26
                          Ticks = 1154      <2584> <AuLog.Startup> <5> Session Host initialization sequence complete.
                          Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Clipboard Manager
                          Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Preset Manager
                          Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing Favorites Manager
                          Ticks = 1154      <2584> <AuLog.Startup> <5> AuApplication initialization sequence complete.
                          Ticks = 1154      <2584> <AuLog.Startup> <5> Initializing AsyncQueueManager
                          Ticks = 1170      <2584> <AuLog.Startup> <5> Initializing AuUI
                          Ticks = 1388      <2584> <AuLog.Startup> <5> Initializing AuScripting
                          Ticks = 1388      <2584> <AuLog.Startup> <5> Setting up temp directories
                          • 10. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                            Here is the log.
                            I don't think you tried what was requested in the FAQ, because you've not posted the crash dump or system information that was requested in the FAQ.  Instead, you posted the Audition Log file, which is usually helpful, but not in this situation.  Also, the steps mentioned in the FAQ won't stop your crash, it will only help you get us the information we need to figure out what the crash is.  I'd first try to delete your preferences folder.
                            • 11. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                              HarryykC
                              hello, please help me, i dont know how to solve this problem. Audition CS5.5 crashes to after start-up.
                              system information
                              Hardware Overview:
                                Model Name:          MacBook
                                Model Identifier:          MacBook6,1
                                Processor Name:          Intel Core 2 Duo
                                Processor Speed:          2.26 GHz
                                Number of Processors:          1
                                Total Number of Cores:          2
                                L2 Cache:          3 MB
                                Memory:          4 GB
                                Bus Speed:          1.07 GHz
                                Boot ROM Version:          MB61.00C8.B00
                                SMC Version (system):          1.51f53
                                Serial Number (system):          45012Q3H8PW
                                Hardware UUID:          83B15CC5-50FA-53F9-ABB2-9F4CDF9BE254
                                Sudden Motion Sensor:
                                State:          Enabled
                              problem detail and system configration
                              Process:         Adobe Audition [3829]
                              Path:            /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
                              Identifier:      com.adobe.Audition.4.0
                              Version:         4.0x1815 (4.0)
                              Code Type:       X86 (Native)
                              Parent Process:  launchd [156]
                              Date/Time:       2011-10-25 00:28:01.532 +0800
                              OS Version:      Mac OS X 10.7.2 (11C74)
                              Report Version:  9
                              Interval Since Last Report:          199872 sec
                              Crashes Since Last Report:           71
                              Per-App Interval Since Last Report:  168 sec
                              Per-App Crashes Since Last Report:   40
                              Anonymous UUID:                      913EA101-2C51-460B-A86C-99F2C6F9883B
                              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                              Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                              Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
                              VM Regions Near 0:
                              --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
                                  __TEXT                 0000000000001000-0000000000003000 [    8K] r-x/rwx SM=COW  /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
                              Application Specific Information:
                              objc[3829]: garbage collection is OFF
                              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                              0   org.perian                              0x0f3686cc 0xf226000 + 1320652
                              1   com.apple.CoreServices.CarbonCore          0x950fb5f5 CallComponent + 223
                              2   com.apple.CoreServices.CarbonCore          0x950fb63e CallComponentDispatch + 29
                              3   com.apple.CoreServices.CarbonCore          0x95167898 CallComponentOpen + 43
                              4   com.apple.CoreServices.CarbonCore          0x950fa2b4 OpenAComponent + 426
                              5   com.apple.CoreServices.CarbonCore          0x950fa334 OpenComponent + 24
                              6   com.apple.CoreServices.CarbonCore          0x950fb57c CallComponent + 102
                              7   com.apple.CoreServices.CarbonCore          0x950fb63e CallComponentDispatch + 29
                              8   com.apple.QuickTime                     0x9af104a0 MovieImportGetMIMETypeList + 43
                              9   com.adobe.AmioQT.bundle                 0x0b8a593b amio::qt::QueryExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> > const*, bool, ComponentDescription) + 283
                              10  com.adobe.AmioQT.bundle                 0x0b8a677b amio::qt::QueryImportExtensions(std::list<std::string, std::allocator<std::string> >&, std::list<std::string, std::allocator<std::string> >*, bool) + 107
                              11  com.adobe.AmioQT.bundle                 0x0b89ba0e amio::AmioQTInterface::GetAmioInfo(amio::AmioGetAmioInfoInterface&) + 398
                              12  com.adobe.AmioQT.bundle                 0x0b896b1a amio::AmioInterfaceTemplate<amio::qt::Source, amio::qt::Source>::EntryPoint(int, void*, void*) + 218
                              13  com.adobe.AmioQT.bundle                 0x0b895e69 AmioInterface + 57
                              14  com.adobe.aubackend.framework           0x01fe2c82 abe::AmioPlugin::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 482
                              15  com.adobe.aubackend.framework           0x01fdcb40 abe::AmioHost::Impl::LoadModule(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 576
                              16  com.adobe.aubackend.framework           0x01fe035f abe::AmioHost::Impl::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>&) + 2351
                              17  com.adobe.aubackend.framework           0x01fda611 abe::AmioHost::Initialize(std::list<abe::AmioInfo, std::allocator<abe::AmioInfo> > const*, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 33
                              18  AuApplication                           0x028c4f4a app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 3306
                              19  AuUI                                    0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace::Workspace*) + 2768
                              20  AuUI                                    0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Workspace*) + 28
                              21  AuUI                                    0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
                              22  com.adobe.exo.framework                 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
                              23  AuUI                                    0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
                              24  AuUI                                    0x03555c0f AudMacMain(int, char**) + 415
                              25  com.adobe.Audition.4.0                  0x00002ecd main + 93
                              26  com.adobe.Audition.4.0                  0x00002c66 start + 54
                              Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                              0   libsystem_kernel.dylib                  0x91a6890a kevent + 10
                              1   libdispatch.dylib                       0x9a3f1c58 _dispatch_mgr_invoke + 969
                              2   libdispatch.dylib                       0x9a3f06a7 _dispatch_mgr_thread + 53
                              Thread 2:
                              0   libsystem_kernel.dylib                  0x91a6802e __workq_kernreturn + 10
                              1   libsystem_c.dylib                       0x90266ccf _pthread_wqthread + 773
                              2   libsystem_c.dylib                       0x902686fe start_wqthread + 30
                              Thread 3:
                              Thread 4:
                              0   libsystem_kernel.dylib                  0x91a6783e __psynch_cvwait + 10
                              1   libsystem_c.dylib                       0x90268e78 _pthread_cond_wait + 914
                              2   libsystem_c.dylib                       0x9021082a pthread_cond_wait + 48
                              3   com.adobe.amt.services                  0x06765274 C_AMTUISwitchSuppressUpdates + 16864
                              4   com.adobe.amt.services                  0x0675e074 C_EULA_SetState + 2166
                              5   com.adobe.amt.services                  0x067652da C_AMTUISwitchSuppressUpdates + 16966
                              6   libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
                              7   libsystem_c.dylib                       0x902686de thread_start + 34
                              Thread 5:
                              1   libsystem_c.dylib                       0x90268e21 _pthread_cond_wait + 827
                              2   libsystem_c.dylib                       0x9021942c pthread_cond_wait$UNIX2003 + 71
                              3   com.apple.CoreServices.CarbonCore          0x95160f36 TSWaitOnCondition + 124
                              4   com.apple.CoreServices.CarbonCore          0x950d2579 TSWaitOnConditionTimedRelative + 136
                              5   com.apple.CoreServices.CarbonCore          0x95134755 MPWaitOnQueue + 200
                              6   com.adobe.dvacore.framework             0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
                              7   com.adobe.dvacore.framework             0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
                              8   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
                              9   com.adobe.dvacore.framework             0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
