38 Replies Latest reply on Apr 12, 2012 3:31 AM by UnFlash
    The ActiveX control for Flash Player could not be registered
    ChipM Level 1
      Here we go again with a failed Flash Player install.
      Runing Windows 7 64bit with IE9
      Install gets to 50% and stalls with Failed to register.
      I have downloaded the small install, run as Admin. Same error.
      Uninstalled and Rebooted...
      Downloaded the direct install, run as Admin. Same error.
      Reduced IE9 Security to lowest setting. Same error.
      Uninstalled, rebooted, reinstalled. Same error.
      Run Task Manager shut down all processes (except criticals). Same error.
      Ran reset_fp10.cmd through subinalc.exe. Same error. Might there be a reset_fp11.cmd?
      Not sure what else to do here...Ideas?
        • 1. Re: The ActiveX control for Flash Player could not be registered
          libflashplayer.so Adobe Employee
          some people have found that there are multiple iexplore.exe processes running, but it sounds like you covered this.  if you did not, make sure to force quit those.  also, some IM clients and other apps can possibly load the player.  check the system tray to see if any programs are running there.
          • 2. Re: The ActiveX control for Flash Player could not be registered
            pwillener Level 8
            Sorry, I have just a few minutes before I have to leave...
            Can you download & install Process Monitor, then start the installer and note the process ID.
            Start Process Monitor and filter only the FP installer.  Next click INSTALL (on the FP installer) and watch it with Process Monitor.  It should show you what registry entry is blocking the installer from registering the ActiveX.
            • 3. Re: The ActiveX control for Flash Player could not be registered
              ChipM Level 1
              libflashplayer.so,
              I made sure there were no running processes or applications except for core Windows components,
              • 4. Re: The ActiveX control for Flash Player could not be registered
                ChipM Level 1
                ʇɐb ɹəuəllıʍ,
                Other than some Name Not Found or No More File Results I do not see any true Failures in the process. Of course I have never read Process Monitor results so I may be missing something.
                I will say that I can successfully install it for Firefox. But that does not do me much good since my Adobe products that depend on Flash Player (RoboHelp, Captivate, etc...) require the one for Internet Explorer. This simple install problem has brought me to a stand-still.
                • 5. Re: The ActiveX control for Flash Player could not be registered
                  pwillener Level 8
                  Is the ProcMon output very large, or just one page?  Could you take a screenshot of that output?
                  I also don't know what we will get from ProcMon, but I am hoping that we can see what is causing that registration error.  (I also don't understand why the Firefox plugin [dll] can be registered, but the IE ActiveX [ocx] cannot.)
                  • 6. Re: The ActiveX control for Flash Player could not be registered
                    ChipM Level 1
                    Very large...Over 30,000 events linked specifically to that install.
                    • 7. Re: The ActiveX control for Flash Player could not be registered
                      pwillener Level 8
                      Can you try to save the output, then attach it to a reply in this forum?
                      (I see that I have a 8.9MB limit to attached files; do you see a similar limit? Is the file larger than that? Could you possibly zip it if it is larger?)
                      • 8. Re: The ActiveX control for Flash Player could not be registered
                        ChipM Level 1
                        Still can't get this going. I have monitored and tried all the solutions offered to others having this problem with no resolution yet. Can't figure out how to attach the log file.
                        • 9. Re: The ActiveX control for Flash Player could not be registered
                          WDY73
                          I am ready to throw my computer out the window at this point. My Flashplayer worked fine until the 11 upgrade. Windows XP, Service Pack 3, 32bit, Internet Explorer. Home computer, nothing special but all that happens is it gets through 50% then says Active X can't be registered. Exact same error has here???
                          • 10. Re: The ActiveX control for Flash Player could not be registered
                            WDY73 Level 1
                            I FINALLY got it to work by using the solution offered here: http://kb2.adobe.com/cps/494/cpsid_49419.html
                            • 11. Re: The ActiveX control for Flash Player could not be registered
                              pwillener Level 8
                              Click on "Use advanced editor" on the upper-right corner of the forum editor.
                              Now click on the "Browse" button under "Attach Files" on the lower-left corner.
                              (I have just attached a little PDF to test attachments.)
                              • 12. Re: The ActiveX control for Flash Player could not be registered
                                ChipM Level 1
                                WDY73,
                                Glad you got your working...I had already tried that solution with no luck.
                                • 13. Re: The ActiveX control for Flash Player could not be registered
                                  ChipM Level 1
                                  ʇɐb ɹəuəllıʍ,
                                  Maybe I can't see the Browse option because I don't have Flash. How frustrating...Not to mention how this has screwed up the functionality of the other Adobe products I use.
                                  • 14. Re: The ActiveX control for Flash Player could not be registered
                                    pwillener Level 8
                                    Can you send it to me by email?  (I'll send you my address via PM.)
                                    • 15. Re: The ActiveX control for Flash Player could not be registered
                                      pwillener Level 8
                                      Thank you; I have received your Procmon logfile.  It is indeed very long, and it may take me a while to analyze it.  (I also have just reinstalled the FP 11 ActiveX with Procmon, so I will have something to compare it with.)
                                      If any of the Adobe engineers want to have a look at it as well, I will try to attach it to this post.
                                      • 16. Re: The ActiveX control for Flash Player could not be registered
                                        pwillener Level 8
                                        Have you ever used the registry editor (regedit.exe)?
                                        I would like you to check some few things for me (do not edit anything!).
                                        Using regedit, can you find the following key: {D27CDB6E-AE6D-11cf-96B8-444553540000}
                                        This key should exist at HKEY_CLASSES_ROOT\CLSID and other locations.  I am only insterested in the one at HKEY_CLASSES_ROOT\CLSID.
                                        Does it exist in your registry?
                                        Does it have any subkeys, like InprocServer32 and others?
                                        If the InprocServer32 subkey exists, what does it contain?
                                        Please feel free to ask if you are unsure about what to do.  (But I feel you have good technical skills, the way you handled Procmon.)
                                        • 17. Re: The ActiveX control for Flash Player could not be registered
                                          ChipM Level 1
                                          No it is not located in HKEY_CLASSES_ROOT. Does pop up in HKCU and HKLM though.
                                          • 18. Re: The ActiveX control for Flash Player could not be registered
                                            pwillener Level 8
                                            The reason I asked about that key is that I saw in your log several dozen times NAME NOT FOUND for that key.
                                            In my own Procmon log I see that the Flash OCX is registered in that key, but I do not see that in your log file.
                                            I need to look deeper into these logs, i.e. where that key is created, and where it potentially fails in your case.  Unfortunately I have not much time today.
                                            Attaching the log file to my earlier post failed.  (The virus scanner rejected it as malware.)  I will try to forward it by email to the engineering team.
                                            • 19. Re: The ActiveX control for Flash Player could not be registered
                                              ChipM Level 1
                                              Woo hoo! I got it going. Thanks ʇɐb ɹəuəllıʍ you gave me enough hints to get it going! Ok, here is what I had to do...
                                              1. Logon as the local administrator - this is so you will have unrestricted access to the registry.
                                              2. Run the registry editor
                                              3. Access the HKEY_CLASSES_ROOT - backup or "export" the key
                                              4. Attempt to assign permissions to the entire key - Be sure to assign permissions to the Administrators Group not just the current administrator, include subkeys in the permission assignments. ( You may receive a message stating that permissions cannot be assigned to all subkeys or registries, this is okay)
                                              5. Scroll down in the HKEY_CLASSES_ROOT key specifically to the HKEY_CLASSES_ROOT\CLSID - Now assign permission to this key specifically, include the subkeys and leave the parent permissions intact. You should not receive the subkey permission message this time.
                                              6. Run the flash executable.
                                              You should have a successful installation at this point.
                                              Thanks again ʇɐb ɹəuəllıʍc for the hints!
                                              • 20. Re: The ActiveX control for Flash Player could not be registered
                                                pwillener Level 8
                                                Well done!
                                                To everyone trying this solution, be sure to create a System Restore Point before editing the registry.
                                                • 21. Re: The ActiveX control for Flash Player could not be registered
                                                  freevision
                                                  Hello!
                                                  I've the same issue since a month... everything was fine with version 10. after needed to update for V.11 i got that activex error. trying all solutions but so far I couldnt solve it.... even I gave those permissions on registry. it s not helping... what am I suppose to do? am I missing something.... any other idea?
                                                  kinda regards
                                                  • 22. Re: The ActiveX control for Flash Player could not be registered
                                                    pwillener Level 8
                                                    I am still collecting data from other similar reports; maybe I can come up with a general solution.
                                                    If you want to help, send me your ProcMon logfile.
                                                    • 23. Re: The ActiveX control for Flash Player could not be registered
                                                      freevision Level 1
                                                      hi,
                                                      here s my log file. http://dl.dropbox.com/u/2478367/Logfile2.PML
                                                      I hope we can find a permanent solution for this ridicilous .... I contacted with Macromedia and also microsoft about this issue. Both of them blaming eachother but no solutions. what kind of customer care is that ))
                                                      ps: my chrome and firefox perfectly works with flash player 11
                                                      • 24. Re: The ActiveX control for Flash Player could not be registered
                                                        pwillener Level 8
                                                        Thank you for the logfile; I will have a look at it when I find some time.
