All of a sudden, preview topic is no longer working in RoboHelp 8. Not sure if it has to do with the recent patch, but I need it to WORK!
Any suggestions?
Elissa
Hi Elissa
I've seen Preview go missing before. Were you working on multiple monitors?
Try this. I think it's Ameber that came up with this.
Preview
Press Alt+Spacebar
Press an arrow key
Wiggle the mouse a bit and the preview should snap into view.
At least I think those are the correct steps.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Yes, I was working on multiple monitors earlier this week. But it worked yesterday when I wasn't working on multiple monitors.
I tried the procedure that you suggested, and no luck...
Oops... looks like I missed a step
Preview
Alt+Spacebar
M (for move)
THEN arrow key
THEN mouse wiggle. I think Ameber calls it a waggle, but whatever. She also suggests adding "Wildly" as in Wildly waggle.
See if that helps... Rick
I had this same thing happen to me. I have a laptop docking station connected to another monitor and used my laptop screen as my 2nd monitor, the preview pane stopped working when I added a 2nd stand alone monitor to the mix. I was able to regain the preview window by opening my laptop while docked to "reset" the window pane to the new monitors I have.
Hope that helps!
Thanks for having this topic and answer on the forum.
I returned to single monitor mode and followed the suggested steps (including wildy waggling).
My topic preview came back.
I returned to dual monitors and it still works.
Great!
I also had this problem, but ALT + SPACE only activated on the main RoboHelp window. This guy's technique did the trick, however:
Hi Mike
The fact that Alt+Space only opened the Main RoboHelp window suggests that after you tried to preview you clicked the main window to shift focus to it. And when that happens, it won't work.
If the Preview window doesn't have focus, the steps will naturally fail.
Generally, if this happens, an easy way is to carefully work. Close RoboHelp and restart. Preview again. Then try the steps outlined before trying to click anywhere else.
I'm about as geeky as they come with RoboHelp stuff and I believe I'm the only one that exposed the method Colum posted in his blog. But the keyboard method is much safer and is highly recommended.
Cheers... Rick
Thanks Captiv8r, but that was not the case. I know all about Alt+Space, focus, etc., I had restarted RoboHelp many times, reinstalled RH, and even looked for the setting in the registry myself before finding that blog. The preview window simply would not take focus for some reason. But resetting the registry values totally did the trick.
Hi there
Interesting. However,
I'll also add that at first, I had issues making it work. What I discovered I was missing was after pressing Alt+Spacebar and M, I was at that point trying to move the mouse and expecting things to work. I was stymied when they failed.
What I needed to do (and missed) was pressing an arrow key to begin the move process.
However, I do note that you say your situation is apparently different.
At any rate you managed to fix it using the instructions Colum copied and posted on his blog. (I had to laugh because I recognized my own attempted humor in the instructions) I'm just happy you managed to sort it.
Cheers... Rick
Ah haaaa... you mean he copied it from you? Well, all the credit goes to you then. Thanks for all the help!