                              10  com.adobe.dvacore.framework             0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
                              11  com.adobe.boost_threads.framework          0x000566fd thread_proxy + 141
                              12  libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
                              13  libsystem_c.dylib                       0x902686de thread_start + 34
                              Thread 6:
                              Thread 7:
                              Thread 8:
                              Thread 9:
                              Thread 10:
                              Thread 11:
                              Thread 12:
                              Thread 13:
                              Thread 14:
                              Thread 15:
                              2   libsystem_c.dylib                       0x902193e0 pthread_cond_timedwait$UNIX2003 + 70
                              3   com.adobe.aubackend.framework           0x022bc600 abe::spectral::SpectralDataManager::Process() + 720
                              4   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
                              5   com.adobe.dvacore.framework             0x0013fa9a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
                              6   com.adobe.dvacore.framework             0x0013b89a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
                              7   com.adobe.dvacore.framework             0x000c7869 boost::function0<void>::operator()() const + 41
                              8   com.adobe.dvacore.framework             0x0013830d dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
                              9   com.adobe.dvacore.framework             0x00139200 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
                              10  com.adobe.boost_threads.framework          0x000566fd thread_proxy + 141
                              11  libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
                              12  libsystem_c.dylib                       0x902686de thread_start + 34
                              Thread 16:
                              2   libsystem_c.dylib                       0x90268f7b pthread_cond_timedwait_relative_np + 47
                              3   com.apple.CoreServices.CarbonCore          0x950d25a3 TSWaitOnConditionTimedRelative + 178
                              4   com.apple.CoreServices.CarbonCore          0x95134755 MPWaitOnQueue + 200
                              5   com.adobe.dvacore.framework             0x0013fa0a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
                              Thread 17:: com.apple.audio.IOThread.client
                              0   libsystem_kernel.dylib                  0x91a65c22 mach_msg_trap + 10
                              1   libsystem_kernel.dylib                  0x91a651f6 mach_msg + 70
                              2   com.apple.audio.CoreAudio               0x911d49fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
                              3   com.apple.audio.CoreAudio               0x911d4a6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
                              4   com.apple.audio.CoreAudio               0x911cce5f HALC_ProxyIOContext::IOWorkLoop() + 1145
                              5   com.apple.audio.CoreAudio               0x911cc926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
                              6   com.apple.audio.CoreAudio               0x911cc898 __HALC_ProxyIOContext_block_invoke_6 + 20
                              7   com.apple.audio.CoreAudio               0x911cc81d HALB_IOThread::Entry(void*) + 69
                              8   libsystem_c.dylib                       0x90264ed9 _pthread_start + 335
                              9   libsystem_c.dylib                       0x902686de thread_start + 34
                              Thread 0 crashed with X86 Thread State (32-bit):
                                eax: 0x00000000  ebx: 0x00000000  ecx: 0x069b3600  edx: 0x000000ef
                                edi: 0x0f2290a7  esi: 0xbfffe1b8  ebp: 0xbfffe178  esp: 0xbfffe15c
                                 ss: 0x00000023  efl: 0x00010286  eip: 0x0f3686cc   cs: 0x0000001b
                                 ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                                cr2: 0x00000000
                              Logical CPU: 0
                              Binary Images:
                                  0x1000 -     0x2ff7 +com.adobe.Audition.4.0 (4.0x1815 - 4.0) <85E5CFCF-9F35-62E7-FBB0-A9D784065AAA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/MacOS/Adobe Audition
                                  0x8000 -     0xcffc +com.adobe.AdobeCrashReporter (2.5 - 3.0.20090403) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
                                 0x13000 -    0x2ffd7 +com.adobe.LogTransport (1.0 - 1.0) /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
                                 0x3b000 -    0x41fef +com.adobe.boost_date_time.framework (boost_date_time version 5.5.0 - 5.5.0.11) <65EA5634-E68B-A458-36E5-1CE41C510FE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                 0x54000 -    0x5bff2 +com.adobe.boost_threads.framework (boost_threads version 5.5.0 - 5.5.0.11) <BA76B8DD-DD46-9677-BC27-2263B3F6C1C2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                 0x6c000 -    0x76ffd +com.adobe.boost_signals.framework (boost_signals version 5.5.0 - 5.5.0.11) <BF2FB70C-B5C6-8895-7F49-A958252FE8AD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                 0x8a000 -    0x8bffb +com.adobe.boost_system.framework (boost_system version 5.5.0 - 5.5.0.11) <BF82B35F-D3C0-33A9-FEA0-726282D735EA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                 0x94000 -   0x221fe7 +com.adobe.dvacore.framework (dvacore version 5.5.0 - 5.5.0.11) <B4D76A59-D111-D6BB-5628-4A323BB85052> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                0x3a5000 -   0x707fe7 +com.adobe.dvaui.framework (dvaui version 5.5.0 - 5.5.0.11) <67D7F0B7-A688-3BEB-F0DA-75C9E4387838> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                0xab7000 -   0xe34ff3 +com.adobe.dvaadameve.framework (dvaadameve version 5.5.0 - 5.5.0.11) <D61819DB-66CC-348F-3902-BC814A3A4A14> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                              0x13b1000 -  0x145efff +com.adobe.dvaworkspace.framework (dvaworkspace version 5.5.0 - 5.5.0.11) <A7558000-BC03-A56D-FB8B-50357B11D002> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                              0x1534000 -  0x1556ff7 +com.adobe.dvamediatypes.framework (dvamediatypes version 5.5.0 - 5.5.0.11) <BA4829C9-AA08-55B0-0C65-CAABBDE0570E> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                              0x1578000 -  0x15d8fff +com.adobe.dvametadata.framework (dvametadata version 5.5.0 - 5.5.0.11) <177F1AC0-7356-003C-3A1B-932D6AFCD109> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                              0x1664000 -  0x16bcff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.2 -c 3 - 61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                              0x16cc000 -  0x1772ff3 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.2 -f 17 - 61.141987) <963C6B68-E97E-A983-A716-6A8FA37E9D2D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                              0x17b0000 -  0x1842fff +com.adobe.dvametadataUI.framework (dvametadataUI version 5.5.0 - 5.5.0.11) <ADF2FFAD-9BB9-D293-6E0F-65D730C1149D> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvametadataui.framework/Versions/A/dvametadataUI
                              0x18de000 -  0x1927fff +com.adobe.dvatemporalxmp.framework (dvatemporalxmp version 5.5.0 - 5.5.0.11) <5E7D6AE9-B564-573D-A87E-856AB21CBE72> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                              0x194a000 -  0x19f4fff +com.adobe.exo.framework (exo version 5.5.0 - 5.5.0.11) <CD97F7C6-68E8-A72F-9CF3-41875F43B537> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
                              0x1af2000 -  0x1b10ff3 +com.adobe.dvaunittesting.framework (dvaunittesting version 5.5.0 - 5.5.0.11) <2A5C3BEA-D80D-1838-0561-5E4167362226> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                              0x1b3c000 -  0x1b47fff +com.adobe.aucore.framework (1.0 - 1.0) <A59255F4-FF8E-6362-0321-66A358A85AC0> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
                              0x1b55000 -  0x1ccdfe2 +com.adobe.audsp.framework (1.0 - 1.0) <26B5FE57-0462-24C2-A141-50F0A8585AE2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
                              0x1d3f000 -  0x1ec0fff +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <1E99D19B-F863-7356-1152-AEE3CC79A790> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
                              0x1fcb000 -  0x2359fef +com.adobe.aubackend.framework (1.0 - 1.0) <F772F4E9-DFF6-B6FF-F0FC-D8A58B2D7A2B> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
                              0x268c000 -  0x2693fff +com.adobe.dvaundo.framework (dvaundo version 5.5.0 - 5.5.0.11) <EB63E6D5-2B66-B9CE-2537-49F04A2E2546> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
                              0x26a0000 -  0x2a04feb +AuApplication (??? - ???) <6EC48FB1-D2E9-C93B-BCDA-56B5E3970DE5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
                              0x2d00000 -  0x2de8feb +com.adobe.auuitoolkit.framework (1.0 - 1.0) <809291B6-2082-44FB-1FE9-6209B34CB819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
                              0x2f39000 -  0x2fd8ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.15.1 - 4.15.1.10952) <08C05DF9-BC45-17F2-6797-6E46C1528565> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                              0x303f000 -  0x30d1fe3 +com.adobe.AdobeScCore (ScCore 4.15.1 - 4.15.1.10952) <393EE4DF-20CE-C83C-F22C-CE5C06DCB858> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                              0x311e000 -  0x322effb +com.adobe.auscripting.framework (1.0 - 1.0) <86C73976-B283-7E91-05B9-10F72115B56F> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
                              0x33bb000 -  0x342afff +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <F82A50BC-6CD1-6FAC-642E-C04EB82CD0BF> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponen tsUI
                              0x34cb000 -  0x3e5cfef +AuUI (??? - ???) <6A6C3DBD-AADA-8A6C-3C92-FC8E0BD5D796> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