                                                        Actually, it is neither Microsoft's nor Adobe's fault; it is a permission issue within your Windows registry.  From the few logfiles I have analyzed so far, each user had a different problem (different registry key with insufficient permissions).
                                                        • 25. Re: The ActiveX control for Flash Player could not be registered
                                                          freevision Level 1
                                                          I followed almost every solutions, including permit whole HKEY_CLASSES_ROOT and specifically to CLSID. is there any other folders I need to permit?
                                                          the thing is this issue came up with player 11. all was fine before that. isn't that weird?  I believe Adobe and Microsoft must consider these issues.
                                                          kinda regards
                                                          • 26. Re: The ActiveX control for Flash Player could not be registered
                                                            freevision Level 1
                                                            hi,
                                                            did ever have a chance to look at my log file? still I'm stuck with this issue....
                                                            • 27. Re: The ActiveX control for Flash Player could not be registered
                                                              pwillener Level 8
                                                              Sorry, I haven't found anything so far.  I have (today) asked the Adobe team to have a look at it.
                                                              • 28. Re: The ActiveX control for Flash Player could not be registered
        freevision Level 1
        hello! is there any response from adobe team. this non-sense issue s affecting all my workflow ((((
        • 29. Re: The ActiveX control for Flash Player could not be registered
        pwillener Level 8
        Yes, the Adobe team is looking into it.
        Meanwhile, another user has discovered a tool that seems to fix many installation problems: http://support.microsoft.com/mats/Program_Install_and_Uninstall
        Can you give it a try?
        • 30. Re: The ActiveX control for Flash Player could not be registered
        chris.campbell Adobe Employee
        Freevision,
        Thanks for the log file.  In addition to that, can you also post your Flash Player installer log?
        Chris
        • 32. Re: The ActiveX control for Flash Player could not be registered
        freevision Level 1
        hi,
        I did it... I assume u know already how it works. at the end Adobe Flash Player wasnt on the list. so it couldnt find any problem to fix. but there was Adobe AIR, Adobe Community Help, Adobe media Player and Adobe reader.. dont think it s related with my issue.
        still there s no progress...
        • 33. Re: The ActiveX control for Flash Player could not be registered
        freevision Level 1
        hi guys, I'm sorry but anything new with this issue?
        • 34. Re: The ActiveX control for Flash Player could not be registered
        freevision Level 1
        FINALLY I FIXED THIS PROBLEM....
        it was all about permissions of Flash directory under WINDOWS folder.
        1- Permissions must be set manually on
        C:\Windows\System32\Macromed\Flash  ( as Administrator -- right click on folder's name then launch Properties, switch SECURITY section and select your user. REMEMBER: your account must be administrator rights. check under Allow boxes there, then Apply all changes)
        2-  Same process must be done also for C:\Windows\SysWOW64\Macromed\Flash
        3- Download latest http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp_11.1.102.55_archive .zip  it s an installer archive.
        4- try to install fp_11.1.102.55_archive\11_1r102_55_64bit\flashplayer11_1r102_55_winax_64bit.msi   do not try to install EXE versions. it doesnt work. MSI installer worked for me...
        I tried many solutions to fix it. non of them worked. this research took me 2 months but I fixed finally... Adobe Team MUST CONSIDER this solution next time I believe.
        thanks
        • 35. Re: The ActiveX control for Flash Player could not be registered
        ChipM Level 1
        OK, so Flash Player 11.1.102.63 is released and I get notification the Flash needs to Update. So I blindly allow it to Update. Guess what? Same problem as I had that started this post. There is a very critical piece of information in Freevision's Correct Answer. You MUST install via the .MSI file and not the automatic download file or the .EXE.
        • 36. Re: The ActiveX control for Flash Player could not be registered
        Anzo07
        THANKS FREEVISION, YOU ARE THE BEST
        After 6 months I FINALLY fixed this problem, following your instructions, as for what ChipM said, in the next page you can find the LAST install via .MSI
        http://www.adobe.com/products/flashplayer/distribution3.html
        Thank you!!!!!!!!! for posting it, i'm so happy i just cant believe it's already fixed
        • 37. Re: The ActiveX control for Flash Player could not be registered
        UnFlash Level 1
        Failed. I always use the MSI, now what did adobe do?  All permissions were good; registry and both macro folders. Ripped ALL adobe from system and registry, checked permissions, MSI again. Fail. Extracted the exe from the MSI, failed again. Why does updating flash have to be such a hassle?
        • 38. Re: The ActiveX control for Flash Player could not be registered
        UnFlash Level 1
        Here is thelog. I did all the permisisoning to where I even gave Everyone and Users full on the folders.
        === Verbose logging started: 4/12/2012  05:25:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
        MSI (c) (F4:A0) [05:25:33:647]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
        MSI (c) (F4:64) [05:25:33:678]: Resetting cached policy values
        MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'Debug' is 0
        MSI (c) (F4:64) [05:25:33:678]: ******* RunEngine:
        ******* Product: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        ******* Action:
        ******* CommandLine: **********
        MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'DisableUserInstalls' is 0
        MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
        MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
        MSI (c) (F4:64) [05:25:33:991]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
        MSI (c) (F4:64) [05:25:34:053]: Cloaking enabled.
        MSI (c) (F4:64) [05:25:34:053]: Attempting to enable all disabled privileges before calling Install on Server
        MSI (c) (F4:64) [05:25:34:069]: End dialog not enabled
        MSI (c) (F4:64) [05:25:34:069]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        MSI (c) (F4:64) [05:25:34:069]: Package we're running from ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: Compatibility mode property overrides found.
        MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: no matching ProductCode found in database.
        MSI (c) (F4:64) [05:25:34:069]: MSCOREE not loaded loading copy from system32
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'TransformsSecure' is 0
        MSI (c) (F4:64) [05:25:34:084]: User policy value 'TransformsAtSource' is 0
        MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2205 2:  3: MsiFileHash
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisablePatch' is 0
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AllowLockdownPatch' is 0
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableLUAPatching' is 0
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableFlyWeightPatching' is 0
        MSI (c) (F4:64) [05:25:34:084]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
        MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: no matching ProductCode found in database.
        MSI (c) (F4:64) [05:25:34:084]: Transforms are not secure.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
        MSI (c) (F4:64) [05:25:34:084]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=4596
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
        MSI (c) (F4:64) [05:25:34:084]: Product Code passed to Engine.Initialize:           ''
        MSI (c) (F4:64) [05:25:34:084]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
        MSI (c) (F4:64) [05:25:34:084]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
        MSI (c) (F4:64) [05:25:34:084]: Product not registered: beginning first-time install
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
        MSI (c) (F4:64) [05:25:34:084]: Entering CMsiConfigurationManager::SetLastUsedSource.
        MSI (c) (F4:64) [05:25:34:084]: User policy value 'SearchOrder' is 'nmu'
        MSI (c) (F4:64) [05:25:34:084]: Adding new sources is allowed.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
        MSI (c) (F4:64) [05:25:34:084]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
        MSI (c) (F4:64) [05:25:34:084]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
        MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2262 2: AdminProperties 3: -2147287038
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableMsi' is 0
        MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AlwaysInstallElevated' is 0
        MSI (c) (F4:64) [05:25:34:084]: User policy value 'AlwaysInstallElevated' is 0
        MSI (c) (F4:64) [05:25:34:084]: Product installation will be elevated because user is admin and product is being installed per-machine.
        MSI (c) (F4:64) [05:25:34:084]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
        MSI (c) (F4:64) [05:25:34:084]: TRANSFORMS property is now:
        MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
        MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
        MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
        MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
        MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
        MSI (c) (F4:64) [05:25:34:100]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
        MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'MsiDisableEmbeddedUI' is 0
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
        MSI (c) (F4:A0) [05:25:34:100]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
        === Logging started: 4/12/2012  05:25:34 ===
        MSI (c) (F4:64) [05:25:34:100]: Note: 1: 2205 2:  3: PatchPackage
        MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'DisableRollback' is 0
        MSI (c) (F4:64) [05:25:34:100]: User policy value 'DisableRollback' is 0
        MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
        MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
        MSI (c) (F4:64) [05:25:34:116]: Doing action: INSTALL
        Action 05:25:34: INSTALL.
        Action start 05:25:34: INSTALL.
        MSI (c) (F4:64) [05:25:34:116]: UI Sequence table 'InstallUISequence' is present and populated.
        MSI (c) (F4:64) [05:25:34:116]: Running UISequence
        MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
        MSI (c) (F4:64) [05:25:34:116]: Doing action: ISSetAllUsers
        Action 05:25:34: ISSetAllUsers.
        Action start 05:25:34: ISSetAllUsers.
        MSI (c) (F4:64) [05:25:34:147]: Creating MSIHANDLE (1) of type 790542 for thread 1380
        MSI (c) (F4:78) [05:25:34:147]: Invoking remote custom action. DLL: C:\Users\Ad~1\AppData\Local\Temp\MSIEDE8.tmp, Entrypoint: SetAllUsers
        MSI (c) (F4:DC) [05:25:34:147]: Cloaking enabled.
