For the last month or so I've been having problems downloading BBCiplayer so I tried downloading Adobe AIR on its own and that was fine although iplayer still didn't work so I uninstalled AIR. Anyway today I thought I'd retry my luck and I attempted to download AIR again but time I'm getting this message: An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
I hope I've done this correctly but the log files are below. Please note that I've already tried to use the windows fixit program that's been linked in other threads but that hasn't worked either. Please help.
[2011-10-15:17:08:41] Application Installer end with exit code 0
[2011-10-15:17:08:41] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:41] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.15832900628447533 onApplicationVersion
[2011-10-15:17:08:41] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:41] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.05353033496066928 onApplicationVersion
[2011-10-15:17:08:42] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:42] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.09053797228261828 onApplicationVersion
[2011-10-15:17:08:42] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:42] Application Installer end with exit code 0
[2011-10-15:17:08:42] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.036973283626139164 onApplicationVersion
[2011-10-15:17:08:43] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:43] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5064086625352502 onApplicationVersion
[2011-10-15:17:08:43] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:43] Application Installer end with exit code 0
[2011-10-15:17:08:44] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:44] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.09705144492909312 onApplicationVersion
[2011-10-15:17:08:44] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:44] Application Installer end with exit code 0
[2011-10-15:17:08:44] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.09935963898897171 onApplicationVersion
[2011-10-15:17:08:44] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6277109226211905 onApplicationVersion
[2011-10-15:17:08:45] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:45] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8247216655872762 onApplicationVersion
[2011-10-15:17:08:45] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:45] Application Installer end with exit code 0
[2011-10-15:17:08:45] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8871690081432462 onApplicationVersion
[2011-10-15:17:08:46] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:46] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7843382293358445 onApplicationVersion
[2011-10-15:17:08:46] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:46] Application Installer end with exit code 0
[2011-10-15:17:08:47] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:47] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4415894574485719 onApplicationVersion
[2011-10-15:17:08:47] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:47] Application Installer end with exit code 0
[2011-10-15:17:08:47] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5712991305626929 onApplicationVersion
[2011-10-15:17:08:47] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6200988343916833 onApplicationVersion
[2011-10-15:17:08:48] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:48] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.053208133671432734 onApplicationVersion
[2011-10-15:17:08:48] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:48] Application Installer end with exit code 0
[2011-10-15:17:08:48] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8560211127623916 onApplicationVersion
[2011-10-15:17:08:49] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:49] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.40506770927459 onApplicationVersion
[2011-10-15:17:08:49] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:49] Application Installer end with exit code 0
[2011-10-15:17:08:50] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:50] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.19526419416069984 onApplicationVersion
[2011-10-15:17:08:50] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:50] Application Installer end with exit code 0
[2011-10-15:17:08:50] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9119615168310702 onApplicationVersion
[2011-10-15:17:08:51] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:51] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9316339469514787 onApplicationVersion
[2011-10-15:17:08:51] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:51] Application Installer end with exit code 0
[2011-10-15:17:08:51] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6085766856558621 onApplicationVersion
[2011-10-15:17:08:52] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:52] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.914133204612881 onApplicationVersion
[2011-10-15:17:08:52] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:52] Application Installer end with exit code 0
[2011-10-15:17:08:52] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8456230442970991 onApplicationVersion
[2011-10-15:17:08:53] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:53] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7275252449326217 onApplicationVersion
[2011-10-15:17:08:53] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:53] Application Installer end with exit code 0
[2011-10-15:17:08:53] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9888213840313256 onApplicationVersion
[2011-10-15:17:08:54] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:54] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.116327871568501 onApplicationVersion
[2011-10-15:17:08:54] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:54] Application Installer end with exit code 0
[2011-10-15:17:08:54] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5331940301693976 onApplicationVersion
[2011-10-15:17:08:54] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.06563299288973212 onApplicationVersion
[2011-10-15:17:08:55] Application Installer end with exit code 0
[2011-10-15:17:08:55] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:55] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.15864801546558738 onApplicationVersion