                              0x47a7000 -  0x47e4fff  com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                              0x47fe000 -  0x486bffb  com.apple.CoreSymbolication (2.1 - 71) <442A5CD4-9820-3BB2-BD68-D8AB94010E34> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                              0x48a6000 -  0x490bffb  com.apple.Symbolication (1.2 - 89) <AB71058E-7106-3D01-8EF9-5F9FEF950D6E> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                              0x4937000 -  0x496efef  com.apple.DebugSymbols (2.1 - 87) <E2E26B90-BC10-304A-AF1B-8E5CCA9776A7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                              0x4987000 -  0x4991ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                              0x49a6000 -  0x4a23fe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                              0x4a8a000 -  0x4b5efef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                              0x4c5b000 -  0x4c87ff3  com.apple.audio.CoreAudioKit (1.6.2 - 1.6.2) <9376552A-AFDD-368A-AF35-65A2D6F5DF8E> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                              0x4c9a000 -  0x4d303a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
                              0x4d6d000 -  0x4dc3ffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                              0x4e0c000 -  0x509afec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
                              0x521d000 -  0x52caff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
                              0x530f000 -  0x5432ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                              0x5455000 -  0x5b2fff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                              0x5bf4000 -  0x5c11ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                              0x5c18000 -  0x5c3effb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                              0x5c45000 -  0x5f74ff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                              0x5fc6000 -  0x6034ffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                              0x604b000 -  0x604ffff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                              0x605a000 -  0x605dffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                              0x63da000 -  0x63e2fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              0x6740000 -  0x67abfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                              0x67e7000 -  0x67ebffb  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                              0x67f0000 -  0x67f6ffb  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                              0x8795000 -  0x8805feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              0x8b97000 -  0x8bc0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                              0x8e0c000 -  0x8e0dff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                              0xb3d3000 -  0xb3eafff +com.adobe.AmioAiff.bundle (1.0 - 1.0) <8DD42393-CA20-52FD-E73B-735A39AFD2A9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioAiff.bundle/Contents/MacOS/AmioAiff
                              0xb404000 -  0xb44dff7 +com.adobe.AmioLSF.bundle (1.0 - 1.0) <DD4C303E-2964-374C-FCE4-B5053A976327> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/MacOS/AmioLSF
                              0xb482000 -  0xb4e0ff3 +libsndfile.1.dylib (2.23.0 - compatibility 2.0.0) <832BFA9E-FE6D-3C12-9B61-E8CBC29CD963> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libsndfile.1.dylib
                              0xb502000 -  0xb546fef +libFLAC.8.2.0.dylib (11.0.0 - compatibility 11.0.0) <B5EF064F-745D-0D00-2FC4-B31A46971272> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libFLAC.8.2.0.dylib
                              0xb55c000 -  0xb6bbfeb +libvorbisenc.2.dylib (3.7.0 - compatibility 3.0.0) <93CE9300-8AB1-83A4-E20D-E7737DB97BA5> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbisenc.2.dylib
                              0xb700000 -  0xb726fea +libvorbis.0.dylib (5.4.0 - compatibility 5.0.0) <745A9A7D-4C43-6B9A-FFCF-773BFD318C05> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libvorbis.0.dylib
                              0xb72f000 -  0xb731fe8 +libogg.0.dylib (8.0.0 - compatibility 8.0.0) <51B9D3BA-575C-C5A5-CD90-3AF66EB1BDF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioLSF.bundle/Contents/Libraries/libogg.0.dylib
                              0xb737000 -  0xb7e3fe6 +com.adobe.AmioMp3.bundle (1.0 - 1.0) <53405C96-BF4A-93D5-9ECE-3CD999E37DD6> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioMp3.bundle/Contents/MacOS/AmioMp3
                              0xb892000 -  0xb8b2ff7 +com.adobe.AmioQT.bundle (1.0 - 1.0) <14050CEE-F059-C990-1515-0F419BBA3F46> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Amio Plug-Ins/AmioQT.bundle/Contents/MacOS/AmioQT
                              0xb9e5000 -  0xb9eefca +com.cod3r.ac3movieimport (1.7.1 - 1.7.1) /Library/QuickTime/AC3MovieImport.component/Contents/MacOS/AC3MovieImport
                              0xb9f3000 -  0xb9f3fff +com.adobe.SoundboothScoreAudioCodec (1.0 - 1.0) /Library/QuickTime/SoundboothScoreCodec.component/Contents/MacOS/SoundboothScoreCodec
                              0xba5d000 -  0xba5efff  com.apple.DVCPROHDVideoOutputCodec (1.2 - 1.2) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/DVCPROHDVideoOutputC odec
                              0xba62000 -  0xbad3fff +com.DivXInc.DivXDecoder (6.2.5 - 6.2.5) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
                              0xbae1000 -  0xbb31fff +com.DivXInc.DivXDecoder (6.0.5 - 6.0.5) /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
                              0xeb2d000 -  0xed20ff7 +net.telestream.wmv.import (2.1.0.33 - 2.1.0.33) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
                              0xf01d000 -  0xf153ff7  com.apple.QuickTimeStreaming.component (7.7.1 - 2306) <AA9E0B70-CC52-34D7-AF42-1D36708CF31B> /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
                              0xf1b7000 -  0xf20affb  com.apple.QuickTimeMPEG.component (7.7.1 - 2306) <29532A45-677C-3381-AC08-919365E64EA9> /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/QuickTimeMPEG
                              0xf21e000 -  0xf220ffd  com.apple.PDFImporter (2.2 - ???) <4F3BD14A-F40E-3469-81AC-FFBCF5E66F3B> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
                              0xf226000 -  0xf37efef +org.perian (??? - 0.5) /Library/QuickTime/Perian.component/Contents/MacOS/Perian
                              0x8feba000 - 0x8feec9c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
                              0x90208000 - 0x902d3fff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
                              0x902d4000 - 0x90426fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                              0x90479000 - 0x90479fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                              0x9047a000 - 0x9050eff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                              0x9093c000 - 0x90994fff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                              0x90995000 - 0x9099affd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                              0x90ee1000 - 0x90f03ff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                              0x90fe1000 - 0x911b7fe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                              0x911b8000 - 0x91219ffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                              0x91297000 - 0x9129fff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
                              0x912a0000 - 0x912defff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                              0x91739000 - 0x9173bff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
                              0x9174c000 - 0x9174dff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
                              0x9174e000 - 0x919c1fff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                              0x91a12000 - 0x91a4efff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
                              0x91a4f000 - 0x91a6dff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
                              0x91aed000 - 0x91aedfff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
                              0x91aee000 - 0x91b5dfff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                              0x91b5f000 - 0x91bc1ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                              0x91c0d000 - 0x91c23ffe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
                              0x91c24000 - 0x91c25ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
                              0x91c26000 - 0x91c31fff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
                              0x91c3c000 - 0x91c58ff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                              0x91cab000 - 0x91cadffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                              0x91cae000 - 0x91e0fffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                              0x91e10000 - 0x91e10fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                              0x91e6b000 - 0x91e73ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
                              0x91e7a000 - 0x91e7bff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
                              0x91eee000 - 0x91ef4ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                              0x91ef5000 - 0x91f24ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
                              0x92299000 - 0x9229afff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
                              0x9229b000 - 0x922a6ffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                              0x922a7000 - 0x9233eff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                              0x9264c000 - 0x92669ff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                              0x9266a000 - 0x9266dff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <B9344DE6-B84D-352C-95AD-EF73A68B8A10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                              0x926b1000 - 0x926bcff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                              0x926df000 - 0x92713ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
                              0x9271a000 - 0x92829ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                              0x9293a000 - 0x92becff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
                              0x92bed000 - 0x92bf3ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                              0x92bf4000 - 0x92da8ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
                              0x93580000 - 0x93587ff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
                              0x93588000 - 0x9360ffff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                              0x93621000 - 0x93643ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                              0x93644000 - 0x93645fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