        MSI (c) (F4:DC) [05:25:34:147]: Attempting to enable all disabled privileges before calling Install on Server
        MSI (c) (F4:DC) [05:25:34:147]: Connected to service for CA interface.
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (2) of type 790531 for thread 2532
        InstallShield 05:25:34: Begin SetAllUsers()
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (2) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (3) of type 790541 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (4) of type 790531 for thread 2532
        InstallShield 05:25:34: Getting records from Upgrade table
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (4) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (5) of type 790540 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (6) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (7) of type 790531 for thread 2532
        InstallShield 05:25:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (7) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (8) of type 790531 for thread 2532
        InstallShield 05:25:34: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (8) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (6) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (9) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (10) of type 790531 for thread 2532
        InstallShield 05:25:34: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (10) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (11) of type 790531 for thread 2532
        InstallShield 05:25:34: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (11) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (9) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (12) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (13) of type 790531 for thread 2532
        InstallShield 05:25:34: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (13) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (14) of type 790531 for thread 2532
        InstallShield 05:25:34: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (14) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (12) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (15) of type 790531 for thread 2532
        InstallShield 05:25:34: End SetAllUsers()
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (15) of type 790531 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (5) of type 790540 for thread 2532
        MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (3) of type 790541 for thread 2532
        MSI (c) (F4:78) [05:25:34:256]: Closing MSIHANDLE (1) of type 790542 for thread 1380
        Action ended 05:25:34: ISSetAllUsers. Return value 1.
        MSI (c) (F4:64) [05:25:34:256]: Doing action: AppSearch
        Action 05:25:34: AppSearch. Searching for installed applications
        Action start 05:25:34: AppSearch.
        MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2205 2:  3: AppSearch
        MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
        Action ended 05:25:34: AppSearch. Return value 0.
        MSI (c) (F4:64) [05:25:34:256]: Doing action: LaunchConditions
        Action 05:25:34: LaunchConditions. Evaluating launch conditions
        Action start 05:25:34: LaunchConditions.
        Action ended 05:25:34: LaunchConditions. Return value 1.
        MSI (c) (F4:64) [05:25:34:272]: Doing action: SetupInitialization
        Action 05:25:34: SetupInitialization.
        Action start 05:25:34: SetupInitialization.
        Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
        Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
        Action 05:25:34: SetupInitialization. Dialog created
        Action ended 05:25:34: SetupInitialization. Return value 1.
        MSI (c) (F4:64) [05:25:34:288]: Doing action: FindRelatedProducts
        Action 05:25:34: FindRelatedProducts. Searching for related applications
        Action start 05:25:34: FindRelatedProducts.
        Action ended 05:25:34: FindRelatedProducts. Return value 1.
        MSI (c) (F4:64) [05:25:34:288]: Skipping action: CCPSearch (condition is false)
        MSI (c) (F4:64) [05:25:34:288]: Skipping action: RMCCPSearch (condition is false)
        MSI (c) (F4:64) [05:25:34:288]: Doing action: ValidateProductID
        Action 05:25:34: ValidateProductID.
        Action start 05:25:34: ValidateProductID.
        Action ended 05:25:34: ValidateProductID. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: CostInitialize
        Action 05:25:34: CostInitialize. Computing space requirements
        Action start 05:25:34: CostInitialize.
        MSI (c) (F4:64) [05:25:34:303]: Machine policy value 'MaxPatchCacheSize' is 10
        MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
        MSI (c) (F4:64) [05:25:34:303]: Baseline: New baseline 11.2.202 from transaction.
        MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorted order Native: Order 0.
        MSI (c) (F4:64) [05:25:34:303]: Baseline Data Table:
        MSI (c) (F4:64) [05:25:34:303]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
        MSI (c) (F4:64) [05:25:34:303]: Baseline File Table:
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
        Action ended 05:25:34: CostInitialize. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: FileCost
        Action 05:25:34: FileCost. Computing space requirements
        Action start 05:25:34: FileCost.
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: MsiAssembly
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Class
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Extension
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: TypeLib
        Action ended 05:25:34: FileCost. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: IsolateComponents
        Action 05:25:34: IsolateComponents.
        Action start 05:25:34: IsolateComponents.
        Action ended 05:25:34: IsolateComponents. Return value 0.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: setUserProfileNT
        Action 05:25:34: setUserProfileNT.
        Action start 05:25:34: setUserProfileNT.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
        Action ended 05:25:34: setUserProfileNT. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Skipping action: SetAllUsersProfileNT (condition is false)
        MSI (c) (F4:64) [05:25:34:303]: Doing action: setAllUsersProfile2K
        Action 05:25:34: setAllUsersProfile2K.
        Action start 05:25:34: setAllUsersProfile2K.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
        Action ended 05:25:34: setAllUsersProfile2K. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: ResolveSource
        Action 05:25:34: ResolveSource.
        Action start 05:25:34: ResolveSource.
        MSI (c) (F4:64) [05:25:34:303]: Resolving source.
        MSI (c) (F4:64) [05:25:34:303]: Resolving source to launched-from source.
        MSI (c) (F4:64) [05:25:34:303]: Setting launched-from source as last-used.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR ==> C:\Users\Admin\Desktop\
        MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
        MSI (c) (F4:64) [05:25:34:303]: Determining source type
        MSI (c) (F4:64) [05:25:34:303]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
        MSI (c) (F4:64) [05:25:34:303]: Source path resolution complete. Dumping Directory table...
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
        MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
        Action ended 05:25:34: ResolveSource. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: CostFinalize
        Action 05:25:34: CostFinalize. Computing space requirements
        Action start 05:25:34: CostFinalize.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2262 2: Patch 3: -2147287038
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Condition
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
        MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
        MSI (c) (F4:64) [05:25:34:303]: Target path resolution complete. Dumping Directory table...
        MSI (c) (F4:64) [05:25:34:303]: Note: target paths subject to change (via custom actions or browsing)
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TARGETDIR , Object: E:\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
        MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
        MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
        Action ended 05:25:34: CostFinalize. Return value 1.
        MSI (c) (F4:64) [05:25:34:303]: Doing action: MigrateFeatureStates
        Action 05:25:34: MigrateFeatureStates. Migrating feature states from related applications
        Action start 05:25:34: MigrateFeatureStates.
        Action ended 05:25:34: MigrateFeatureStates. Return value 0.
        MSI (c) (F4:64) [05:25:34:303]: Skipping action: PatchWelcome (condition is false)
        MSI (c) (F4:64) [05:25:34:303]: Doing action: InstallWelcome
        Action 05:25:34: InstallWelcome.
        Action start 05:25:34: InstallWelcome.
        Action 05:25:34: InstallWelcome. Dialog created
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: _RemoveFilePath
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: MsiFileHash
        MSI (c) (F4:9C) [05:25:34:319]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: BindImage
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: ProgId
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: PublishComponent
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: SelfReg
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Extension
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Font
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Shortcut
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Class
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: TypeLib
        MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2727 2:
        Action ended 05:25:36: InstallWelcome. Return value 1.
        MSI (c) (F4:64) [05:25:36:022]: Skipping action: SetupResume (condition is false)
        MSI (c) (F4:64) [05:25:36:022]: Skipping action: MaintenanceWelcome (condition is false)
        MSI (c) (F4:64) [05:25:36:022]: Doing action: SetupProgress
        Action 05:25:36: SetupProgress.
        Action start 05:25:36: SetupProgress.
        Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
        Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
        Action 05:25:36: SetupProgress. Dialog created
        Action ended 05:25:36: SetupProgress. Return value 1.
        MSI (c) (F4:64) [05:25:36:038]: Doing action: ExecuteAction
        Action 05:25:36: ExecuteAction.
        Action start 05:25:36: ExecuteAction.
        MSI (c) (F4:64) [05:25:36:053]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
        MSI (c) (F4:64) [05:25:36:053]: Grabbed execution mutex.
        MSI (c) (F4:64) [05:25:36:053]: Incrementing counter to disable shutdown. Counter after increment: 0
        MSI (c) (F4:64) [05:25:36:053]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\" USERNAME="Viking" CLIENTPROCESSID="4596" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop"  ADDLOCAL=FlashPlayerAXInstaller
        MSI (s) (28:94) [05:25:36:069]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        MSI (s) (28:94) [05:25:36:069]: Grabbed execution mutex.
        MSI (s) (28:78) [05:25:36:069]: Resetting cached policy values
        MSI (s) (28:78) [05:25:36:069]: Machine policy value 'Debug' is 0
        MSI (s) (28:78) [05:25:36:069]: ******* RunEngine:
        ******* Action: INSTALL
        MSI (s) (28:78) [05:25:36:069]: Machine policy value 'DisableUserInstalls' is 0
        MSI (s) (28:78) [05:25:36:069]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
        MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
        MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
        MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
        MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
        MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
        MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
        MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
        MSI (s) (28:78) [05:25:36:084]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
        MSI (s) (28:78) [05:25:36:084]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
        MSI (s) (28:78) [05:25:36:084]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
        MSI (s) (28:78) [05:25:36:084]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
        MSI (s) (28:78) [05:25:36:084]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
        MSI (s) (28:78) [05:25:46:319]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 390.
        MSI (s) (28:78) [05:25:46:319]: File will have security applied from OpCode.
        MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
        MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
        MSI (s) (28:78) [05:25:46:538]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
        MSI (s) (28:78) [05:25:46:538]: End dialog not enabled
        MSI (s) (28:78) [05:25:46:538]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        MSI (s) (28:78) [05:25:46:538]: Package we're running from ==> C:\Windows\Installer\1201d91.msi
        MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: Compatibility mode property overrides found.
        MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: no matching ProductCode found in database.
        MSI (s) (28:78) [05:25:46:553]: MSCOREE not loaded loading copy from system32
        MSI (s) (28:78) [05:25:46:553]: Machine policy value 'TransformsSecure' is 0
        MSI (s) (28:78) [05:25:46:553]: User policy value 'TransformsAtSource' is 0
        MSI (s) (28:78) [05:25:46:553]: Note: 1: 2205 2:  3: MsiFileHash
        MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisablePatch' is 0
        MSI (s) (28:78) [05:25:46:553]: Machine policy value 'AllowLockdownPatch' is 0
        MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableLUAPatching' is 0
        MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableFlyWeightPatching' is 0
        MSI (s) (28:78) [05:25:46:553]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
        MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: no matching ProductCode found in database.
        MSI (s) (28:78) [05:25:46:553]: Transforms are not secure.
        MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
        MSI (s) (28:78) [05:25:46:553]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\ USERNAME=Viking CLIENTPROCESSID=4596 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
        MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
        MSI (s) (28:78) [05:25:46:553]: Product Code passed to Engine.Initialize:           ''
        MSI (s) (28:78) [05:25:46:553]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
        MSI (s) (28:78) [05:25:46:553]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
        MSI (s) (28:78) [05:25:46:553]: Product not registered: beginning first-time install
        MSI (s) (28:78) [05:25:46:553]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
        MSI (s) (28:78) [05:25:46:553]: MSI_LUA: Credential prompt not required, user is an admin
        MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
        MSI (s) (28:78) [05:25:46:553]: Entering CMsiConfigurationManager::SetLastUsedSource.
        MSI (s) (28:78) [05:25:46:553]: User policy value 'SearchOrder' is 'nmu'
        MSI (s) (28:78) [05:25:46:553]: Adding new sources is allowed.
        MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:569]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
        MSI (s) (28:78) [05:25:46:569]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
        MSI (s) (28:78) [05:25:46:569]: Note: 1: 2262 2: AdminProperties 3: -2147287038
        MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableMsi' is 0
        MSI (s) (28:78) [05:25:46:569]: Machine policy value 'AlwaysInstallElevated' is 0
        MSI (s) (28:78) [05:25:46:569]: User policy value 'AlwaysInstallElevated' is 0
        MSI (s) (28:78) [05:25:46:569]: Product installation will be elevated because user is admin and product is being installed per-machine.
        MSI (s) (28:78) [05:25:46:569]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
        MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'ffdbe6677a09a542b5e6559f7939deaf'.
        MSI (s) (28:78) [05:25:46:569]: RESTART MANAGER: Session opened.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:569]: Engine has iefSecondSequence set to true.
        MSI (s) (28:78) [05:25:46:569]: TRANSFORMS property is now:
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\'.
        MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
        MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
        MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
        MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
        MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
        MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
        MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
        MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
        MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
        MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
        MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
        MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
        MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
        MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
        MSI (s) (28:78) [05:25:46:616]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1201d91.msi'.
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
        MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MsiDisableEmbeddedUI' is 0
        MSI (s) (28:78) [05:25:46:616]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: PatchPackage
        MSI (s) (28:78) [05:25:46:616]: Machine policy value 'DisableRollback' is 0
        MSI (s) (28:78) [05:25:46:616]: User policy value 'DisableRollback' is 0
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
        MSI (s) (28:78) [05:25:46:616]: Doing action: INSTALL
        Action 05:25:46: INSTALL.
        Action start 05:25:46: INSTALL.
        MSI (s) (28:78) [05:25:46:616]: Running ExecuteSequence
        MSI (s) (28:78) [05:25:46:616]: Doing action: ISSetAllUsers
        Action 05:25:46: ISSetAllUsers.
        Action start 05:25:46: ISSetAllUsers.
        MSI (s) (28:78) [05:25:46:616]: Skipping action due to msidbCustomActionTypeFirstSequence option.
        Action ended 05:25:46: ISSetAllUsers. Return value 0.
        MSI (s) (28:78) [05:25:46:616]: Doing action: AppSearch
        Action 05:25:46: AppSearch. Searching for installed applications
        Action start 05:25:46: AppSearch.
        MSI (s) (28:78) [05:25:46:616]: Skipping AppSearch action: already done on client side
        Action ended 05:25:46: AppSearch. Return value 0.
        MSI (s) (28:78) [05:25:46:616]: Doing action: LaunchConditions
        Action 05:25:46: LaunchConditions. Evaluating launch conditions
        Action start 05:25:46: LaunchConditions.
        Action ended 05:25:46: LaunchConditions. Return value 1.
        MSI (s) (28:78) [05:25:46:616]: Doing action: FindRelatedProducts
        Action 05:25:46: FindRelatedProducts. Searching for related applications
        Action start 05:25:46: FindRelatedProducts.
        MSI (s) (28:78) [05:25:46:616]: Skipping FindRelatedProducts action: already done on client side
        Action ended 05:25:46: FindRelatedProducts. Return value 0.
        MSI (s) (28:78) [05:25:46:616]: Skipping action: CCPSearch (condition is false)
        MSI (s) (28:78) [05:25:46:616]: Skipping action: RMCCPSearch (condition is false)
        MSI (s) (28:78) [05:25:46:616]: Doing action: ValidateProductID
        Action 05:25:46: ValidateProductID.
        Action start 05:25:46: ValidateProductID.
        Action ended 05:25:46: ValidateProductID. Return value 1.
        MSI (s) (28:78) [05:25:46:616]: Doing action: CostInitialize
        Action 05:25:46: CostInitialize. Computing space requirements
        Action start 05:25:46: CostInitialize.
        MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MaxPatchCacheSize' is 10
        MSI (s) (28:78) [05:25:46:616]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
        MSI (s) (28:78) [05:25:46:616]: Baseline: New baseline 11.2.202 from transaction.
        MSI (s) (28:78) [05:25:46:616]: Baseline: Sorted order Native: Order 0.
        MSI (s) (28:78) [05:25:46:616]: Baseline Data Table:
        MSI (s) (28:78) [05:25:46:616]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
        MSI (s) (28:78) [05:25:46:616]: Baseline File Table:
        MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 2262 2: Patch 3: -2147287038
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
        MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: __MsiPatchFileList
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PatchPackage
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
        MSI (s) (28:78) [05:25:46:631]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
        Action ended 05:25:46: CostInitialize. Return value 1.
        MSI (s) (28:78) [05:25:46:631]: Doing action: FileCost
        Action 05:25:46: FileCost. Computing space requirements
        Action start 05:25:46: FileCost.
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiAssembly
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Class
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Extension
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: TypeLib
        Action ended 05:25:46: FileCost. Return value 1.
        MSI (s) (28:78) [05:25:46:631]: Doing action: IsolateComponents
        Action 05:25:46: IsolateComponents.
        Action start 05:25:46: IsolateComponents.
        Action ended 05:25:46: IsolateComponents. Return value 0.
        MSI (s) (28:78) [05:25:46:631]: Doing action: CostFinalize
        Action 05:25:46: CostFinalize. Computing space requirements
        Action start 05:25:46: CostFinalize.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Condition
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
        MSI (s) (28:78) [05:25:46:631]: Target path resolution complete. Dumping Directory table...
        MSI (s) (28:78) [05:25:46:631]: Note: target paths subject to change (via custom actions or browsing)
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TARGETDIR , Object: E:\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
        MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
        Action ended 05:25:46: CostFinalize. Return value 1.
        MSI (s) (28:78) [05:25:46:631]: Doing action: SetARPINSTALLLOCATION
        Action 05:25:46: SetARPINSTALLLOCATION.
        Action start 05:25:46: SetARPINSTALLLOCATION.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        Action ended 05:25:46: SetARPINSTALLLOCATION. Return value 1.
        MSI (s) (28:78) [05:25:46:631]: Doing action: SetODBCFolders
        Action 05:25:46: SetODBCFolders. Initializing ODBC directories
        Action start 05:25:46: SetODBCFolders.
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCDriver
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCTranslator
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
        Action ended 05:25:46: SetODBCFolders. Return value 0.
        MSI (s) (28:78) [05:25:46:631]: Doing action: MigrateFeatureStates
        Action 05:25:46: MigrateFeatureStates. Migrating feature states from related applications
        Action start 05:25:46: MigrateFeatureStates.
        MSI (s) (28:78) [05:25:46:631]: Skipping MigrateFeatureStates action: already done on client side
        Action ended 05:25:46: MigrateFeatureStates. Return value 0.
        MSI (s) (28:78) [05:25:46:631]: Doing action: InstallValidate
        Action 05:25:46: InstallValidate. Validating install
        Action start 05:25:46: InstallValidate.
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'ffdbe6677a09a542b5e6559f7939deaf'.