[2011-10-15:17:08:55] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:56] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:56] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6484434166923165 onApplicationVersion
[2011-10-15:17:08:56] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:56] Application Installer end with exit code 0
[2011-10-15:17:08:56] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6438154112547636 onApplicationVersion
[2011-10-15:17:08:56] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8319012015126646 onApplicationVersion
[2011-10-15:17:08:57] Application Installer end with exit code 0
[2011-10-15:17:08:57] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:57] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3820904018357396 onApplicationVersion
[2011-10-15:17:08:57] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:57] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9428510195575655 onApplicationVersion
[2011-10-15:17:08:58] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:58] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7785209976136684 onApplicationVersion
[2011-10-15:17:08:58] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:58] Application Installer end with exit code 0
[2011-10-15:17:08:59] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:08:59] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4013191135600209 onApplicationVersion
[2011-10-15:17:08:59] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:08:59] Application Installer end with exit code 0
[2011-10-15:17:08:59] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7450108272023499 onApplicationVersion
[2011-10-15:17:09:00] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:00] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9968445943668485 onApplicationVersion
[2011-10-15:17:09:00] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:00] Application Installer end with exit code 0
[2011-10-15:17:09:00] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5687433020211756 onApplicationVersion
[2011-10-15:17:09:00] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.22188922856003046 onApplicationVersion
[2011-10-15:17:09:01] Application Installer end with exit code 0
[2011-10-15:17:09:01] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:01] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4626821596175432 onApplicationVersion
[2011-10-15:17:09:01] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:02] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:02] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.784669816493988 onApplicationVersion
[2011-10-15:17:09:02] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:02] Application Installer end with exit code 0
[2011-10-15:17:09:02] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.05042148567736149 onApplicationVersion
[2011-10-15:17:09:03] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:03] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.22542871348559856 onApplicationVersion
[2011-10-15:17:09:03] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:03] Application Installer end with exit code 0
[2011-10-15:17:09:03] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9895828347653151 onApplicationVersion
[2011-10-15:17:09:03] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5126292207278311 onApplicationVersion
[2011-10-15:17:09:04] Application Installer end with exit code 0
[2011-10-15:17:09:04] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:04] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.031449728179723024 onApplicationVersion
[2011-10-15:17:09:04] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:05] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:05] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.05915635358542204 onApplicationVersion
[2011-10-15:17:09:05] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:05] Application Installer end with exit code 0
[2011-10-15:17:09:05] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4452045252546668 onApplicationVersion
[2011-10-15:17:09:06] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:06] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7543233949691057 onApplicationVersion
[2011-10-15:17:09:06] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:06] Application Installer end with exit code 0
[2011-10-15:17:09:06] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4572636689990759 onApplicationVersion
[2011-10-15:17:09:07] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:07] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.031378265004605055 onApplicationVersion
[2011-10-15:17:09:07] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:07] Application Installer end with exit code 0
[2011-10-15:17:09:07] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9756521987728775 onApplicationVersion
[2011-10-15:17:09:08] Application Installer end with exit code 0
[2011-10-15:17:09:08] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:08] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8166084247641265 onApplicationVersion
[2011-10-15:17:09:08] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:08] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.17336749704554677 onApplicationVersion
[2011-10-15:17:09:09] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:09] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9998851823620498 onApplicationVersion
[2011-10-15:17:09:09] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:09] Application Installer end with exit code 0
[2011-10-15:17:09:09] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5504097254015505 onApplicationVersion
[2011-10-15:17:09:09] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8749697804450989 onApplicationVersion
[2011-10-15:17:09:10] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:10] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4783385372720659 onApplicationVersion
[2011-10-15:17:09:10] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:10] Application Installer end with exit code 0
[2011-10-15:17:09:11] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:11] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5426344890147448 onApplicationVersion
[2011-10-15:17:09:11] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:11] Application Installer end with exit code 0
[2011-10-15:17:09:11] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.20394797017797828 onApplicationVersion
[2011-10-15:17:09:12] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:12] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6842504567466676 onApplicationVersion