                              0x93646000 - 0x9373eff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                              0x93741000 - 0x937cbffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                              0x9384d000 - 0x93894fff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                              0x938f2000 - 0x939e2ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
                              0x939e3000 - 0x93b03fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                              0x93b04000 - 0x93b0eff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                              0x93b14000 - 0x93b16ff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                              0x93e5a000 - 0x93e61ffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                              0x93e62000 - 0x93f22ff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                              0x93f23000 - 0x9400bfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
                              0x94038000 - 0x94074ffd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                              0x94083000 - 0x94094fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
                              0x94095000 - 0x94095ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
                              0x94096000 - 0x94156fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                              0x9418e000 - 0x94232fff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                              0x9440f000 - 0x9446cffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                              0x9446d000 - 0x94490fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                              0x945a9000 - 0x945b2ff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                              0x945b3000 - 0x945bbff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
                              0x94678000 - 0x9469dff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                              0x946c7000 - 0x9472bfff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                              0x947ba000 - 0x947fbff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <975E4F25-7943-3785-849C-244FF4E77602> /usr/lib/libcurl.4.dylib
                              0x947fc000 - 0x94824ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
                              0x94825000 - 0x94828ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
                              0x94829000 - 0x9482affd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                              0x9482b000 - 0x9483bfff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
                              0x9483c000 - 0x9483fffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                              0x94cd4000 - 0x94cd4fff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                              0x94cd5000 - 0x94d2effb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                              0x94d2f000 - 0x94e43ff3  com.apple.QuickTimeImporters.component (7.7.1 - 2306) <393FD879-F626-3FB2-9866-9E6B122BD64F> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
                              0x94e90000 - 0x94fbcff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                              0x94fbd000 - 0x95093a5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
                              0x95094000 - 0x95396fff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                              0x953df000 - 0x953fcfff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
                              0x953fd000 - 0x9544dfff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                              0x95604000 - 0x95944ffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                              0x95a0c000 - 0x95a5dff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                              0x95a5e000 - 0x95a73ff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                              0x95b09000 - 0x95b14ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                              0x95b15000 - 0x95b15fff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                              0x95b5b000 - 0x95b7afff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                              0x95b7b000 - 0x95b7effd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                              0x95b7f000 - 0x95b86ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
                              0x95c03000 - 0x95c65ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
                              0x95c66000 - 0x95cdbfff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                              0x95d19000 - 0x95d1dfff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                              0x95d1e000 - 0x95db9ff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                              0x95dba000 - 0x95dd3fff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                              0x95e79000 - 0x95e8cffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                              0x95f0a000 - 0x95f0eff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
                              0x961ca000 - 0x961cbff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
                              0x96aa7000 - 0x96aacff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
                              0x96aad000 - 0x96ab0ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
                              0x96ab1000 - 0x96ab1ff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                              0x96ab2000 - 0x96ac6ff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                              0x96acd000 - 0x96adbfff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
                              0x96af4000 - 0x96af4ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                              0x96af5000 - 0x96afdfff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                              0x96b01000 - 0x96b0afff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
                              0x96b0b000 - 0x96b18fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                              0x96b19000 - 0x97194fe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                              0x97195000 - 0x9719cfff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                              0x9719d000 - 0x971cbfe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
                              0x971cc000 - 0x9720afff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                              0x9720b000 - 0x97225fff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                              0x97226000 - 0x97337ff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                              0x97338000 - 0x979e1eeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                              0x979e2000 - 0x979f2fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                              0x979f3000 - 0x97a29ff4  com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                              0x97b71000 - 0x97b9affe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                              0x97b9b000 - 0x97c00ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                              0x97fb7000 - 0x97fbbfff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                              0x98045000 - 0x98d95fff  com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
                              0x98d96000 - 0x98dd6ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
                              0x98dd7000 - 0x98e64fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                              0x98e65000 - 0x98e9bff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                              0x98e9c000 - 0x98e9dfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                              0x98e9e000 - 0x98eccff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                              0x98ecd000 - 0x991d7ff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                              0x9921a000 - 0x9921afff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                              0x9921b000 - 0x992eafff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                              0x99478000 - 0x998edff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                              0x9996b000 - 0x9996bfff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                              0x9996c000 - 0x99a7bff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
                              0x99a7c000 - 0x99a8cff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
                              0x99bbc000 - 0x99c37ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                              0x99c38000 - 0x99c60ff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                              0x99eab000 - 0x9a387ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                              0x9a3d5000 - 0x9a3e3fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                              0x9a3ef000 - 0x9a3fdfff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
                              0x9a3fe000 - 0x9ae8cffe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                              0x9aea6000 - 0x9b12bfe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                              0x9b12c000 - 0x9b193fff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
                              0x9b194000 - 0x9b1ddff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                              0x9b1de000 - 0x9b2c1ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
                              0x9b2c2000 - 0x9b305ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
                              0x9b446000 - 0x9b447fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
                              0x9b523000 - 0x9b573ff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                              0x9b7d8000 - 0x9b9c1ff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                              0x9ba3a000 - 0x9ba3effd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                              0x9ba3f000 - 0x9be41ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                              0x9bef1000 - 0x9bf7eff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                              0x9bf7f000 - 0x9bf82ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
                              0x9bf83000 - 0x9bfaefff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                              0x9bfaf000 - 0x9bfb3ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