        MSI (s) (28:78) [05:25:46:631]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
        MSI (s) (28:78) [05:25:46:631]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
        MSI (s) (28:78) [05:25:46:631]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
        MSI (s) (28:78) [05:25:46:631]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: BindImage
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ProgId
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PublishComponent
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: SelfReg
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Font
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Shortcut
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: _RemoveFilePath
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiFileHash
        MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2727 2:
        MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: FilesInUse
        MSI (s) (28:78) [05:25:46:647]: Note: 1: 2727 2:
        Action ended 05:25:46: InstallValidate. Return value 1.
        MSI (s) (28:78) [05:25:46:647]: Doing action: RemoveExistingProducts
        Action 05:25:46: RemoveExistingProducts. Removing applications
        Action start 05:25:46: RemoveExistingProducts.
        Action ended 05:25:46: RemoveExistingProducts. Return value 1.
        MSI (s) (28:78) [05:25:46:663]: Doing action: InstallInitialize
        Action 05:25:46: InstallInitialize.
        Action start 05:25:46: InstallInitialize.
        MSI (s) (28:78) [05:25:46:663]: Machine policy value 'AlwaysInstallElevated' is 0
        MSI (s) (28:78) [05:25:46:663]: User policy value 'AlwaysInstallElevated' is 0
        MSI (s) (28:78) [05:25:46:663]: BeginTransaction: Locking Server
        MSI (s) (28:78) [05:25:46:663]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
        Action ended 05:25:50: InstallInitialize. Return value 1.
        MSI (s) (28:78) [05:25:50:538]: Skipping action: CallExeUninstaller (condition is false)
        MSI (s) (28:78) [05:25:50:538]: Doing action: MakePropsAvailable
        Action 05:25:50: MakePropsAvailable.
        Action start 05:25:50: MakePropsAvailable.
        MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
        Action ended 05:25:50: MakePropsAvailable. Return value 1.
        MSI (s) (28:78) [05:25:50:538]: Doing action: AllocateRegistrySpace
        Action 05:25:50: AllocateRegistrySpace. Allocating registry space
        Action start 05:25:50: AllocateRegistrySpace.
        Action ended 05:25:50: AllocateRegistrySpace. Return value 1.
        MSI (s) (28:78) [05:25:50:538]: Doing action: ProcessComponents
        Action 05:25:50: ProcessComponents. Updating component registration
        Action start 05:25:50: ProcessComponents.
        MSI (s) (28:78) [05:25:50:538]: Note: 1: 2205 2:  3: MsiPatchCertificate
        MSI (s) (28:78) [05:25:50:538]: LUA patching is disabled: missing MsiPatchCertificate table
        MSI (s) (28:78) [05:25:50:538]: Resolving source.
        MSI (s) (28:78) [05:25:50:538]: Resolving source to launched-from source.
        MSI (s) (28:78) [05:25:50:538]: Setting launched-from source as last-used.
        MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
        MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
        MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
        MSI (s) (28:78) [05:25:50:538]: SOURCEDIR ==> C:\Users\Admin\Desktop\
        MSI (s) (28:78) [05:25:50:538]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
        MSI (s) (28:78) [05:25:50:538]: Determining source type
        MSI (s) (28:78) [05:25:50:553]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
        MSI (s) (28:78) [05:25:50:553]: Source path resolution complete. Dumping Directory table...
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
        MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
        Action 05:25:50: GenerateScript. Generating script operations for action:
        GenerateScript: Updating component registration
        Action ended 05:25:50: ProcessComponents. Return value 1.
        MSI (s) (28:78) [05:25:50:553]: Doing action: UnpublishComponents
        Action 05:25:50: UnpublishComponents. Unpublishing Qualified Components
        Action start 05:25:50: UnpublishComponents.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: PublishComponent
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: UnpublishComponents. Return value 0.
        MSI (s) (28:78) [05:25:50:569]: Doing action: MsiUnpublishAssemblies
        Action 05:25:50: MsiUnpublishAssemblies. Unpublishing assembly information
        Action start 05:25:50: MsiUnpublishAssemblies.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: MsiAssembly
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: MsiUnpublishAssemblies. Return value 0.
        MSI (s) (28:78) [05:25:50:569]: Doing action: UnpublishFeatures
        Action 05:25:50: UnpublishFeatures. Unpublishing product features
        Action start 05:25:50: UnpublishFeatures.
        Action ended 05:25:50: UnpublishFeatures. Return value 1.
        MSI (s) (28:78) [05:25:50:569]: Doing action: StopServices
        Action 05:25:50: StopServices. Stopping services
        Action start 05:25:50: StopServices.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: ServiceControl
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
        Action ended 05:25:50: StopServices. Return value 1.
        MSI (s) (28:78) [05:25:50:569]: Doing action: DeleteServices
        Action 05:25:50: DeleteServices. Deleting services
        Action start 05:25:50: DeleteServices.
        Action ended 05:25:50: DeleteServices. Return value 1.
        MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterComPlus
        Action 05:25:50: UnregisterComPlus. Unregistering COM+ Applications and Components
        Action start 05:25:50: UnregisterComPlus.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: Complus
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
        Action ended 05:25:50: UnregisterComPlus. Return value 0.
        MSI (s) (28:78) [05:25:50:569]: Doing action: SelfUnregModules
        Action 05:25:50: SelfUnregModules. Unregistering modules
        Action start 05:25:50: SelfUnregModules.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: SelfReg
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
        Action ended 05:25:50: SelfUnregModules. Return value 1.
        MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterTypeLibraries
        Action 05:25:50: UnregisterTypeLibraries. Unregistering type libraries
        Action start 05:25:50: UnregisterTypeLibraries.
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: TypeLib
        MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
        Action ended 05:25:50: UnregisterTypeLibraries. Return value 0.
        MSI (s) (28:78) [05:25:50:569]: Doing action: RemoveODBC
        Action 05:25:50: RemoveODBC. Removing ODBC components
        Action start 05:25:50: RemoveODBC.
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDataSource
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCTranslator
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDriver
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager
        1: Removing ODBC components
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager64
        Action ended 05:25:50: RemoveODBC. Return value 1.
        MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterFonts
        Action 05:25:50: UnregisterFonts. Unregistering fonts
        Action start 05:25:50: UnregisterFonts.
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Font
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
        Action ended 05:25:50: UnregisterFonts. Return value 1.
        MSI (s) (28:78) [05:25:50:584]: Doing action: RemoveRegistryValues
        Action 05:25:50: RemoveRegistryValues. Removing system registry values
        Action start 05:25:50: RemoveRegistryValues.
        Action ended 05:25:50: RemoveRegistryValues. Return value 1.
        MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterClassInfo
        Action 05:25:50: UnregisterClassInfo. Unregister class servers
        Action start 05:25:50: UnregisterClassInfo.
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Class
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: UnregisterClassInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterExtensionInfo
        Action 05:25:50: UnregisterExtensionInfo. Unregistering extension servers
        Action start 05:25:50: UnregisterExtensionInfo.
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Extension
        MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: UnregisterExtensionInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterProgIdInfo
        Action 05:25:50: UnregisterProgIdInfo. Unregistering program identifiers
        Action start 05:25:50: UnregisterProgIdInfo.
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: ProgId
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: UnregisterProgIdInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:600]: Doing action: UnregisterMIMEInfo
        Action 05:25:50: UnregisterMIMEInfo. Unregistering MIME info
        Action start 05:25:50: UnregisterMIMEInfo.
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: MIME
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: UnregisterMIMEInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveIniValues
        Action 05:25:50: RemoveIniValues. Removing INI file entries
        Action start 05:25:50: RemoveIniValues.
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: IniFile
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
        Action ended 05:25:50: RemoveIniValues. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveShortcuts
        Action 05:25:50: RemoveShortcuts. Removing shortcuts
        Action start 05:25:50: RemoveShortcuts.
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Shortcut
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
        Action ended 05:25:50: RemoveShortcuts. Return value 0.
        MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveEnvironmentStrings
        Action 05:25:50: RemoveEnvironmentStrings. Updating environment strings
        Action start 05:25:50: RemoveEnvironmentStrings.
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Environment
        MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
        Action ended 05:25:50: RemoveEnvironmentStrings. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveDuplicateFiles
        Action 05:25:50: RemoveDuplicateFiles. Removing duplicated files
        Action start 05:25:50: RemoveDuplicateFiles.
        Action ended 05:25:50: RemoveDuplicateFiles. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveFolders
        Action 05:25:50: RemoveFolders. Removing folders
        Action start 05:25:50: RemoveFolders.
        Action ended 05:25:50: RemoveFolders. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: CreateFolders
        Action 05:25:50: CreateFolders. Creating folders
        Action start 05:25:50: CreateFolders.
        CreateFolders: Folder: Creating folders
        Action ended 05:25:50: CreateFolders. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: MoveFiles
        Action 05:25:50: MoveFiles. Moving files
        Action start 05:25:50: MoveFiles.
        Action ended 05:25:50: MoveFiles. Return value 1.
        MSI (s) (28:78) [05:25:50:600]: Doing action: InstallFiles
        Action 05:25:50: InstallFiles. Copying new files
        Action start 05:25:50: InstallFiles.
