Locked
about my earlier post
Oct 30, 2011 Oct 30, 2011
i tried to respond to it, unfortunately, because of this program, adobe flash player 11, i am unable to do so. i un-installed it and downloaded and re-installed version 10.3 and still i'm having the same problems. i am also unable to see what is in the inbox of my email. the thing says it's installed, but when i do the "manage add ons" routine, like other people, it's not there. you tube still swears i don't have a current version of flash player, and it also swears i don't have java. neither of these are true. you guys released a product that is destroying and wreaking havoc on computers. now, as for my system information, here it is in full:
System Information
Time of this report: 10/30/2011, 20:31:50
       Machine name: EMACHINE-98E05C
   Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647)
           Language: English (Regional Setting: English)
System Manufacturer: eMachines
       System Model: EL1300G
               BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
          Processor: AMD Athlon(tm) Processor 2650e,  MMX,  3DNow, ~1.6GHz
             Memory: 894MB RAM
          Page File: 761MB used, 1406MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce 6150SE nForce 430
     Manufacturer: NVIDIA
        Chip type: GeForce 6150SE nForce 430
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_03D0&SUBSYS_01531025&REV_A2
   Display Memory: 512.0 MB
     Current Mode: 1024 x 768 (32 bit) (60Hz)
          Monitor: Plug and Play Monitor
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0011.6401 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/25/2008 12:29:00, 5784832 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 2/25/2008 12:29:00, 6867360 bytes
Device Identifier: {D7B71E3E-4090-11CF-946A-582103C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x03D0
        SubSys ID: 0x01531025
      Revision ID: 0x00A2
      Revision ID: 0x00A2
      Video Accel:
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
            Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10250153&REV_1002
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RtkHDAud.sys
         Driver Version: 5.10.0000.5628 (English)
            WHQL Logo'd: Yes
          Date and Size: 5/20/2008 17:53:00, 4800000 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
              HW Memory: 0
       Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
            Description: Realtek HD Audio Input
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xFFF
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  Microsoft MIDI Mapper , Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft GS Wavetable SW Synth , Hardware (Not Kernel Mode), Output, No DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x03F1
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 05:00:00, 59520 bytes
| Driver: usbd.sys, 4/14/2008 05:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 05:00:00, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 05:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 06:43:22, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 4/14/2008 01:09:48, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,00E04C31F239)
DirectPlay8 IPX Service Provider: IPX Adapter 2 - (00000000,001D72B9C80B)
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
Free Space: 10.4 GB
Total Space: 142.4 GB
File System: NTFS
      Model: ST316081 5AS SCSI Disk Device
      Drive: G:
      Model: SanDisk U3 Cruzer Micro USB Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5593 (English), 5/2/2008 03:49:39, 62976 bytes
      Drive: D:
      Model: HL-DT-ST DVDRAM GH40F SCSI CdRom Device
System Devices
     Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_01531025&REV_A2\3&2411E6FE&0&41
   Driver: C:\WINDOWS\system32\DRIVERS\nvgts.sys, 10.03.0000.0021 (English), 1/25/2008 20:01:06, 132096 bytes
   Driver: C:\WINDOWS\system32\nvraidco.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:56, 360448 bytes
   Driver: C:\WINDOWS\system32\nvraiins.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:56, 360448 bytes
   Driver: C:\WINDOWS\system32\NvRCoAr.dll, 10.03.0000.0021 (Arabic), 1/25/2008 19:48:26, 37376 bytes
   Driver: C:\WINDOWS\system32\NvRCoCs.dll, 10.03.0000.0021 (Czech), 1/25/2008 19:48:26, 37376 bytes
   Driver: C:\WINDOWS\system32\NvRCoDa.dll, 10.03.0000.0021 (Danish), 1/25/2008 19:48:28, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoDe.dll, 10.03.0000.0021 (German), 1/25/2008 19:48:28, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoEl.dll, 10.03.0000.0021 (Greek), 1/25/2008 19:48:28, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoEng.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:28, 37376 bytes
   Driver: C:\WINDOWS\system32\NvRCoENU.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:30, 37376 bytes
   Driver: C:\WINDOWS\system32\NvRCoEs.dll, 10.03.0000.0021 (Spanish), 1/25/2008 19:48:30, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoEsm.dll, 10.03.0000.0021 (Spanish), 1/25/2008 19:48:30, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoFi.dll, 10.03.0000.0021 (Finnish), 1/25/2008 19:48:30, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoFr.dll, 10.03.0000.0021 (French), 1/25/2008 19:48:32, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoHe.dll, 10.03.0000.0021 (Hebrew), 1/25/2008 19:48:32, 36864 bytes
   Driver: C:\WINDOWS\system32\NvRCoHu.dll, 10.03.0000.0021 (Hungarian), 1/25/2008 19:48:32, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoIt.dll, 10.03.0000.0021 (Italian), 1/25/2008 19:48:32, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoJa.dll, 10.03.0000.0021 (Japanese), 1/25/2008 19:48:34, 36352 bytes
   Driver: C:\WINDOWS\system32\NvRCoKo.dll, 10.03.0000.0021 (Korean), 1/25/2008 19:48:34, 35840 bytes
   Driver: C:\WINDOWS\system32\NvRCoNl.dll, 10.03.0000.0021 (Dutch), 1/25/2008 19:48:34, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoNo.dll, 10.03.0000.0021 (Norwegian (Bokmål)), 1/25/2008 19:48:34, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoPl.dll, 10.03.0000.0021 (Polish), 1/25/2008 19:48:36, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoPt.dll, 10.03.0000.0021 (Portuguese), 1/25/2008 19:48:36, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoPtb.dll, 10.03.0000.0021 (Portuguese), 1/25/2008 19:48:36, 38400 bytes
   Driver: C:\WINDOWS\system32\NvRCoRu.dll, 10.03.0000.0021 (Russian), 1/25/2008 19:48:36, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoSk.dll, 10.03.0000.0021 (Slovak), 1/25/2008 19:48:38, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoSl.dll, 10.03.0000.0021 (Slovenian), 1/25/2008 19:48:38, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoSv.dll, 10.03.0000.0021 (Swedish), 1/25/2008 19:48:38, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoTh.dll, 10.03.0000.0021 (Thai), 1/25/2008 19:48:38, 37376 bytes
