1. Re: Problem loading modules in flex 4.5
RedBall23 May 26, 2011 3:56 AM (in response to RedBall23)One more thing:
When I use sdk 4.1 and mx module everything is great.
But I want to use sdk 4.5 and spark module, and then I have the above exception..
Hope it helps to figuring out the solution.. (still waiting for an answer.. )
2. Re: Problem loading modules in flex 4.5
Nicolas YuenJun 15, 2011 3:40 PM (in response to RedBall23)
I'll try to have a look at the issue this week, could you please open a jira ticket with a sample on our bug tracking system:
https://bugs.adobe.com/jira/browse/CGM
thanks
3. Re: Problem loading modules in flex 4.5
EricJ32 Oct 21, 2011 5:19 AM (in response to Nicolas Yuen)Hi,
Has this been looked into? I'm trying to migrate to 4.5 and am getting the same message.
4. Re: Problem loading modules in flex 4.5
Joan Llenas Oct 21, 2011 12:02 PM (in response to EricJ32)While the issue is being fixed you can recompile the library yourself changing all mx.modules.Module references to mx.modules.IModule.
That seems to be enough as far as I can tell.
Cheers
5. Re: Problem loading modules in flex 4.5
DoubleFx Fr Oct 27, 2011 4:32 AM (in response to Nicolas Yuen)Hello Nico,
The problem just happened to me this morning, in order to fix it, it is enought to patch the Cairngorm Module Library in order to implement some methods witch extends IFlexModuleFactory, this new interface is done in order to check if an RSL is already loaded before loading, so modules and sub-applications will not load RSLs that are already loaded.
You can patch it like that, in a project where you use the Cairngorm Module Library:
1- Create the package "com.adobe.cairngorm.module" at the root source of the project.
2- Download and paste in it the http://opensource.adobe.com/svn/opensource/cairngorm3/tags/cairngorm3-3.0.9/libraries/Modu le/src/com/adobe/cairngorm/module/ParsleyFlexModuleFactory.as
3- In ParsleyFlexModuleFactory.as, remove the CONFIG::Flex4 tags (they're used for the conditional compilation but we don't need them because we'll indeed compile it for flex 4.5+ and not everybody uses a conditional compilation configuration).
4- add this code :
public function get allowDomainsInNewRSLs():Boolean
return factory.allowDomainsInNewRSLs;
public function set allowDomainsInNewRSLs(value:Boolean):void
factory.allowDomainsInNewRSLs = value;
public function get allowInsecureDomainsInNewRSLs():Boolean
return factory.allowInsecureDomainsInNewRSLs;
public function set allowInsecureDomainsInNewRSLs(value:Boolean):void
factory.allowInsecureDomainsInNewRSLs = value;
public function addPreloadedRSL(loaderInfo:LoaderInfo, rsl:Vector.<RSLData>):void
factory.addPreloadedRSL(loaderInfo, rsl);
5- Add the spicelib-flex-2.4+.swc and the parsley-flex4-2.4+.swc (or the Parsley counterpart libraries) as support for the patched ParsleyFlexModuleFactory.
6- Compile it with the SDK 4.5+ and that's done, it works now with the SDK 4+.
(If you've got more projects where you use the Cairngorm Module Library, just copy and paste the new patched package and add thespicelib-flex-2.4+ and the parsley-flex4-2.4+.swc (or the Parsley counterpart libraries)
That will only allows the library to be fully compatible with the SDK 4.5+
(maybe it's good to keep Alex Uhlmann in touch with it allowing him to implement a conditional compilation or another version of the artifact the time it migrates completely its library in 4.5).
(For the those who have a lot of Maven projects, it's preferable to re-compile the original Cairngorm Module Library with the code above in order to have the patched artifact in your maven repository, indeed, you won't have to remove the CONFIG::Flex4 tags or to add the spicelib, parsley libraries, the patched module is self-suffisent and a simple "mvn clean install" does the job)
Note: Anyway, now, with Parsley 2.4, the flex module integration is FULLY tranparent and the need of this library is less important.
Frédéric THOMAS
6. Re: Problem loading modules in flex 4.5
Nicolas YuenOct 27, 2011 5:13 PM (in response to DoubleFx Fr)
Hi Fred!,
Thanks for the great contribution. I'll have a look at the lib and see if the changes can be implemented in the next build
7. Re: Problem loading modules in flex 4.5
DoubleFx Fr Oct 29, 2011 2:06 AM (in response to Nicolas Yuen)Hi Nico,
Actually, no needs to ask to integrate it, that's already done on the source force repo, https://bugs.adobe.com/jira/browse/CGM-87
I just releazed that I was on the old repo, the new one being on sourceforge.net. -
8. Re: Problem loading modules in flex 4.5
Nick Li Apr 24, 2013 9:19 PM (in response to DoubleFx Fr)public function addPreloadedRSL(loaderInfo:LoaderInfo, rsl:Vector.<RSLData>):void
Need to import LoaderInfo & RSLData ?
What are their path?
