1. Re: Choppy footage from AE
joe bloe premiere Oct 28, 2011 3:53 PM (in response to simonsvideo1)Warp stabilization is very process intensive, and you should not
expect to get real-time playback of the linked comp in Premiere.
You should render the effect (or the entire timeline) for smooth playback.
Render a preview file for a section of a sequence
Red, yellow, and green render bars and what they mean
edit:
added render bars link per fuzz's suggestion.
2. Re: Choppy footage from AE
Fuzzy Barsik Oct 28, 2011 3:25 PM (in response to simonsvideo1)A couple of words to what Joe says.
Irrespective of the dynamically linked AE comps complexity PrPro CS5.5 displays them yellow in the timeline, which might be misleading.
So as to get smooth preview playback you need to 'Render Entire Work Area' (not just 'Render Effects in Work Area'!).
If this option is grayed out, you may e.g. select any clip on the timeline and copy it into clipboard (Ctrl/Cmd+C) - Voilà! Access granted.
3. Re: Choppy footage from AE
simonsvideo1 Oct 28, 2011 7:23 PM (in response to simonsvideo1)Yeap, that did the trick. You guys were very helpful. Thank you.