                              0x9ca05000 - 0x9ca1afff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                              0x9cafd000 - 0x9cb01ff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                              0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                              External Modification Summary:
                                Calls made by other processes targeting this process:
                                  task_for_pid: 2
                                  thread_create: 0
                                  thread_set_state: 0
                                Calls made by this process:
                                  task_for_pid: 0
                                  thread_create: 0
                                  thread_set_state: 0
                                Calls made by all processes on this machine:
                                  task_for_pid: 6797
                                  thread_create: 0
                                  thread_set_state: 0
                              VM Region Summary:
                              ReadOnly portion of Libraries: Total=250.8M resident=138.7M(55%) swapped_out_or_unallocated=112.1M(45%)
                              Writable regions: Total=131.0M written=7932K(6%) resident=14.4M(11%) swapped_out=0K(0%) unallocated=116.6M(89%)
                              REGION TYPE                      VIRTUAL
                              (null) (reserved)                    40K        reserved VM address space (unallocated)
                              ATS (font support)                 32.2M
                              ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                              CG backing stores                   872K
                              CG raster data                      860K
                              CG shared images                   1256K
                              CoreGraphics                          8K
                              CoreServices                       4428K
                              MALLOC                             26.6M
                              MALLOC guard page                    32K
                              MALLOC_LARGE (reserved)            33.4M        reserved VM address space (unallocated)
                              Memory tag=242                       12K
                              Memory tag=243                        4K
                              Memory tag=249                      408K
                              Stack                              72.6M
                              VM_ALLOCATE                        17.0M
                              __CI_BITMAP                          80K
                              __DATA                             16.1M
                              __DATA/__OBJC                       112K
                              __IMAGE                            1256K
                              __IMPORT                            348K
                              __LINKEDIT                         78.1M
                              __OBJC                             1636K
                              __OBJC/__DATA                        48K
                              __PAGEZERO                            4K
                              __TEXT                            172.7M
                              __UNICODE                           544K
                              mapped file                       113.5M
                              shared memory                       364K
                              shared pmap                        9164K
                              TOTAL                             583.1M
                              TOTAL, minus reserved VM space    549.7M
                              Model: MacBook6,1, BootROM MB61.00C8.B00, 2 processors, Intel Core 2 Duo, 2.26 GHz, 4 GB, SMC 1.51f53
                              Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
                              Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                              Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.100.98.75.18)
                              Bluetooth: Version 4.0.1f4, 2 service, 11 devices, 1 incoming serial ports
                              Network Service: AirPort, AirPort, en1
                              Serial ATA Device: TOSHIBA MK2555GSXF, 250.06 GB
                              Serial ATA Device: MATSHITADVD-R   UJ-898
                              USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 2
                              USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0x04600000 / 2
                              USB Device: USB Optical Mouse, 0x046d  (Logitech Inc.), 0xc058, 0x06200000 / 3
                              USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
                              USB Device: Bluetooth Module, apple_vendor_id, 0x8218, 0x06130000 / 4
                              please help me, thank you very much
                              • 12. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                Charles VW Adobe Employee
                                By giving the information requested in the FAQ, I can now immediately see the problem:
                                Perian is crashing when QuickTime is asking it what it supports.  Please update Perian or uninstall it.   The reason why this is crashing Audition on startup is because on first launch we ask QuickTime which file extensions it supports (e.g. .mov, .aac, .mp4, etc).  In that process, QuickTime is in-turn, calling Perian (since you installed it) and asking Perian.  For some reason, this is crashing.
                                If you don't need QuickTime support in Audition, you can remove/rename the AmioQT.bundle from within the Adobe Audition CS5.5.app.
                                • 13. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                  HarryykC Level 1
                                  thank you very much, it work now
                                  • 14. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                    For the benefit of others that may come across this thread, what exactly did you do/change to get it to work?
                                    • 15. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                      HarryykC Level 1
                                      I removed perian and then intalled it, but audition not worked, so I renamed the file AmioQT.bundle,while it didnt work, then I removed it,and audition worked. Hope it useful for others
                                      • 16. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                        ographix Level 1
                                        Hey my audition crash when i open up today. it started up did it yesterday as well. please help.
                                        here a screen shot just before it crashes.
                                        here the crash report
                                        Process:         Adobe Audition [3158]
                                        Parent Process:  launchd [242]
                                        Date/Time:       2012-05-31 08:09:45.593 +0930
                                        OS Version:      Mac OS X 10.7.4 (11E53)
                                        Report Version:  9
                                        Interval Since Last Report:          2241 sec
                                        Per-App Interval Since Last Report:  57 sec
                                        Per-App Crashes Since Last Report:   7
                                        Anonymous UUID:                      4176F5F7-DB75-41E1-AEDB-0DE4B0F8FEE1
                                        Exception Type:  EXC_CRASH (SIGABRT)
                                        Exception Codes: 0x0000000000000000, 0x0000000000000000
                                        objc[3158]: garbage collection is OFF
                                        terminate called throwing an exception
                                        abort() called
                                        0   libsystem_kernel.dylib                  0x978d89c6 __pthread_kill + 10
                                        1   libsystem_c.dylib                       0x99159f78 pthread_kill + 106
                                        2   libsystem_c.dylib                       0x9914abdd abort + 167
                                        3   libc++abi.dylib                         0x900ee921 abort_message + 94
                                        4   libc++abi.dylib                         0x900ec1bc default_terminate() + 36
                                        5   libc++abi.dylib                         0x900ec1fe safe_handler_caller(void (*)()) + 15
                                        6   libc++abi.dylib                         0x900ec268 std::terminate() + 23
                                        7   libc++abi.dylib                         0x900ed2a0 __cxa_throw + 112
                                        8   AuUI                                    0x03550f7f aui::ErrorManager::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) const + 319
                                        9   com.adobe.dvacore.framework             0x000c58f8 dvacore::config::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) + 168
                                        10  com.adobe.dvacore.framework             0x0011bf89 dvacore::proplist::utils::LoadPropList(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::proplist::PropList&, bool) + 361
                                        11  AuApplication                           0x026f2f13 app::FavoriteManager::Initialize(bool) + 339
                                        12  AuApplication                           0x028c59e7 app::Initializer::Initialize(bool, boost::function<void ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >)>) + 6023
                                        13  AuUI                                    0x03b56440 aui::ApplicationInitializer::Impl::Initialize(dvaworkspace::workspace::Workspace*) + 2768
                                        14  AuUI                                    0x03b4bc3c aui::ApplicationInitializer::Initialize(dvaworkspace::workspace::Workspace*) + 28
                                        15  AuUI                                    0x0353d6d7 aui::Application::InitApplication(exo::app::AppInitArgs&) + 3943
                                        16  com.adobe.exo.framework                 0x0194cdf9 exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 729
                                        17  AuUI                                    0x0353243e aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 158
                                        18  AuUI                                    0x03555c0f AudMacMain(int, char**) + 415
                                        19  com.adobe.Audition.4.0                  0x00002ecd main + 93
                                        20  com.adobe.Audition.4.0                  0x00002c66 start + 54