[2011-10-15:17:09:12] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:12] Application Installer end with exit code 0
[2011-10-15:17:09:12] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6585747129283845 onApplicationVersion
[2011-10-15:17:09:12] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.05785722937434912 onApplicationVersion
[2011-10-15:17:09:13] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:13] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.638652506750077 onApplicationVersion
[2011-10-15:17:09:13] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:13] Application Installer end with exit code 0
[2011-10-15:17:09:14] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:14] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9306980706751347 onApplicationVersion
[2011-10-15:17:09:14] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:14] Application Installer end with exit code 0
[2011-10-15:17:09:15] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:15] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7999980472959578 onApplicationVersion
[2011-10-15:17:09:15] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:15] Application Installer end with exit code 0
[2011-10-15:17:09:15] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9218810191377997 onApplicationVersion
[2011-10-15:17:09:15] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.33684336952865124 onApplicationVersion
[2011-10-15:17:09:16] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:16] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.03296273108571768 onApplicationVersion
[2011-10-15:17:09:16] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:16] Application Installer end with exit code 0
[2011-10-15:17:09:16] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.13416810939088464 onApplicationVersion
[2011-10-15:17:09:17] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:17] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4828432952053845 onApplicationVersion
[2011-10-15:17:09:17] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:17] Application Installer end with exit code 0
[2011-10-15:17:09:17] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.12148092687129974 onApplicationVersion
[2011-10-15:17:09:18] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:18] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5281979856081307 onApplicationVersion
[2011-10-15:17:09:18] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:18] Application Installer end with exit code 0
[2011-10-15:17:09:18] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.32450640853494406 onApplicationVersion
[2011-10-15:17:09:18] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3871136154048145 onApplicationVersion
[2011-10-15:17:09:19] Application Installer end with exit code 0
[2011-10-15:17:09:19] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:19] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6729136174544692 onApplicationVersion
[2011-10-15:17:09:20] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:20] Application Installer end with exit code 0
[2011-10-15:17:09:20] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:20] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.04252322996035218 onApplicationVersion
[2011-10-15:17:09:20] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6626231442205608 onApplicationVersion
[2011-10-15:17:09:21] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:21] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9271919410675764 onApplicationVersion
[2011-10-15:17:09:21] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:21] Application Installer end with exit code 0
[2011-10-15:17:09:21] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6318746651522815 onApplicationVersion
[2011-10-15:17:09:21] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6163823078386486 onApplicationVersion
[2011-10-15:17:09:22] Application Installer end with exit code 0
[2011-10-15:17:09:23] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:23] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.39249605778604746 onApplicationVersion
[2011-10-15:17:09:23] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:23] Application Installer end with exit code 0
[2011-10-15:17:09:23] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9530374617315829 onApplicationVersion
[2011-10-15:17:09:23] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2720960369333625 onApplicationVersion
[2011-10-15:17:09:24] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:24] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5543921273201704 onApplicationVersion
[2011-10-15:17:09:24] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:24] Application Installer end with exit code 0
[2011-10-15:17:09:24] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.32085943315178156 onApplicationVersion
[2011-10-15:17:09:25] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:25] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.08231018856167793 onApplicationVersion
[2011-10-15:17:09:25] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:25] Application Installer end with exit code 0
[2011-10-15:17:09:26] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:26] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7352876705117524 onApplicationVersion
[2011-10-15:17:09:26] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:26] Application Installer end with exit code 0
[2011-10-15:17:09:26] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8072764803655446 onApplicationVersion
[2011-10-15:17:09:26] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.021800097078084946 onApplicationVersion
[2011-10-15:17:09:27] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:27] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8927665883675218 onApplicationVersion
[2011-10-15:17:09:27] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:27] Application Installer end with exit code 0
[2011-10-15:17:09:27] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1406533089466393 onApplicationVersion
[2011-10-15:17:09:28] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:28] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1514084874652326 onApplicationVersion
[2011-10-15:17:09:28] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:28] Application Installer end with exit code 0