   Driver: C:\WINDOWS\system32\NvRCoTr.dll, 10.03.0000.0021 (Turkish), 1/25/2008 19:48:40, 37888 bytes
   Driver: C:\WINDOWS\system32\NvRCoZhc.dll, 10.03.0000.0021 (Chinese), 1/25/2008 19:48:40, 35328 bytes
   Driver: C:\WINDOWS\system32\NvRCoZht.dll, 10.03.0000.0021 (Chinese), 1/25/2008 19:48:40, 35328 bytes
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_01531025&REV_A2\3&2411E6FE&0&40
     Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03F5&SUBSYS_01531025&REV_A2\3&2411E6FE&0&0A
   Driver: n/a
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_03F3&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 68224 bytes
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F2&SUBSYS_CB8410DE&REV_A3\3&2411E6FE&0&11
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 22:42:10, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 7168 bytes
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F1&SUBSYS_CB8410DE&REV_A3\3&2411E6FE&0&10
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 17152 bytes
     Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DE&DEV_03F0&SUBSYS_01531025&REV_A2\3&2411E6FE&0&28
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/14/2008 05:00:00, 144384 bytes
     Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_03EF&SUBSYS_01531025&REV_A2\3&2411E6FE&0&38
   Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0001.6776 (English), 1/29/2008 12:37:48, 22016 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6776 (English), 1/29/2008 12:37:38, 950272 bytes
   Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.6776 (English), 1/29/2008 12:36:56, 9216 bytes
   Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.6776 (English), 1/29/2008 12:36:56, 9216 bytes
   Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 1/29/2008 12:13:08, 35840 bytes
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_03EC&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&30
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 24960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 96512 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 4/14/2008 05:00:00, 3328 bytes
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_03EB&SUBSYS_01531025&REV_A2\3&2411E6FE&0&09
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03EA&SUBSYS_CB8410DE&REV_A1\3&2411E6FE&0&00
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_00000000&REV_A2\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_00000000&REV_A2\3&2411E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_03E8&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_03E0&SUBSYS_00000000&REV_A2\3&2411E6FE&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 37248 bytes
     Name: NVIDIA GeForce 6150SE nForce 430
Device ID: PCI\VEN_10DE&DEV_03D0&SUBSYS_01531025&REV_A2\3&2411E6FE&0&68
   Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6867360 bytes
   Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 5784832 bytes
   Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 155716 bytes
   Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 364544 bytes
   Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6750208 bytes
   Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 8491008 bytes
   Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11155 (English), 2/25/2008 12:29:00, 286720 bytes
   Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 229376 bytes
   Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6356992 bytes
   Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 5509120 bytes
   Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3346432 bytes
   Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3166208 bytes
   Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 188416 bytes
   Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 458752 bytes
   Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 1163264 bytes
   Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2854912 bytes
   Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3563520 bytes
   Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3629056 bytes
   Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2383872 bytes
   Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2441216 bytes
   Driver: C:\WINDOWS\help\nvcpl.hlp, 2/25/2008 12:29:00, 177897 bytes
   Driver: C:\WINDOWS\help\nvwcplen.hlp, 2/25/2008 12:29:00, 55444 bytes
   Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 2/25/2008 12:29:00, 35328 bytes
   Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 2/25/2008 12:29:00, 35328 bytes
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
   Driver: n/a
DirectX Components
   ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 17920 bytes
   dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 83456 bytes
  dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 116736 bytes
  dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 53520 bytes
  dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 394240 bytes
     joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 76800 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
  dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 71680 bytes
  dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 82432 bytes
  system.dll: 1.01.4322.2490 English Final Retail 10/12/2011 10:16:32 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 10/30/2011 05:14:25 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 10/30/2011 05:14:12 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 10/30/2011 05:14:13 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 10/30/2011 05:14:14 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 10/30/2011 05:14:14 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 10/30/2011 05:14:15 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 10/30/2011 05:14:15 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 10/30/2011 05:14:16 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 10/30/2011 05:14:16 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 10/30/2011 05:14:16 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 10/30/2011 05:14:25 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:25 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:24 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:25 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:24 223232 bytes
   dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 619008 bytes
   dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 2113536 bytes
   mfc40.dll: 4.01.0000.6151 English Beta Retail 9/17/2010 23:53:25 954368 bytes
   mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 06:33:55 978944 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:00:00 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 05:00:00 498742 bytes