        MSI (s) (28:78) [05:25:50:616]: Dumping binary patch manager data...
        MSI (s) (28:78) [05:25:50:616]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
        InstallFiles: File: Copying new files,  Directory: ,  Size:
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiSFCBypass
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
        MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: PatchPackage
        Action ended 05:25:50: InstallFiles. Return value 1.
        MSI (s) (28:78) [05:25:50:616]: Doing action: NewCustomAction1
        Action 05:25:50: NewCustomAction1.
        Action start 05:25:50: NewCustomAction1.
        NewCustomAction1:
        Action ended 05:25:50: NewCustomAction1. Return value 1.
        MSI (s) (28:78) [05:25:50:616]: Doing action: PatchFiles
        Action 05:25:50: PatchFiles. Patching files
        Action start 05:25:50: PatchFiles.
        Action ended 05:25:50: PatchFiles. Return value 1.
        MSI (s) (28:78) [05:25:50:616]: Doing action: DuplicateFiles
        Action 05:25:50: DuplicateFiles. Creating duplicate files
        Action start 05:25:50: DuplicateFiles.
        Action ended 05:25:50: DuplicateFiles. Return value 1.
        MSI (s) (28:78) [05:25:50:616]: Doing action: BindImage
        Action 05:25:50: BindImage. Binding executables
        Action start 05:25:50: BindImage.
        Action ended 05:25:50: BindImage. Return value 1.
        MSI (s) (28:78) [05:25:50:631]: Doing action: CreateShortcuts
        Action 05:25:50: CreateShortcuts. Creating shortcuts
        Action start 05:25:50: CreateShortcuts.
        CreateShortcuts: Shortcut: Creating shortcuts
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Shortcut
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
        Action ended 05:25:50: CreateShortcuts. Return value 0.
        MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterClassInfo
        Action 05:25:50: RegisterClassInfo. Registering class servers
        Action start 05:25:50: RegisterClassInfo.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Class
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
        Action ended 05:25:50: RegisterClassInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterExtensionInfo
        Action 05:25:50: RegisterExtensionInfo. Registering extension servers
        Action start 05:25:50: RegisterExtensionInfo.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Extension
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
        Action ended 05:25:50: RegisterExtensionInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterProgIdInfo
        Action 05:25:50: RegisterProgIdInfo. Registering program identifiers
        Action start 05:25:50: RegisterProgIdInfo.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: ProgId
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
        Action ended 05:25:50: RegisterProgIdInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterMIMEInfo
        Action 05:25:50: RegisterMIMEInfo. Registering MIME info
        Action start 05:25:50: RegisterMIMEInfo.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: MIME
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
        Action ended 05:25:50: RegisterMIMEInfo. Return value 0.
        MSI (s) (28:78) [05:25:50:631]: Doing action: WriteRegistryValues
        Action 05:25:50: WriteRegistryValues. Writing system registry values
        Action start 05:25:50: WriteRegistryValues.
        WriteRegistryValues: Key: Writing system registry values, Name: , Value:
        Action ended 05:25:50: WriteRegistryValues. Return value 1.
        MSI (s) (28:78) [05:25:50:631]: Doing action: WriteIniValues
        Action 05:25:50: WriteIniValues. Writing INI file values
        Action start 05:25:50: WriteIniValues.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: IniFile
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
        Action ended 05:25:50: WriteIniValues. Return value 1.
        MSI (s) (28:78) [05:25:50:631]: Doing action: WriteEnvironmentStrings
        Action 05:25:50: WriteEnvironmentStrings. Updating environment strings
        Action start 05:25:50: WriteEnvironmentStrings.
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Environment
        MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
        Action ended 05:25:50: WriteEnvironmentStrings. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterFonts
        Action 05:25:50: RegisterFonts. Registering fonts
        Action start 05:25:50: RegisterFonts.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Font
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
        Action ended 05:25:50: RegisterFonts. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: InstallODBC
        Action 05:25:50: InstallODBC. Installing ODBC components
        Action start 05:25:50: InstallODBC.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager64
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDriver
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`, `Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCTranslator
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileNam e`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDataSource
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
        Action ended 05:25:50: InstallODBC. Return value 0.
        MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterTypeLibraries
        Action 05:25:50: RegisterTypeLibraries. Registering type libraries
        Action start 05:25:50: RegisterTypeLibraries.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: TypeLib
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
        Action ended 05:25:50: RegisterTypeLibraries. Return value 0.
        MSI (s) (28:78) [05:25:50:647]: Doing action: SelfRegModules
        Action 05:25:50: SelfRegModules. Registering modules
        Action start 05:25:50: SelfRegModules.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: SelfReg
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
        Action ended 05:25:50: SelfRegModules. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterComPlus
        Action 05:25:50: RegisterComPlus. Registering COM+ Applications and Components
        Action start 05:25:50: RegisterComPlus.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Complus
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
        Action ended 05:25:50: RegisterComPlus. Return value 0.
        MSI (s) (28:78) [05:25:50:647]: Doing action: InstallServices
        Action 05:25:50: InstallServices. Installing new services
        Action start 05:25:50: InstallServices.
        MSI (s) (28:78) [05:25:50:647]: Detected older ServiceInstall table schema
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceInstall
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrder Group`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Argume nts` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
        Action ended 05:25:50: InstallServices. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: StartServices
        Action 05:25:50: StartServices. Starting services
        Action start 05:25:50: StartServices.
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceControl
        MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
        Action ended 05:25:50: StartServices. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterUser
        Action 05:25:50: RegisterUser. Registering user
        Action start 05:25:50: RegisterUser.
        RegisterUser: Registering user
        Action ended 05:25:50: RegisterUser. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterProduct
        Action 05:25:50: RegisterProduct. Registering product
        Action start 05:25:50: RegisterProduct.
        RegisterProduct: Registering product
        MSI (s) (28:78) [05:25:50:647]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
        Action ended 05:25:50: RegisterProduct. Return value 1.
        MSI (s) (28:78) [05:25:50:647]: Doing action: PublishComponents
        Action 05:25:50: PublishComponents. Publishing qualified components
        Action start 05:25:50: PublishComponents.
        MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: PublishComponent
        MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
        Action ended 05:25:50: PublishComponents. Return value 0.
        MSI (s) (28:78) [05:25:50:663]: Doing action: MsiPublishAssemblies
        Action 05:25:50: MsiPublishAssemblies. Publishing assembly information
        Action start 05:25:50: MsiPublishAssemblies.
        MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: MsiAssembly
        MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
        Action ended 05:25:50: MsiPublishAssemblies. Return value 0.
        MSI (s) (28:78) [05:25:50:663]: Doing action: PublishFeatures
        Action 05:25:50: PublishFeatures. Publishing product features
        Action start 05:25:50: PublishFeatures.
        PublishFeatures: Feature: Publishing product features
        Action ended 05:25:50: PublishFeatures. Return value 1.
        MSI (s) (28:78) [05:25:50:663]: Doing action: PublishProduct
        Action 05:25:50: PublishProduct. Publishing product information
        Action start 05:25:50: PublishProduct.
        1: Publishing product information
        Action ended 05:25:50: PublishProduct. Return value 1.
        MSI (s) (28:78) [05:25:50:663]: Skipping action: ScheduleReboot (condition is false)
        MSI (s) (28:78) [05:25:50:663]: Doing action: InstallFinalize
        Action 05:25:50: InstallFinalize.
        Action start 05:25:50: InstallFinalize.
        MSI (s) (28:78) [05:25:50:663]: Running Script: C:\Windows\Installer\MSI2E1D.tmp
        MSI (s) (28:78) [05:25:50:663]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
        MSI (s) (28:78) [05:25:50:663]: Machine policy value 'DisableRollback' is 0
        MSI (s) (28:78) [05:25:50:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
        MSI (s) (28:78) [05:25:50:678]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824, ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680 650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101- 488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymen tFlags=3)
        MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=0,Argument=1033)
        MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
        MSI (s) (28:78) [05:25:50:678]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
        MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=0,)
        MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=1,)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
        Action 5:25:50: ProcessComponents. Updating component registration
        MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\s ystem32\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
        1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
        MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\Ad~ 1\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=1)
        1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe
        MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
        Action 5:25:50: RemoveODBC. Removing ODBC components
        MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=0)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=1)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
        Action 5:25:50: CreateFolders. Creating folders
        MSI (s) (28:78) [05:25:50:678]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
        CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
        MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
        Action 5:25:50: InstallFiles. Copying new files
        MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
        MSI (s) (28:78) [05:25:50:678]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
        MSI (s) (28:78) [05:25:50:678]: Executing op: SetSourceFolder(Folder=1\Temp\)
        MSI (s) (28:78) [05:25:50:678]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Instal ler\1201d91.msi,,,,,IsFirstPhysicalMedia=1)
        MSI (s) (28:78) [05:25:50:678]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=InstallAX64.exe,DestName=In stallAX64.exe,Attributes=16384,FileSize=8767136,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC= 0,Version=11.2.202.228,Language=1033,InstallMode=58982400,,,,,,,)
        MSI (s) (28:78) [05:25:50:678]: File: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
        MSI (s) (28:78) [05:25:50:678]: Source for file 'InstallAX64.exe' is compressed
        InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Ad~1\AppData\Local\Temp\,  Size: 8767136
        MSI (s) (28:78) [05:25:50:772]: Executing op: CacheSizeFlush(,)
        MSI (s) (28:78) [05:25:50:772]: Executing op: ActionStart(Name=NewCustomAction1,,)
        Action 5:25:50: NewCustomAction1.