[2011-10-15:17:09:29] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:29] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.0712014283053577 onApplicationVersion
[2011-10-15:17:09:29] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:29] Application Installer end with exit code 0
[2011-10-15:17:09:29] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9551911363378167 onApplicationVersion
[2011-10-15:17:09:29] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2194956080056727 onApplicationVersion
[2011-10-15:17:09:30] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:30] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.017956760246306658 onApplicationVersion
[2011-10-15:17:09:30] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:30] Application Installer end with exit code 0
[2011-10-15:17:09:30] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4151028976775706 onApplicationVersion
[2011-10-15:17:09:31] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:31] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2157457685098052 onApplicationVersion
[2011-10-15:17:09:31] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:31] Application Installer end with exit code 0
[2011-10-15:17:09:32] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:32] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.023549224250018597 onApplicationVersion
[2011-10-15:17:09:32] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:32] Application Installer end with exit code 0
[2011-10-15:17:09:32] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2753891833126545 onApplicationVersion
[2011-10-15:17:09:32] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6002904176712036 onApplicationVersion
[2011-10-15:17:09:33] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:33] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5443548602052033 onApplicationVersion
[2011-10-15:17:09:33] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:33] Application Installer end with exit code 0
[2011-10-15:17:09:33] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.17788414284586906 onApplicationVersion
[2011-10-15:17:09:34] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:34] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6447380073368549 onApplicationVersion
[2011-10-15:17:09:34] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:34] Application Installer end with exit code 0
[2011-10-15:17:09:35] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:35] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5432745786383748 onApplicationVersion
[2011-10-15:17:09:35] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:35] Application Installer end with exit code 0
[2011-10-15:17:09:35] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.36365548614412546 onApplicationVersion
[2011-10-15:17:09:36] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:36] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9898125105537474 onApplicationVersion
[2011-10-15:17:09:36] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:36] Application Installer end with exit code 0
[2011-10-15:17:09:36] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.022511661518365145 onApplicationVersion
[2011-10-15:17:09:36] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6201024316251278 onApplicationVersion
[2011-10-15:17:09:37] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:37] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2689111386425793 onApplicationVersion
[2011-10-15:17:09:37] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:37] Application Installer end with exit code 0
[2011-10-15:17:09:38] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:38] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.44309731014072895 onApplicationVersion
[2011-10-15:17:09:38] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:38] Application Installer end with exit code 0
[2011-10-15:17:09:38] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5268928105942905 onApplicationVersion
[2011-10-15:17:09:39] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:39] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.25792620657011867 onApplicationVersion
[2011-10-15:17:09:39] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:39] Application Installer end with exit code 0
[2011-10-15:17:09:39] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.29841098189353943 onApplicationVersion
[2011-10-15:17:09:39] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6427866192534566 onApplicationVersion
[2011-10-15:17:09:40] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:40] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.048034231178462505 onApplicationVersion
[2011-10-15:17:09:40] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:40] Application Installer end with exit code 0
[2011-10-15:17:09:41] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:41] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5121513800695539 onApplicationVersion
[2011-10-15:17:09:41] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:41] Application Installer end with exit code 0
[2011-10-15:17:09:41] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.21775659825652838 onApplicationVersion
[2011-10-15:17:09:42] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:42] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.31567522464320064 onApplicationVersion
[2011-10-15:17:09:42] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:42] Application Installer end with exit code 0
[2011-10-15:17:09:42] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7298949165269732 onApplicationVersion
[2011-10-15:17:09:43] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:43] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.07696087937802076 onApplicationVersion
[2011-10-15:17:09:43] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:43] Application Installer end with exit code 0
[2011-10-15:17:09:43] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7941595129668713 onApplicationVersion
[2011-10-15:17:09:44] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:44] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4084869218058884 onApplicationVersion
[2011-10-15:17:09:44] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:44] Application Installer end with exit code 0
[2011-10-15:17:09:44] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2339778570458293 onApplicationVersion
[2011-10-15:17:09:45] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:45] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5837470842525363 onApplicationVersion