                                        0   libsystem_kernel.dylib                  0x978d990a kevent + 10
                                        1   libdispatch.dylib                       0x99256e10 _dispatch_mgr_invoke + 969
                                        2   libdispatch.dylib                       0x9925585f _dispatch_mgr_thread + 53
                                        Thread 2:
                                        0   libsystem_kernel.dylib                  0x978d902e __workq_kernreturn + 10
                                        1   libsystem_c.dylib                       0x99159ccf _pthread_wqthread + 773
                                        2   libsystem_c.dylib                       0x9915b6fe start_wqthread + 30
                                        Thread 3:
                                        Thread 4:
                                        0   libsystem_kernel.dylib                  0x978d883e __psynch_cvwait + 10
                                        1   libsystem_c.dylib                       0x9915be78 _pthread_cond_wait + 914
                                        2   libsystem_c.dylib                       0x9910382a pthread_cond_wait + 48
                                        3   com.adobe.amt.services                  0x06f25274 C_AMTUISwitchSuppressUpdates + 16864
                                        4   com.adobe.amt.services                  0x06f1e074 C_EULA_SetState + 2166
                                        5   com.adobe.amt.services                  0x06f252da C_AMTUISwitchSuppressUpdates + 16966
                                        6   libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
                                        7   libsystem_c.dylib                       0x9915b6de thread_start + 34
                                        Thread 5:
                                        Thread 6:
                                        1   libsystem_c.dylib                       0x9915be21 _pthread_cond_wait + 827
                                        2   libsystem_c.dylib                       0x9910c42c pthread_cond_wait$UNIX2003 + 71
                                        3   com.apple.CoreServices.CarbonCore          0x90e0ae62 TSWaitOnCondition + 124
                                        4   com.apple.CoreServices.CarbonCore          0x90d7c37d TSWaitOnConditionTimedRelative + 136
                                        5   com.apple.CoreServices.CarbonCore          0x90dde67f MPWaitOnQueue + 200
                                        12  libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
                                        13  libsystem_c.dylib                       0x9915b6de thread_start + 34
                                        Thread 7:
                                        Thread 8:
                                        Thread 9:
                                        Thread 10:
                                        Thread 11:
                                        Thread 12:
                                        Thread 13:
                                        Thread 14:
                                        Thread 15:
                                        Thread 16:
                                        Thread 17:
                                        Thread 18:
                                        Thread 19:
                                        Thread 20:
                                        Thread 21:
                                        Thread 22:
                                        2   libsystem_c.dylib                       0x9910c3e0 pthread_cond_timedwait$UNIX2003 + 70
                                        11  libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
                                        12  libsystem_c.dylib                       0x9915b6de thread_start + 34
                                        Thread 23:
                                        2   libsystem_c.dylib                       0x9915bf7b pthread_cond_timedwait_relative_np + 47
                                        3   com.apple.CoreServices.CarbonCore          0x90d7c3a7 TSWaitOnConditionTimedRelative + 178
                                        4   com.apple.CoreServices.CarbonCore          0x90dde67f MPWaitOnQueue + 200
                                        Thread 24:: com.apple.audio.IOThread.client
                                        0   libsystem_kernel.dylib                  0x978d6c22 mach_msg_trap + 10
                                        1   libsystem_kernel.dylib                  0x978d61f6 mach_msg + 70
                                        2   com.apple.audio.CoreAudio               0x9920e9fe HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, unsigned int) + 122
                                        3   com.apple.audio.CoreAudio               0x9920ea6a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 60
                                        4   com.apple.audio.CoreAudio               0x99206e5f HALC_ProxyIOContext::IOWorkLoop() + 1145
                                        5   com.apple.audio.CoreAudio               0x99206926 HALC_ProxyIOContext::IOThreadEntry(void*) + 136
                                        6   com.apple.audio.CoreAudio               0x99206898 __HALC_ProxyIOContext_block_invoke_6 + 20
                                        7   com.apple.audio.CoreAudio               0x9920681d HALB_IOThread::Entry(void*) + 69
                                        8   libsystem_c.dylib                       0x99157ed9 _pthread_start + 335
                                        9   libsystem_c.dylib                       0x9915b6de thread_start + 34
                                          eax: 0x00000000  ebx: 0x900ef330  ecx: 0xbfffe91c  edx: 0x978d89c6
                                          edi: 0xaca2f2c0  esi: 0x00000006  ebp: 0xbfffe938  esp: 0xbfffe91c
                                           ss: 0x00000023  efl: 0x00000246  eip: 0x978d89c6   cs: 0x0000000b
                                          cr2: 0x03e952e0
                                        Logical CPU: 0
                                        Binary Images:
                                        0x47fe000 -  0x4808ff3 +com.adobe.boost_filesystem.framework (boost_filesystem version 5.5.0 - 5.5.0.11) <0E6191C4-7881-0F74-7118-1E5E94CE884C> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                                        0x481d000 -  0x489afe2 +com.adobe.boost_regex.framework (boost_regex version 5.5.0 - 5.5.0.11) <0CF74BD7-D9F3-CA91-D6F6-4B56738E4819> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                                        0x4901000 -  0x49d5fef +com.adobe.dvaeve.framework (dvaeve version 5.5.0 - 5.5.0.11) <029FE587-C304-DEDB-FC46-6F84D2C75EE4> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                                        0x4ad2000 -  0x4afeff3  com.apple.audio.CoreAudioKit (1.6.3 - 1.6.3) <7D47B1D3-4410-3524-BC47-FCDF49E48DB5> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                                        0x4b11000 -  0x4ba73a6 +iZotope_Radius (??? - ???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
                                        0x4be4000 -  0x4c3affb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                        0x4c83000 -  0x4f11fec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
                                        0x5094000 -  0x5141ff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
                                        0x5186000 -  0x52a9ff7 +AdobeACE (??? - ???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                        0x52cc000 -  0x59a6ff3 +AdobeAGM (??? - ???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                        0x5a6b000 -  0x5a88ff7 +AdobeBIB (??? - ???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                        0x5a8f000 -  0x5ab5ffb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                        0x5abc000 -  0x5debff3 +com.adobe.CoolType (AdobeCoolType 5.10.7.10201 - 5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                        0x5e3d000 -  0x5eabffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                        0x5ec2000 -  0x5ec6fff +com.adobe.dvaflashview.framework (dvaflashview version 5.5.0 - 5.5.0.11) <98E23B9D-1CF1-E412-FD26-1EDE5BBD3DF9> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                                        0x5ed1000 -  0x5ed4ffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                        0x6a8c000 -  0x6a94fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                                        0x6aed000 -  0x6af1ffb  com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <E6982BB2-BEC8-3232-989D-B3D5B26AE0DF> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                                        0x6af6000 -  0x6afbfff  com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <BAD1E0E6-10E6-342C-BEB8-B1706F0CE2CF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                        0x6f00000 -  0x6f6bfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                                        0x6f87000 -  0x6fb0fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                                        0x6fc8000 -  0x6fc9ff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                        0x8c00000 -  0x8c70feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Audition CS5.5/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                        0x8feb1000 - 0x8fee3aa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
                                        0x900de000 - 0x900e6fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                        0x900e7000 - 0x900f0fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
                                        0x90239000 - 0x90244ff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <EDA0F56F-CB2C-30BB-940D-C6A25B73C717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                        0x90245000 - 0x90246fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                        0x902ef000 - 0x90304fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                        0x9032f000 - 0x90365ff4  com.apple.LDAPFramework (3.2 - 120.2) <39DF72E3-CDAF-33CC-B2DA-67B8891A5CFF> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                        0x90366000 - 0x9051aff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
                                        0x90531000 - 0x905d5fff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                        0x905d6000 - 0x90ab2ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                        0x90ae7000 - 0x90b15fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
                                        0x90b16000 - 0x90b36ff7  com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                        0x90b37000 - 0x90b4dffe  libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