        MSI (s) (28:78) [05:25:50:772]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\Ad~1\AppData \Local\Temp\InstallAX64.exe,Target=-install -msi,)
        CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
        MSI (s) (28:78) [05:25:53:788]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
        Info 2835.The control ErrorIcon was not found on dialog SetupError.
        Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
        MSI (s) (28:78) [05:25:58:694]: Product: Adobe Flash Player 11 ActiveX (x64) -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
        Action ended 05:25:58: InstallFinalize. Return value 3.
        MSI (s) (28:78) [05:25:58:694]: User policy value 'DisableRollback' is 0
        MSI (s) (28:78) [05:25:58:694]: Machine policy value 'DisableRollback' is 0
        MSI (s) (28:78) [05:25:58:694]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824, ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
        MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=0,Argument=1033)
        MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
        MSI (s) (28:78) [05:25:58:694]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
        Action 5:25:58: Rollback. Rolling back action:
        Rollback: NewCustomAction1
        MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=NewCustomAction1,,)
        MSI (s) (28:78) [05:25:58:694]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680 650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101- 488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymen tFlags=3)
        Rollback: Copying new files
        MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
        MSI (s) (28:78) [05:25:58:694]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
        MSI (s) (28:78) [05:25:58:694]: Executing op: FileRemove(,FileName=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,,)
        Rollback: Creating folders
        MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
        MSI (s) (28:78) [05:25:58:709]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,SecurityDescriptor=Bina ryData,)
        Rollback: Removing ODBC components
        MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
        Rollback: Updating component registration
        MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
        MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},ProductKey={5C804E BB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
        MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},ProductKey={5C804E BB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
        MSI (s) (28:78) [05:25:58:709]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
        MSI (s) (28:78) [05:25:58:709]: Error in rollback skipped. Return: 5
        MSI (s) (28:78) [05:25:58:709]: Note: 1: 2318 2:
        MSI (s) (28:78) [05:25:58:709]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 390, szDescription: "".
        MSI (s) (28:78) [05:25:58:709]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
        MSI (s) (28:78) [05:25:58:709]: Unlocking Server
        MSI (s) (28:78) [05:25:59:350]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
        Action ended 05:25:59: INSTALL. Return value 3.
        Property(S): DiskPrompt = [1]
        Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
        Property(S): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
        Property(S): ProductToBeRegistered = 1
        Property(S): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
        Property(S): SOURCEDIR = C:\Users\Admin\Desktop\
        Property(S): VersionNT = 601
        Property(S): TARGETDIR = E:\
        Property(S): ALLUSERSPROFILE = C:\ProgramData\
        Property(S): PrimaryVolumeSpaceRemaining = 0
        Property(S): PrimaryVolumeSpaceRequired = 0
        Property(S): PrimaryVolumeSpaceAvailable = 0
        Property(S): OutOfNoRbDiskSpace = 0
        Property(S): OutOfDiskSpace = 0
        Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
        Property(S): MACROMED = C:\Windows\system32\Macromed\
        Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
        Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
        Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
        Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
        Property(S): System64Folder = C:\Windows\system32\
        Property(S): CostingComplete = 1
        Property(S): SourceDir = C:\Users\Admin\Desktop\
        Property(S): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
        Property(S): USERPROFILE = C:\Users\Admin\
        Property(S): Preselected = 1
        Property(S): UILevel = 5
        Property(S): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        Property(S): DATABASE = C:\Windows\Installer\1201d91.msi
        Property(S): Privileged = 1
        Property(S): MsiRunningElevated = 1
        Property(S): RedirectedDllSupport = 2
        Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
        Property(S): MsiNetAssemblySupport = 4.0.30319.1
        Property(S): Date = 4/12/2012
        Property(S): Time = 5:25:59
        Property(S): TTCSupport = 1
        Property(S): ColorBits = 32
        Property(S): TextInternalLeading = 3
        Property(S): TextHeight = 16
        Property(S): BorderSide = 1
        Property(S): BorderTop = 1
        Property(S): CaptionHeight = 22
        Property(S): ScreenY = 768
        Property(S): ISCHECKFORPRODUCTUPDATES = 1
        Property(S): ApplicationUsers = AllUsers
        Property(S): AgreeToLicense = No
        Property(S): _IsMaintenance = Change
        Property(S): RestartManagerOption = CloseRestart
        Property(S): IS_SQLSERVER_USERNAME = sa
        Property(S): IS_SQLSERVER_AUTHENTICATION = 0
        Property(S): SetupType = Typical
        Property(S): _IsSetupTypeMin = Typical
        Property(S): Display_IsBitmapDlg = 1
        Property(S): ScreenX = 1024
        Property(S): ProductName = Adobe Flash Player 11 ActiveX (x64)
        Property(S): ALLUSERS = 1
        Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
        Property(S): ARPNOMODIFY = 1
        Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
        Property(S): ARPURLINFOABOUT = http://www.adobe.com
        Property(S): SystemLanguageID = 1033
        Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
        Property(S): DWUSINTERVAL = 30
        Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
        Property(S): DefaultUIFont = Tahoma8
        Property(S): DialogCaption = InstallShield for Windows Installer
        Property(S): DisplayNameCustom = Custom
        Property(S): DisplayNameMinimal = Minimal
        Property(S): DisplayNameTypical = Typical
        Property(S): ErrorDialog = SetupError
        Property(S): INSTALLLEVEL = 100
        Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
        Property(S): ISVROOT_PORT_NO = 0
        Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
        Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
        Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
        Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
        Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
        Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
        Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
        Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
        Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
        Property(S): InstallChoice = AR
        Property(S): Manufacturer = Adobe Systems Incorporated
        Property(S): MsiLogging = voicewarmupx
        Property(S): NewProperty2 = 0
        Property(S): NewProperty3 = 0
        Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
        Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
        Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
        Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
        Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
        Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
        Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
        Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
        Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
        Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
        Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
        Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
        Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
        Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
        Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
        Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
        Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
        Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
        Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
        Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
        Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
        Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
        Property(S): ProductID = none
        Property(S): ProductLanguage = 1033
        Property(S): ProductVersion = 11.2.202.228
        Property(S): ProgressType0 = install
        Property(S): ProgressType1 = Installing
        Property(S): ProgressType2 = installed
        Property(S): ProgressType3 = installs
        Property(S): RebootYesNo = Yes
        Property(S): ReinstallModeText = omus
        Property(S): SHOWLAUNCHPROGRAM = 0
        Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
        Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
        Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
        Property(S): ARPINSTALLLOCATION = C:\Windows\system32\Macromed\Flash\
        Property(S): ComputerName = NSDQ01
        Property(S): UserLanguageID = 1033
        Property(S): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
        Property(S): LogonUser = Admin
        Property(S): AdminUser = 1
        Property(S): MsiTrueAdminUser = 1
        Property(S): VirtualMemory = 6406
        Property(S): PhysicalMemory = 4094
        Property(S): Intel = 6
        Property(S): Msix64 = 6
        Property(S): MsiAMD64 = 6
        Property(S): ShellAdvtSupport = 1
        Property(S): OLEAdvtSupport = 1
        Property(S): GPTSupport = 1
        Property(S): FontsFolder = C:\Windows\Fonts\
        Property(S): DesktopFolder = C:\Users\Public\Desktop\
        Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
        Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
        Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
        Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
        Property(S): MyPicturesFolder = C:\Users\Admin\Pictures\
        Property(S): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
        Property(S): CommonAppDataFolder = C:\ProgramData\
        Property(S): USERNAME = Viking
        Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
        Property(S): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
        Property(S): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
        Property(S): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
        Property(S): PersonalFolder = C:\Users\Admin\Documents\
        Property(S): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
        Property(S): FavoritesFolder = C:\Users\Admin\Favorites\
        Property(S): AppDataFolder = C:\Users\Admin\AppData\Roaming\
        Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
        Property(S): ProgramFiles64Folder = C:\Program Files\
        Property(S): ProgramFilesFolder = C:\Program Files (x86)\
        Property(S): RemoteAdminTS = 1
        Property(S): SystemFolder = C:\Windows\SysWOW64\
        Property(S): WindowsVolume = C:\
        Property(S): WindowsFolder = C:\Windows\
        Property(S): MsiNTProductType = 1
        Property(S): ServicePackLevelMinor = 0
        Property(S): ServicePackLevel = 1
        Property(S): WindowsBuild = 7601
        Property(S): VersionNT64 = 601
        Property(S): VersionMsi = 5.00
        Property(S): MsiSystemRebootPending = 1
        Property(S): ADDLOCAL = FlashPlayerAXInstaller
        Property(S): CURRENTDIRECTORY = C:\Users\Admin\Desktop
        Property(S): CLIENTUILEVEL = 0
        Property(S): CLIENTPROCESSID = 4596
        Property(S): VersionDatabase = 200
        Property(S): ACTION = INSTALL
        Property(S): EXECUTEACTION = INSTALL
        Property(S): ROOTDRIVE = E:\
        Property(S): SECONDSEQUENCE = 1
        Property(S): PackagecodeChanging = 1
        Property(S): ProductState = -1
        Property(S): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
        Property(S): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
        MSI (s) (28:78) [05:25:59:366]: MainEngineThread is returning 1603
        MSI (s) (28:94) [05:25:59:366]: RESTART MANAGER: Session closed.