  mciqtz.drv: 4.00.0096.0729 English Final Retail 11/17/1997 17:13:16 11776 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 22:47:18 211456 bytes
    qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 192512 bytes
     qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 279040 bytes
    qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 386048 bytes
   qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 733696 bytes
  quartz.dll: 6.05.2600.5933 English Final Retail 2/5/2010 11:27:45 1291776 bytes
  quartz.vxd:                 Final Retail 11/17/1997 17:13:16 5672 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 01:00:21 247326 bytes
  vidx16.dll: 0.00.0000.0000 English Final Retail 11/17/1997 17:13:16 10240 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 05:00:00 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 05:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 05:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 05:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 05:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 05:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 05:00:00 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 05:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 02:01:48 204800 bytes
      ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
  ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
  ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
  stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5376 bytes
   mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 01:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 7552 bytes
  swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 1428992 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 30208 bytes
   msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 10:11:44 17920 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5933
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8051.1204
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5933
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5933
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5933
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
CyberLink AudioCD Filter (PDVD7),0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
CyberLink Audio Decoder (PDVD7),0x00601000,1,1,CLAud.ax,6.01.0000.4227
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
CyberLink Audio Effect (PDVD7),0x00200000,1,1,CLAudFx.ax,6.00.0000.4111
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5933
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
CyberLink Video/SP Decoder(PDVD7 HomeNetwork),0x00200000,2,3,CLVSD.ax,6.00.0000.3313
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5933
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
CyberLink Demux (PDVD7),0x00602000,1,0,CLDemuxer.ax,1.00.0000.4528
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3022
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Line21 Decoder (PDVD7),0x00200000,0,2,CLLine21.ax,4.00.0000.7602
CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.2307
CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5933
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5933
CyberLink Push-Mode CLStream (PDVD7),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1627
CyberLink Audio Decoder (PDVD7 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3816
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5933
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
CyberLink Audio Spectrum Analyzer (PDVD7),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVsd.ax,8.00.0000.1918
Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
CyberLink DVD Navigator (PDVD7),0x00600000,0,3,CLNavX.ax,7.00.0000.3112
CyberLink TimeStretch Filter (PDVD7),0x00200000,1,1,clauts.ax,1.00.0000.5423
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Cyberlink SubTitle Importor (PDVD7),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
Cutlist File Source,0x00200000,0,1,qcut.dll,5.01.0051.0207
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5933
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
CyberLink MPEG-4 Splitter (PDVD7),0x00600000,1,2,clm4splt.ax,1.00.0000.3229
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5933
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5933
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5933
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5933
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5933
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5933
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
CyberLink Demux (PDVD7 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
CyberLink Streamming Filter (PDVD7),0x00200000,0,1,CLStream.ax,1.01.0000.2902
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5933
CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0000
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5933
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5933
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5933
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5933
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5933
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming Capture Devices:
Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6076
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6076
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6076
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5933
CyberLink Audio Renderer (PDVD7),0x00200000,1,0,cladr.ax,6.00.0000.3916
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.5512
Realtek HD Audio output,0x00200000,13,1,,5.03.2600.5512
i await your response. be forewarned, i'll have to start a whole new topic in order to respond, seeing as anytime i click on the "reply" button nothing happens. that is the same issue with trying to download the new flash player 11 from the download page. i click on the link, nothing happens. now, i'm having this problem on every website i go to, at least the ones that will come up and display instead of the blank white screen i keep getting everywhere.
644
Oct 31, 2011 Oct 31, 2011
Thank you for the details.  I suggest you try the following
  • go to http://forums.adobe.com/thread/909550 and download (save to disk)
    • the 32-bit uninstaller
    • the 32-bit installer for your browser
  • close all browser windows and run the downloaded uninstaller
  • restart Windows
  • go to C:\Windows\system32\Macromed\Flash and delete any remaining files in there
  • now run the downloaded installer
Can you now see Shockwave Flash under your browser add-ons, and is it enabled?
Can you see the Flash animation at http://www.adobe.com/software/flash/about/ ?
Message was edited by: ʇɐb ɹəuəllıʍ - corrected Flash version link.
Sorry, the link in the last sentence above should have been http://www.adobe.com/software/flash/about/