                                        0x90b4e000 - 0x90b4efff  com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                        0x90b71000 - 0x90b79ff3  liblaunch.dylib (392.38.0 - compatibility 1.0.0) <D7F6E875-263A-37B5-B403-53F76710538C> /usr/lib/system/liblaunch.dylib
                                        0x90b7a000 - 0x90b81ff9  libsystem_dnssd.dylib (??? - ???) <D3A766FC-C409-3A57-ADE4-94B7688E1C7E> /usr/lib/system/libsystem_dnssd.dylib
                                        0x90bb6000 - 0x90bc1ffe  com.apple.NetAuth (3.2 - 3.2) <4377FB18-A550-35C6-BCD2-71C42134EEA6> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                        0x90d23000 - 0x90d3dfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                        0x90d3e000 - 0x91040fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                        0x916bd000 - 0x9174aff7  com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                        0x9174b000 - 0x9174fff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
                                        0x91792000 - 0x917c1ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
                                        0x917c2000 - 0x917d2ff7  libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
                                        0x917d3000 - 0x917d4fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
                                        0x917d5000 - 0x917d6ff7  libsystem_sandbox.dylib (??? - ???) <EBC6ED6B-7D94-32A9-A718-BB9EDA1732C9> /usr/lib/system/libsystem_sandbox.dylib
                                        0x917d7000 - 0x91939ffb  com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                        0x919b4000 - 0x91a18fff  com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                        0x91a2a000 - 0x91a6aff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                        0x91a6b000 - 0x91a8dffe  com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                        0x91a8e000 - 0x91ae9ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                        0x91aea000 - 0x91b4cffb  com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                        0x91b50000 - 0x91b72ff8  com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                        0x91b73000 - 0x91bb1fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <19174EC0-DE0F-38EA-B5F3-7580E84677DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                        0x91c29000 - 0x91c2dffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
                                        0x92082000 - 0x92345fff  com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                        0x92346000 - 0x92356fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
                                        0x9276a000 - 0x92a74ff3  com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                        0x92aba000 - 0x92b18fff  com.apple.coreui (1.2.2 - 165.10) <C6B099D6-7F02-3971-99B9-E415308959CF> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                        0x92b1e000 - 0x92bb4ff7  com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                        0x92bc4000 - 0x92c15ff9  com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                                        0x92c16000 - 0x92d34fec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                        0x92d35000 - 0x92d43fff  com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                        0x92e41000 - 0x92e44ffb  com.apple.help (1.3.2 - 42) <B1E6701C-7473-30B2-AB5A-AFC9A4823694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                        0x92e45000 - 0x92ea7ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
                                        0x92ef3000 - 0x92f45ff7  libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                        0x92f46000 - 0x92f83ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib
                                        0x92f84000 - 0x92f8bfff  com.apple.agl (3.2.0 - AGL-3.2.0) <ED5A5B8A-0014-3897-951F-628391333256> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                        0x92f98000 - 0x9307bff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
                                        0x93112000 - 0x93135fff  com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                        0x93445000 - 0x93446ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
                                        0x93447000 - 0x93849ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                        0x9384a000 - 0x9384efff  libGIF.dylib (??? - ???) <A6F1ACAE-7B9B-3B3F-A54A-ED4004EA1D85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                        0x9384f000 - 0x93850fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
                                        0x939e7000 - 0x93a0cff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                        0x93a0d000 - 0x93a75ff7  libc++.1.dylib (28.1.0 - compatibility 1.0.0) <FE3304C5-C000-3DA0-9E53-0E4CA074B73B> /usr/lib/libc++.1.dylib
                                        0x93a76000 - 0x93a9eff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib
                                        0x93a9f000 - 0x93bb0ff7  libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                                        0x93f6c000 - 0x93f6dffd  libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                        0x93f8d000 - 0x93f92ff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
                                        0x93fb1000 - 0x93ffaff7  libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                        0x94001000 - 0x940e9fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
                                        0x940ea000 - 0x94120ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                        0x94385000 - 0x943aeffe  com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                        0x94418000 - 0x944b4fef  com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                        0x944b5000 - 0x944b5fff  com.apple.Carbon (153 - 153) <63603A0C-723B-3968-B302-EBEEE6A14E97> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                        0x944b6000 - 0x944cbff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                        0x944cc000 - 0x94542fff  com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                        0x945d0000 - 0x945d4ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                        0x9485d000 - 0x94860ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
                                        0x94861000 - 0x948b1ff8  libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                        0x948bd000 - 0x949ccfff  com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                        0x954b0000 - 0x954c1fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
                                        0x95514000 - 0x95517ff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <1211BEEB-31C9-3A5D-9E71-10FC4A541D1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                        0x9565b000 - 0x956c0ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                        0x956c1000 - 0x956c4ffd  libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                        0x9639e000 - 0x963b1ff8  com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                        0x964c4000 - 0x96551fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                        0x96552000 - 0x965afffb  com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                        0x965b0000 - 0x965b4fff  com.apple.CommonPanels (1.2.5 - 94) <EA47550D-7DAF-30D9-91DB-1FB594CC8522> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                        0x968fc000 - 0x9693dff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
                                        0x9694c000 - 0x9694cfff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                        0x9694d000 - 0x9694eff7  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib
                                        0x9694f000 - 0x9696bffc  libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                        0x9696c000 - 0x9729659b  com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                        0x9760c000 - 0x97654ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                        0x9767a000 - 0x9767aff0  com.apple.ApplicationServices (41 - 41) <C48EF6B2-ABF9-35BD-A07A-A38EC0008294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                        0x976a2000 - 0x9772cffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                        0x9777c000 - 0x9783cffb  com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                        0x97885000 - 0x9788dff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
                                        0x978c0000 - 0x978deff7  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
                                        0x978df000 - 0x978edff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
                                        0x978ee000 - 0x978f8ff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                        0x978f9000 - 0x97939ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
                                        0x9793a000 - 0x97a0affb  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                        0x97a0b000 - 0x984a0ff6  com.apple.AppKit (6.7.3 - 1138.47) <D8CD06D7-F18C-39BE-BC68-B343F87F0469> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                        0x984a1000 - 0x98528fff  com.apple.print.framework.PrintCore (7.1 - 366.3) <EEC03CAB-7F79-3931-87FE-4DF0B767BF47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                        0x98529000 - 0x98655ff9  com.apple.CFNetwork (520.4.3 - 520.4.3) <E9E315D4-CE22-3715-BED2-BB95AD5E10E8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                        0x98657000 - 0x98747ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
                                        0x987db000 - 0x9881effd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
                                        0x988a2000 - 0x988b2fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                        0x98900000 - 0x9897bffb  com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                        0x9897c000 - 0x9897cffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
                                        0x98c8d000 - 0x98d85ff7  libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                        0x98d86000 - 0x98dbaff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
                                        0x990eb000 - 0x990f8fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                        0x990fb000 - 0x991c6fff  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
