6 Replies Latest reply on Mar 28, 2012 3:38 AM by Venkom
    video duration
    Venkom Level 1
      How to get video duration in as3 ?
        • 1. Re: video duration
          Andrei1 Level 6
          1 person found this helpful
          • 2. Re: video duration
            Venkom Level 1
            function formatTime(t:int):String {
                      var s:int = Math.round(t);
                      var m:int = 0;
                      if (s > 0) {
                                while (s > 59) {
                                          m++;
                                          s -= 60;
                                return String((m < 10 ? "0" : "") + m + ":" + (s < 10 ? "0" : "") + s);
                      } else {
                                return "00:00";
            How to add hours to above script.
            Format : HH:MM:SS
            • 3. Re: video duration
              Andrei1 Level 6
              Use Date() and RegExp to do that. I have a tutorial on my blog:
              http://as3-blog.net/?p=163
              • 4. Re: video duration
                Venkom Level 1
                I changed this total duration of video.
                but some issus
                msg is
                Scene 1, Layer 'Actions', Frame 1, Line 5091067: Implicit coercion of a value of type String to an unrelated type Number.
                var newMeta:Object = new Object();
                newMeta.onMetaData = onMetaData;
                var vFrame:MovieClip=new MovieClip();
                this.addChild(vFrame);
                vFrame.addEventListener(Event.ENTER_FRAME, videoStatus);
                function onMetaData(newMeta:Object):void
                  duration = newMeta.duration;
                          var hours2:Number;
                          var minutes2:Number;
                          var seconds2:Number;
                          var durminutes = duration/60;
                                    hours2           = Math.floor(durmin/60);
                          if (duration>=3600) {
                                    minutes2 = Math.floor(durmin%60);
                          } else {
                                    minutes2 = Math.floor(duration/60);
                                    seconds2 = Math.floor(duration%60);
                          if (hours2<10) {
                                    hours2 = "0"+hours2;
                          if (minutes2<10) {
                                    minutes2 = "0"+minutes2;
                          if (seconds2<10) {
                                    seconds2 = "0"+seconds2;
                trace (hours2+":"+minutes2+":"+seconds2);
                function videoStatus():void
                          amountLoaded = ns.bytesLoaded/ns.bytesTotal;
                          controls.seekbar.loadBar.width = amountLoaded*330;
                          controls.seekbar.scrubber.x = ns.time/duration*320;
                • 5. Re: video duration
                  Andrei1 Level 6
                  You declared hours2, minutes2,etc. as Numbers but attempt to use them as Strings - hence the error.
                  • 6. Re: video duration
                    Venkom Level 1
                    Now total time fine, playing fine.
                    Thank you
