join/from/where/ combine queries2
Sep 10, 2006 Sep 10, 2006
Hello ,
I need help again on the inner join/and consitions in the where clause
I have these 2 tables tcase and tcase_req where there common field Is the case_id.
tcase is the parent table and the tcase_req is the child table.
(1)I wanted to add this to the from clause using the inner join table . what do I do and where do I put it
(2)I then need to put a condition in the where clause to replace
WHERE TCASE.CASE_NBR Like '%HPOZ%'
AND TCASE.CASE_NBR = 'DIR-2004-4269-HPOZ-CCMP'
by
WHERE TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%'
AND TCASE.CASE_NBR = 'DIR-2004-4269-CWC'
Or TCASE.CASE_NBR = 'DIR-2004-4269-CWNC'
is this efficient??
(3)To a tcase_req
Suffix_id are equal to = cwc and cwnc ( in the tcase_req table)(Suffix_id is the field that cintains the suffix cwc and cwnc for the tcase_req)
Where do I add all this to?
Here is the current query,below: THANKS
SELECT TLA_PROP.PIN,
TLA_PROP.ASSR_PRCL_NBR,
TCASE.CASE_NBR,
TLA_PROP.STR_NBR,
TLA_PROP.STR_NBR_RNG_END,
TLA_PROP.STR_FRAC_NBR,
Tref_plan_area.plan_area_desc
TLA_PROP.STR_FRAC_NBR_RNG_END,
TLA_PROP.STR_DIR_CD,
TLA_PROP.STR_NM,
TLA_PROP.STR_SFX_CD,
TLA_PROP.STR_SFX_DIR_CD,
TLA_PROP.STR_UNIT_TYP_CD,
TLA_PROP.UNIT_NBR,
TLA_PROP.UNIT_NBR_RNG_END,
TLA_PROP.ZIP_CD,
TLA_PROP.ZIP_CD_SFX,
TLA_PROP.CNCL_DIST_NBR,
TLA_PROP.PLAN_AREA_NBR,
TLA_PROP.ZONE_REG_CD,
TAPLC.PROJ_DESC_TXT,
TCASE.CASE_ID,
TCASE.CASE_NBR,
taplc.aplc_id
FROM TLA_PROP
INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR
INNER JOIN TLOC ON TLA_PROP.PROP_ID = TLOC.LOC_ID
INNER JOIN TAPLC ON TLOC.APLC_ID = TAPLC.APLC_ID
INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID
Advanced techniques
402
Participant , Sep 10, 2006 Sep 10, 2006
If you are going to use OR conditions with AND conditions you need to use parenthesis:
WHERE (TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%')
AND (TCASE.CASE_NBR = 'DIR-2004-4269-CWC'
Or TCASE.CASE_NBR = 'DIR-2004-4269-CWNC')
But if you are really hardcoding the case number values you are wasting time with a LIKE comparison so you could just have:
WHERE TCASE.CASE_NBR = 'DIR-2004-4269-CWC'
You might get a more efficient response if not atl...
Participant ,
You might get a more efficient response if not atleast more readable code with:
WHERE TCASE.CASE_NBR in ('DIR-2004-4269-CWC','DIR-2004-4269-CWNC')
Sep 11, 2006 Sep 11, 2006
thanks
hmm
there is an error
Error Executing Database Query.
ORA-00911: invalid character
The error occurred in D:.cfm: line 38
Called from line 38
36 : taplc.aplc_id
37 : FROM TLA_PROP INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR INNER JOIN TLOC ON TLA_PROP.PROP_ID = TLOC.LOC_ID INNER JOIN TAPLC ON TLOC.APLC_ID = TAPLC.APLC_ID INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID
38 : WHERE TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%')and TCASE.CASE_NBR = '#form.caseNbr#'
39 : </cfquery>
40 :
also,
what about the inner join question and question (3) below:
SQL SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR, TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR, Tref_plan_area.plan_area_desc, TLA_PROP.STR_FRAC_NBR_RNG_END, TLA_PROP.STR_DIR_CD, TLA_PROP.STR_NM, TLA_PROP.STR_SFX_CD, TLA_PROP.STR_SFX_DIR_CD, TLA_PROP.STR_UNIT_TYP_CD, TLA_PROP.UNIT_NBR, TLA_PROP.UNIT_NBR_RNG_END, TLA_PROP.ZIP_CD, TLA_PROP.ZIP_CD_SFX, TLA_PROP.CNCL_DIST_NBR, TLA_PROP.PLAN_AREA_NBR, TLA_PROP.ZONE_REG_CD, TAPLC.PROJ_DESC_TXT, TCASE.CASE_ID, TCASE.CASE_NBR, taplc.aplc_id FROM TLA_PROP INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR INNER JOIN TLOC ON TLA_PROP.PROP_ID = TLOC.LOC_ID INNER JOIN TAPLC ON TLOC.APLC_ID = TAPLC.APLC_ID INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID WHERE TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%')and TCASE.CASE_NBR = 'DIR-2004-4242-CWNC'
DATASOURCE
VENDORERRORCODE 911
SQLSTATE 42000
Hello ,
by
is this efficient??
(3)To a tcase_req
apologies
this is the error
The error occurred in D:\export\htdocs\CTS_RPTSTEST\HPOZFORMs4.2\act_search.cfm: line 38
Called from D:h.cfm: line 38
36 : taplc.aplc_id
38 : WHERE (TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%')and TCASE.CASE_NBR = '#form.caseNbr#'
39 : </cfquery>
40 :
SQL SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR, TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR, Tref_plan_area.plan_area_desc, TLA_PROP.STR_FRAC_NBR_RNG_END, TLA_PROP.STR_DIR_CD, TLA_PROP.STR_NM, TLA_PROP.STR_SFX_CD, TLA_PROP.STR_SFX_DIR_CD, TLA_PROP.STR_UNIT_TYP_CD, TLA_PROP.UNIT_NBR, TLA_PROP.UNIT_NBR_RNG_END, TLA_PROP.ZIP_CD, TLA_PROP.ZIP_CD_SFX, TLA_PROP.CNCL_DIST_NBR, TLA_PROP.PLAN_AREA_NBR, TLA_PROP.ZONE_REG_CD, TAPLC.PROJ_DESC_TXT, TCASE.CASE_ID, TCASE.CASE_NBR, taplc.aplc_id FROM TLA_PROP INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR INNER JOIN TLOC ON TLA_PROP.PROP_ID = TLOC.LOC_ID INNER JOIN TAPLC ON TLOC.APLC_ID = TAPLC.APLC_ID INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID WHERE (TCASE.CASE_NBR Like '%CWC%' or TCASE.CASE _NBR Like '%CWNC%')and TCASE.CASE_NBR = 'DIR-2004-4242-CWNC'
DATASOURCE
VENDORERRORCODE
SQLSTATE 42000
Resources:
thanks
never mind that error it was just the in and the sapce between the field namethanks
but the main prob is the inner join and the question below thanks
Hello ,
by
is this efficient??
(3)To a tcase_req
thnaks
Documentation