[2011-10-15:17:09:45] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:45] Application Installer end with exit code 0
[2011-10-15:17:09:45] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7946787658147514 onApplicationVersion
[2011-10-15:17:09:45] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.422074886970222 onApplicationVersion
[2011-10-15:17:09:46] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:46] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3374266945756972 onApplicationVersion
[2011-10-15:17:09:46] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:46] Application Installer end with exit code 0
[2011-10-15:17:09:47] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:47] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4649545210413635 onApplicationVersion
[2011-10-15:17:09:47] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:47] Application Installer end with exit code 0
[2011-10-15:17:09:47] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2672461746260524 onApplicationVersion
[2011-10-15:17:09:48] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:48] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7772057950496674 onApplicationVersion
[2011-10-15:17:09:48] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:48] Application Installer end with exit code 0
[2011-10-15:17:09:48] Download cancelled
[2011-10-15:17:09:48] Application Installer end with exit code 6
[2011-10-15:17:09:48] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6990152508951724 onApplicationVersion
[2011-10-15:17:09:48] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3252941071987152 onApplicationVersion
[2011-10-15:17:09:49] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:49] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.20724391425028443 onApplicationVersion
[2011-10-15:17:09:49] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:49] Application Installer end with exit code 0
[2011-10-15:17:09:50] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:50] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.04977888707071543 onApplicationVersion
[2011-10-15:17:09:50] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:50] Application Installer end with exit code 0
[2011-10-15:17:09:50] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.397434807382524 onApplicationVersion
[2011-10-15:17:09:51] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:51] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2834504251368344 onApplicationVersion
[2011-10-15:17:09:51] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:51] Application Installer end with exit code 0
[2011-10-15:17:09:52] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:52] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.11501013860106468 onApplicationVersion
[2011-10-15:17:09:52] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:52] Application Installer end with exit code 0
[2011-10-15:17:09:52] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6423770328983665 onApplicationVersion
[2011-10-15:17:09:52] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3469237182289362 onApplicationVersion
[2011-10-15:17:09:54] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:54] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8775691716000438 onApplicationVersion
[2011-10-15:17:09:54] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:54] Application Installer end with exit code 0
[2011-10-15:17:09:54] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.41345459083095193 onApplicationVersion
[2011-10-15:17:09:55] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:55] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1471487428061664 onApplicationVersion
[2011-10-15:17:09:55] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:55] Application Installer end with exit code 0
[2011-10-15:17:09:55] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.22823575185611844 onApplicationVersion
[2011-10-15:17:09:56] Application Installer end with exit code 0
[2011-10-15:17:09:56] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:56] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.03291963413357735 onApplicationVersion
[2011-10-15:17:09:56] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:56] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.14251184789463878 onApplicationVersion
[2011-10-15:17:09:57] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-15:17:09:57] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8101708013564348 onApplicationVersion
[2011-10-15:17:09:57] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-15:17:09:57] Application Installer end with exit code 0
[2011-10-15:17:09:57] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.27180860564112663 onApplicationVersion
[2011-10-17:10:51:55] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-17:10:51:56] Commandline is: -arp:uninstall
[2011-10-17:10:51:56] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-17:10:53:33] Relaunching with elevation
[2011-10-17:10:53:33] Launching subprocess with commandline c:\program files (x86)\common files\adobe air\versions\1.0\resources\adobe air updater.exe -eu
[2011-10-17:10:53:37] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-17:10:53:37] Commandline is: -stdio \\.\pipe\AIR_5936_0 -eu
[2011-10-17:10:53:37] Installed runtime (3.0.0.4080) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-10-17:10:53:37] Starting runtime uninstall. Uninstalling runtime version 3.0.0.4080
[2011-10-17:10:53:38] Uninstalling product with GUID {ACEB2BAF-96DF-48FD-ADD5-43842D4C443D}
[2011-10-17:10:54:29] Runtime Installer end with exit code 0
[2011-10-17:10:54:30] Elevated install completed
[2011-10-17:10:54:30] Runtime Installer end with exit code 0
[2011-10-18:11:47:55] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:11:47:55] Commandline is: -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:11:47:55] No installed runtime detected
[2011-10-18:11:47:56] Invoking Application Installer for combined install
[2011-10-18:11:47:56] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIR6218.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIR6218.tmp -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:11:47:57] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:11:47:57] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIR6218.tmp -playerVersion=10,3,183,10 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:11:47:57] No installed runtime detected