        MSI (s) (28:94) [05:25:59:366]: User policy value 'DisableRollback' is 0
        MSI (s) (28:94) [05:25:59:366]: Machine policy value 'DisableRollback' is 0
        MSI (s) (28:94) [05:25:59:366]: Incrementing counter to disable shutdown. Counter after increment: 0
        MSI (s) (28:94) [05:25:59:366]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
        MSI (s) (28:94) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
        MSI (s) (28:94) [05:25:59:381]: Restoring environment variables
        MSI (c) (F4:64) [05:25:59:381]: Back from server. Return value: 1603
        MSI (c) (F4:64) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
        MSI (c) (F4:64) [05:25:59:381]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
        Action ended 05:25:59: ExecuteAction. Return value 3.
        MSI (c) (F4:64) [05:25:59:381]: Doing action: SetupCompleteError
        Action 05:25:59: SetupCompleteError.
        Action start 05:25:59: SetupCompleteError.
        Action 05:25:59: SetupCompleteError. Dialog created
        Action ended 05:26:00: SetupCompleteError. Return value 2.
        Action ended 05:26:00: INSTALL. Return value 3.
        MSI (c) (F4:64) [05:26:00:694]: Destroying RemoteAPI object.
        MSI (c) (F4:DC) [05:26:00:709]: Custom Action Manager thread ending.
        Property(C): DiskPrompt = [1]
        Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
        Property(C): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
        Property(C): PrimaryVolumeSpaceRemaining = 0
        Property(C): PrimaryVolumeSpaceRequired = 0
        Property(C): PrimaryVolumeSpaceAvailable = 0
        Property(C): OutOfNoRbDiskSpace = 0
        Property(C): OutOfDiskSpace = 0
        Property(C): VersionNT = 601
        Property(C): TARGETDIR = E:\
        Property(C): ALLUSERSPROFILE = C:\ProgramData\
        Property(C): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
        Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
        Property(C): MACROMED = C:\Windows\system32\Macromed\
        Property(C): FLASH = C:\Windows\system32\Macromed\Flash\
        Property(C): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
        Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
        Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
        Property(C): System64Folder = C:\Windows\system32\
        Property(C): CostingComplete = 1
        Property(C): ROOTDRIVE = E:\
        Property(C): SourceDir = C:\Users\Admin\Desktop\
        Property(C): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
        Property(C): USERPROFILE = C:\Users\Admin\
        Property(C): EXECUTEACTION = INSTALL
        Property(C): ACTION = INSTALL
        Property(C): UILevel = 5
        Property(C): VersionHandler = 5.00
        Property(C): SOURCEDIR = C:\Users\Admin\Desktop\
        Property(C): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        Property(C): DATABASE = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
        Property(C): Privileged = 1
        Property(C): MsiRunningElevated = 1
        Property(C): RedirectedDllSupport = 2
        Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
        Property(C): MsiNetAssemblySupport = 4.0.30319.1
        Property(C): Date = 4/12/2012
        Property(C): Time = 05:26:00
        Property(C): TTCSupport = 1
        Property(C): ISCHECKFORPRODUCTUPDATES = 1
        Property(C): ApplicationUsers = AllUsers
        Property(C): AgreeToLicense = No
        Property(C): _IsMaintenance = Change
        Property(C): RestartManagerOption = CloseRestart
        Property(C): IS_SQLSERVER_USERNAME = sa
        Property(C): IS_SQLSERVER_AUTHENTICATION = 0
        Property(C): SetupType = Typical
        Property(C): _IsSetupTypeMin = Typical
        Property(C): Display_IsBitmapDlg = 1
        Property(C): ProductName = Adobe Flash Player 11 ActiveX (x64)
        Property(C): ALLUSERS = 1
        Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
        Property(C): ARPNOMODIFY = 1
        Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
        Property(C): ARPURLINFOABOUT = http://www.adobe.com
        Property(C): ColorBits = 32
        Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
        Property(C): DWUSINTERVAL = 30
        Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
        Property(C): DefaultUIFont = Tahoma8
        Property(C): DialogCaption = InstallShield for Windows Installer
        Property(C): DisplayNameCustom = Custom
        Property(C): DisplayNameMinimal = Minimal
        Property(C): DisplayNameTypical = Typical
        Property(C): ErrorDialog = SetupError
        Property(C): INSTALLLEVEL = 100
        Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
        Property(C): ISVROOT_PORT_NO = 0
        Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
        Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
        Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
        Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
        Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
        Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
        Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
        Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
        Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
        Property(C): InstallChoice = AR
        Property(C): Manufacturer = Adobe Systems Incorporated
        Property(C): MsiLogging = voicewarmupx
        Property(C): NewProperty2 = 0
        Property(C): NewProperty3 = 0
        Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
        Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
        Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
        Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
        Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
        Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
        Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
        Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
        Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
        Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
        Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
        Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
        Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
        Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
        Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
        Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
        Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
        Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
        Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
        Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
        Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
        Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
        Property(C): ProductID = none
        Property(C): ProductLanguage = 1033
        Property(C): ProductVersion = 11.2.202.228
        Property(C): ProgressType0 = install
        Property(C): ProgressType1 = Installing
        Property(C): ProgressType2 = installed
        Property(C): ProgressType3 = installs
        Property(C): RebootYesNo = Yes
        Property(C): ReinstallModeText = omus
        Property(C): SHOWLAUNCHPROGRAM = 0
        Property(C): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
        Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
        Property(C): TextInternalLeading = 3
        Property(C): TextHeight = 16
        Property(C): BorderSide = 1
        Property(C): BorderTop = 1
        Property(C): AdminUser = 1
        Property(C): CaptionHeight = 22
        Property(C): ScreenY = 1080
        Property(C): ScreenX = 1920
        Property(C): SystemLanguageID = 1033
        Property(C): ComputerName = NSDQ01
        Property(C): UserLanguageID = 1033
        Property(C): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
        Property(C): LogonUser = Admin
        Property(C): MsiTrueAdminUser = 1
        Property(C): VirtualMemory = 6439
        Property(C): PhysicalMemory = 4094
        Property(C): Intel = 6
        Property(C): Msix64 = 6
        Property(C): MsiAMD64 = 6
        Property(C): ShellAdvtSupport = 1
        Property(C): OLEAdvtSupport = 1
        Property(C): GPTSupport = 1
        Property(C): FontsFolder = C:\Windows\Fonts\
        Property(C): DesktopFolder = C:\Users\Public\Desktop\
        Property(C): USERNAME = Viking
        Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
        Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
        Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
        Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
        Property(C): MyPicturesFolder = C:\Users\Admin\Pictures\
        Property(C): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
        Property(C): CommonAppDataFolder = C:\ProgramData\
        Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
        Property(C): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
        Property(C): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
        Property(C): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
        Property(C): PersonalFolder = C:\Users\Admin\Documents\
        Property(C): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
        Property(C): FavoritesFolder = C:\Users\Admin\Favorites\
        Property(C): AppDataFolder = C:\Users\Admin\AppData\Roaming\
        Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
        Property(C): ProgramFiles64Folder = C:\Program Files\
        Property(C): ProgramFilesFolder = C:\Program Files (x86)\
        Property(C): RemoteAdminTS = 1
        Property(C): SystemFolder = C:\Windows\SysWOW64\
        Property(C): WindowsVolume = C:\
        Property(C): WindowsFolder = C:\Windows\
        Property(C): MsiNTProductType = 1
        Property(C): ServicePackLevelMinor = 0
        Property(C): ServicePackLevel = 1
        Property(C): WindowsBuild = 7601
        Property(C): VersionNT64 = 601
        Property(C): VersionMsi = 5.00
        Property(C): VersionDatabase = 200
        Property(C): MsiSystemRebootPending = 1
        Property(C): CLIENTPROCESSID = 4596
        Property(C): CLIENTUILEVEL = 0
        Property(C): CURRENTDIRECTORY = C:\Users\Admin\Desktop
        Property(C): PackagecodeChanging = 1
        Property(C): ProductState = -1
        Property(C): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
        Property(C): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
        === Logging stopped: 4/12/2012  05:26:00 ===
        MSI (c) (F4:64) [05:26:00:709]: Note: 1: 1708
        MSI (c) (F4:64) [05:26:00:709]: Product: Adobe Flash Player 11 ActiveX (x64) -- Installation operation failed.
        MSI (c) (F4:64) [05:26:00:709]: Windows Installer installed the product. Product Name: Adobe Flash Player 11 ActiveX (x64). Product Version: 11.2.202.228. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
        MSI (c) (F4:64) [05:26:00:709]: Grabbed execution mutex.
        MSI (c) (F4:64) [05:26:00:709]: Cleaning up uninstalled install packages, if any exist
        MSI (c) (F4:64) [05:26:00:709]: MainEngineThread is returning 1603
        === Verbose logging stopped: 4/12/2012  05:26:00 ===
