1. Re: Not Responding with CS4
Pedaling Duo Productions Oct 29, 2011 11:43 AM (in response to Pedaling Duo Productions)Anybody?
2. Re: Not Responding with CS4
Jeff Bellune Oct 30, 2011 5:04 AM (in response to Pedaling Duo Productions)What's different about the footage and the effects that you're using for this project compared to the projects that work? What specific editing task are you performing when you get the hang error?
An AppHangB1 error can mean that the program is genuinely locked up, but it can also mean that it's busy and it's just taking longer to do something than Windows thinks it should take.
-Jeff
3. Re: Not Responding with CS4
Pedaling Duo Productions Oct 30, 2011 9:59 AM (in response to Jeff Bellune)Thanks for answering Jeff,
All of the projects that I have on this editing machine were shot with the same camera, the JVC GY HM100U. I believe it is EXCAM 720 59.94fps. I am having to scale many of the clips slightly because my wind sock on the shotgun mic is in many of the shots. I did not notice when I was shooting but it is in the shot if I was zoomed all the way out with the lens. Also I have slowed some of the clips down by interpeting footage, but less than 1% of the clips are slowed down. In this project I rendered and replaced a lot of the audio with Soundbooth so that I could improve the audio. I have never done that before but the results sound good.
I did find a cut where there were a few blank frames in between. I fixed that and it seemed to help some but not a 100% fix.
I have 10 sequences at an average of 5 minutes each. Some of the sequences I can transcode with either Encore or AME but a few seem to hang up. When I look at the transcoded partial file, that is the file that hung up, the trancoded video plays fine to a point and then the clips turn green and the video studders between green clips and the regular video on a less than a second time scale. I checked and the transcode failure does not fail at the same point in the sequence every time and if you look at the sequence in PPro it appears fine, which is not the case I was having last week. There were green frames in PPro last week but I have tried many things between now and then. As I said it is the same sequences that always fail and I have been over them with a fine tooth comb; I guess not fine enough though.
The things that I have tried that resulted in some improvement.
Note: After all of these troubles started a few weeks ago the project loading bar would hang up for seconds at a time, several times when it was opening the project file. Now it opens quickly and smoothly.
I have shortened the sequence names and used underscores instead of spaces in the file names
I have moved the media files to a different disk and then moved them back again
I found blank frames between cuts in one of the sequences and fixed it
I am currently running a memory check
I defragged the hard drive although it was less then 1% fragmented
As I said it loads nicely now but I am still loosing responce on occation. It does not happen as often as last week but it still happens. I am going to run a disk check on the media disk to see if that turns up anything.
Sorry that my explination is so long but a lot of odd things are going on. I stated in the post that other projects on the same machine work fine. It has to be something corrupted in the files is my guess but I don't know how to find it.
Thanks again. It is always good to hear from you. I miss Wrigleyville.