[2011-10-18:11:47:59] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\fla9AB4.tmp
[2011-10-18:11:48:01] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-18:11:48:04] Application Installer end with exit code 7
[2011-10-18:11:48:04] Subprocess app installer failed (7)
[2011-10-18:11:48:04] Runtime Installer end with exit code 7
[2011-10-18:12:12:16] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:12:12:16] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:12:16] No installed runtime detected
[2011-10-18:12:12:17] Invoking Application Installer for combined install
[2011-10-18:12:12:17] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIRAFAF.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIRAFAF.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:12:17] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:12:12:17] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIRAFAF.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:12:17] No installed runtime detected
[2011-10-18:12:12:18] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaD336.tmp
[2011-10-18:12:12:19] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-18:12:12:23] Application Installer end with exit code 7
[2011-10-18:12:12:23] Subprocess app installer failed (7)
[2011-10-18:12:12:23] Runtime Installer end with exit code 7
[2011-10-18:12:13:51] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:12:13:51] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:13:51] No installed runtime detected
[2011-10-18:12:13:52] Invoking Application Installer for combined install
[2011-10-18:12:13:52] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIR25D7.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIR25D7.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:13:52] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:12:13:52] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIR25D7.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:12:13:52] No installed runtime detected
[2011-10-18:12:13:53] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\fla4559.tmp
[2011-10-18:12:13:54] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-18:12:13:56] Application Installer end with exit code 7
[2011-10-18:12:13:56] Subprocess app installer failed (7)
[2011-10-18:12:13:56] Runtime Installer end with exit code 7
[2011-10-18:13:21:58] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:13:21:58] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:13:21:58] No installed runtime detected
[2011-10-18:13:21:58] Invoking Application Installer for combined install
[2011-10-18:13:21:58] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIR8BEB.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIR8BEB.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:13:21:59] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-18:13:21:59] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIR8BEB.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE1eWxqOQ== b015ylhx null null My4w b015ylj9 normal"
[2011-10-18:13:21:59] No installed runtime detected
[2011-10-18:13:22:00] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaA110.tmp
[2011-10-18:13:22:01] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-18:13:22:04] Application Installer end with exit code 7
[2011-10-18:13:22:04] Subprocess app installer failed (7)
[2011-10-18:13:22:04] Runtime Installer end with exit code 7
[2011-10-22:14:58:59] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-22:14:58:59] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2Ync4cA== b016bsq9 null null My4w b016bw8p normal"
[2011-10-22:14:58:59] No installed runtime detected
[2011-10-22:14:59:00] Invoking Application Installer for combined install
[2011-10-22:14:59:00] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIRCB7D.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIRCB7D.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2Ync4cA== b016bsq9 null null My4w b016bw8p normal"
[2011-10-22:14:59:00] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-22:14:59:00] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIRCB7D.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2Ync4cA== b016bsq9 null null My4w b016bw8p normal"
[2011-10-22:14:59:00] No installed runtime detected
[2011-10-22:14:59:02] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaE850.tmp
[2011-10-22:14:59:02] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-22:14:59:04] Application Installer end with exit code 7
[2011-10-22:14:59:04] Subprocess app installer failed (7)
[2011-10-22:14:59:04] Runtime Installer end with exit code 7
[2011-10-24:19:53:56] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:19:53:56] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:53:56] No installed runtime detected
[2011-10-24:19:53:57] Invoking Application Installer for combined install
[2011-10-24:19:53:57] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIR50E5.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIR50E5.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:53:57] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:19:53:57] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIR50E5.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:53:57] No installed runtime detected
[2011-10-24:19:53:58] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\fla686A.tmp
[2011-10-24:19:54:01] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-24:19:54:03] Application Installer end with exit code 7
[2011-10-24:19:54:03] Subprocess app installer failed (7)
[2011-10-24:19:54:03] Runtime Installer end with exit code 7
[2011-10-24:19:58:50] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:19:58:50] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:58:50] No installed runtime detected
[2011-10-24:19:58:51] Invoking Application Installer for combined install
[2011-10-24:19:58:51] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIRCDB2.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIRCDB2.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:58:51] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:19:58:51] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIRCDB2.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:19:58:51] No installed runtime detected
[2011-10-24:19:58:52] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaE66F.tmp
[2011-10-24:19:58:55] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-24:19:58:57] Application Installer end with exit code 7