                                        0x991c7000 - 0x991f1ff1  com.apple.CoreServicesInternal (113.17 - 113.17) <41979516-2F26-3707-A6CA-7A95A1B0D963> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                        0x991f2000 - 0x99253ffb  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                        0x99254000 - 0x99262fff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
                                        0x99263000 - 0x99264fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
                                        0x993d7000 - 0x993dbffd  IOSurface (??? - ???) <EDDBEE65-1EB8-33A7-9972-E361A3508234> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                        0x994bd000 - 0x994c6ff3  com.apple.CommonAuth (2.2 - 2.0) <C3FD6EC2-8EB3-38FB-BBB7-05009CA49024> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                        0x9973b000 - 0x997fefff  com.apple.CoreServices.OSServices (478.46 - 478.46) <F2063FC8-2BE1-3B97-98AF-8796B0D4BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                        0x99eb7000 - 0x99ebdffd  com.apple.CommerceCore (1.0 - 17) <E59CD307-58E2-35FD-9131-B38978799910> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                        0x99ecd000 - 0x99edbfff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
                                        0x99edf000 - 0x99eeafff  libkxld.dylib (??? - ???) <D8ED88D0-7153-3514-9927-AF15A12261A5> /usr/lib/system/libkxld.dylib
                                        0x99efc000 - 0x99efcfff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                        0x99efd000 - 0x99efeff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
                                        0x99eff000 - 0x99f0affb  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                        0x99f0b000 - 0x9a17effb  com.apple.CoreImage (7.98 - 1.0.1) <EDC91BA1-673D-3B47-BFD5-BBF11C36EE6A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                        0x9a17f000 - 0x9a5f4ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                                        0x9a5f5000 - 0x9a7edff7  com.apple.CoreData (104.1 - 358.14) <C1730963-F75D-3338-B65F-D50235538B28> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                        0x9a7ee000 - 0x9a9c5fe7  com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                        0x9a9cc000 - 0x9ad12ff3  com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                        0x9ad50000 - 0x9ad55ffd  libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                        0x9addc000 - 0x9addcfff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
                                        0x9addd000 - 0x9addfffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                        0x9b057000 - 0x9b074ff3  com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                        0x9b0ba000 - 0x9b0e8ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                        0x9b0f1000 - 0x9b0f1fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                        0x9b0f2000 - 0x9b0f4ff9  com.apple.securityhi (4.0 - 1) <ACEEED5F-8D58-377D-B2B8-E4A7F4E5E286> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                        0x9b0f5000 - 0x9b14efff  com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                        0x9b14f000 - 0x9b2a1fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                        0x9b2a2000 - 0x9b339ff3  com.apple.securityfoundation (5.0 - 55116) <EB53CEF7-4836-39FD-B012-6BC122ED4CE9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                        0x9b33a000 - 0x9b345ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib
                                        0x9b346000 - 0x9b382ffa  libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                        0x9b384000 - 0x9b3a0ff5  com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                        0x9b3a1000 - 0x9b3b5fff  com.apple.CFOpenDirectory (10.7 - 146) <9149C1FE-865E-3A8D-B9D9-547384F553C8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                        0x9b50d000 - 0x9b581fff  com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                        0x9b5db000 - 0x9b5deff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
                                        0x9b5df000 - 0x9b64efff  com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                        0x9b64f000 - 0x9b67afff  com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                        0x9b92e000 - 0x9b935ffd  com.apple.NetFS (4.0 - 4.0) <AE731CFE-1B2E-3E46-8759-843F5FB8C24F> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                        0x9b936000 - 0x9b93dff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
                                        0x9b93e000 - 0x9b95bfff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
                                        0x9b95c000 - 0x9b993fef  com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                        0x9b99c000 - 0x9b99eff7  libdyld.dylib (195.6.0 - compatibility 1.0.0) <1F865C73-5803-3B08-988C-65B8D86CB7BE> /usr/lib/system/libdyld.dylib
                                        0x9babe000 - 0x9bac1ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
                                        0x9bb15000 - 0x9bb1dff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <BB0C7B49-600F-3551-A460-B7E36CA4C4A4> /usr/lib/system/libcopyfile.dylib
                                        0x9bdcc000 - 0x9bdccfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                        0x9cb1e000 - 0x9cb24ffb  com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                        0x9cb9d000 - 0x9ccadfe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
                                        0x9ccae000 - 0x9ccaeff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                        0x9ce97000 - 0x9cf6daab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
                                            task_for_pid: 2
                                            thread_create: 0
                                            thread_set_state: 0
                                            task_for_pid: 0
                                            thread_create: 0
                                            thread_set_state: 0
                                            task_for_pid: 3735
                                            thread_create: 0
                                            thread_set_state: 0
                                        VM Region Summary:
                                        ReadOnly portion of Libraries: Total=219.6M resident=105.4M(48%) swapped_out_or_unallocated=114.2M(52%)
                                        Writable regions: Total=139.4M written=6536K(5%) resident=10.8M(8%) swapped_out=0K(0%) unallocated=128.6M(92%)
                                        REGION TYPE                      VIRTUAL
                                        CG raster data                      860K
                                        CG shared images                   1224K
                                        CoreGraphics                          8K
                                        CoreServices                       3724K
                                        MALLOC                             80.8M
                                        Memory tag=243                        8K
                                        Stack                              76.2M
                                        VM_ALLOCATE                        1004K
                                        __CI_BITMAP                          80K
                                        __DATA                             13.3M
                                        __DATA/__OBJC                       224K
                                        __IMAGE                             528K
                                        __IMPORT                            284K
                                        __LINKEDIT                         76.5M
                                        __OBJC                             1460K
                                        __PAGEZERO                            4K
                                        __TEXT                            143.1M
                                        __UNICODE                           544K
                                        mapped file                       145.8M
                                        shared memory                       364K
                                        shared pmap                        10.6M
                                        TOTAL                             590.7M
                                        TOTAL, minus reserved VM space    557.3M
                                        Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 8 GB, SMC 1.69f3
                                        Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
                                        Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
                                        Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
                                        Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
                                        AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.4.20)
                                        Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
                                        Network Service: Wi-Fi, AirPort, en1
                                        Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
                                        Serial ATA Device: MATSHITADVD-R   UJ-8A8
                                        USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 3
                                        USB Device: USB Mouse, 0x0d62  (Darfon Electronics Corp.), 0xa100, 0xfa130000 / 6
                                        USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0245, 0xfa120000 / 5
                                        USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
                                        USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
                                        USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
                                        USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
                                        USB Device: Desktop, 0x0bc2  (Seagate LLC), 0x3300, 0xfd120000 / 4
                                        USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
                                        FireWire Device: GoFlex Desk, Seagate, 800mbit_speed
                                        Please help thanks
                                        • 17. Re: Audition CS5.5 Crashes Immediately After Start-Up.
                                          For this crash report, it looks like the Favorites file is corrupt.  You might want to email that .xml file in the preference folder to audbugs@adobe.com such that the team can investigate.  Otherwise, probably deleting your prefs file might help your crash on startup.