[2011-10-24:19:58:57] Subprocess app installer failed (7)
[2011-10-24:19:58:57] Runtime Installer end with exit code 7
[2011-10-24:20:01:56] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:20:01:56] Commandline is: -playerVersion=10,3,183,7 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:01:56] No installed runtime detected
[2011-10-24:20:01:56] Invoking Application Installer for combined install
[2011-10-24:20:01:56] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIRA25E.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIRA25E.tmp -playerVersion=10,3,183,7 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:01:56] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:20:01:56] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIRA25E.tmp -playerVersion=10,3,183,7 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:01:57] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaB996.tmp
[2011-10-24:20:02:00] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-24:20:02:03] Application Installer end with exit code 7
[2011-10-24:20:02:03] Subprocess app installer failed (7)
[2011-10-24:20:02:03] Runtime Installer end with exit code 7
[2011-10-24:20:08:45] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:20:08:45] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:08:45] No installed runtime detected
[2011-10-24:20:08:45] Invoking Application Installer for combined install
[2011-10-24:20:08:45] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIRDF8D.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIRDF8D.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:08:46] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:20:08:46] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIRDF8D.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:20:08:46] No installed runtime detected
[2011-10-24:20:08:47] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\flaF898.tmp
[2011-10-24:20:08:49] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-24:20:08:53] Application Installer end with exit code 7
[2011-10-24:20:08:53] Subprocess app installer failed (7)
[2011-10-24:20:08:53] Runtime Installer end with exit code 7
[2011-10-24:21:10:04] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:21:10:04] Commandline is:
[2011-10-24:21:10:04] No installed runtime detected
[2011-10-24:21:10:13] Relaunching with elevation
[2011-10-24:21:10:13] Launching subprocess with commandline c:\users\temi\appdata\local\temp\air150.tmp\adobe air installer.exe -ei
[2011-10-24:21:10:15] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:21:10:15] Commandline is: -stdio \\.\pipe\AIR_1000_0 -ei
[2011-10-24:21:10:15] No installed runtime detected
[2011-10-24:21:10:15] Starting silent runtime install. Installing runtime version 3.0.0.4080
[2011-10-24:21:10:15] Installing msi at c:\users\temi\appdata\local\temp\air150.tmp\setup.msi with guid {ACEB2BAF-96DF-48FD-ADD5-43842D4C443D}
[2011-10-24:21:10:15] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1601" errorID=0]
[2011-10-24:21:10:15] Rolling back install of c:\users\temi\appdata\local\temp\air150.tmp\setup.msi
[2011-10-24:21:10:15] Rollback complete
[2011-10-24:21:10:15] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1601" errorID=0]
[2011-10-24:21:10:15] Runtime Installer end with exit code 7
[2011-10-24:21:11:25] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:21:11:25] Commandline is: -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -x1 http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:21:11:25] No installed runtime detected
[2011-10-24:21:11:26] Invoking Application Installer for combined install
[2011-10-24:21:11:26] Launching subprocess with commandline C:\Users\Temi\AppData\Local\Temp\AIR3D66.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Temi\AppData\Local\Temp\AIR3D66.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:21:11:26] Application Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-10-24:21:11:26] Commandline is: -runtime C:\Users\Temi\AppData\Local\Temp\AIR3D66.tmp -playerVersion=11,0,1,152 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDE2bXQ5cQ== b016mt8y 2500 0 My4w b016mt9q normal "
[2011-10-24:21:11:26] No installed runtime detected
[2011-10-24:21:11:27] Unpackaging http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop_v3213.air to C:\Users\Temi\AppData\Local\Temp\fla5826.tmp
[2011-10-24:21:11:27] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="truncated or corrupt" errorID=0]
[2011-10-24:21:11:29] Application Installer end with exit code 7
[2011-10-24:21:11:30] Subprocess app installer failed (7)
[2011-10-24:21:11:30] Runtime Installer end with exit code 7
[2011-10-24:21:13:31] Runtime Installer end with exit code 7
Anyone?
Could you please try to Microsoft Install and Uninstall Fix It and verify your issue. If you still come across that problem, please copy the entire log here and try the following solution.
Please try this solution:
Step 1. Download the “Windows Installer CleanUp Utility” tool here. Click the “DOWNLOAD LOCATIONS” button, and it will download automatically. The installer file name is “msicuu2.exe”.
Step 2. This tool was initially designed for win xp, in order to make sure it install and run well Win 7. You need to make a small configuration.
Right click on the msicuu2.exe installer file, go to Properties -> Compatibility -> check “Run this problem in compatibility mode for Windows XP (SP3)”. Here is a screen shot. And then run the installer and install the application.
Step 3. After installation, go to Start -> All Programs -> Find “Windows Install Clean Up” and click on the icon to launch the utility program.
You should see this window open:
Step 4. In the opened window, find a program named “Adobe AIR [x.x.x…]” as the version. Mine is AIR 3.0.0.3880. When you select on the item, and click the “Remove” button, the utility will remove the program completely. I suggest you to remove all Adobe AIR versions listed in the window.
Step 5. After a clear uninstallation, you can get the latest version of Adobe AIR here. Try to install it and it should be installed right away without any problem.
Reference links:
China Flash Runtime Blog, and the forum post "Can't install Air on XP home edition (sp3) ".
Yuzhong
Flash Runtime Customer Experience
Sorry about the late reply but I've been having internet problems.
I've done all the above and used Windows Cleaner to perform a clean installation but I'm still getting the Sorry an error has occured: An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
