1
How to place text INSIDE an irregular shape in InDesign
Enthusiast ,
Oct 31, 2011 Oct 31, 2011
I want to place text INSIDE an irregular shape in InDesign, so that the running text fills the entire shape. Is this possible? The desired effect is the opposite of a wrap around.
How to
78.8K
Guide , Sep 01, 2017 Sep 01, 2017
With all due respect Steve, rotating the Text frame is probably not he best option, unless it has 2 symmetrical axes.
If it hasn't, what I would suggest it to "reset" Text frame rotation to 0.
Adding a small frame on top of Text frame, then using pathfinder to Add them should do the trick.
See example:
Mentor ,
Select the irregular frame.
Object > Content > Text
Or just click inside it withthe text tool and start typing, or place text in it like any other text frame. Any drawn shape can be either a text or image frame just by using it as such.
Aug 31, 2017 Aug 31, 2017
when I do this the text appears upside down?
do you know the solution to this?
Choose the Type frame with the Selection tool. Then choose Object > Transform > Rotate 180 degrees
Guide ,
See example:
Yes, incorrectly, I assumed a symmetrical frame. You are probably right.
Mar 28, 2022 Mar 28, 2022
How did you get those boxes to pop up? I know how to in AI but not indesign. I only see "transform" and "pathfinder" under object. Not a specific window
? Which 'boxes' do you mean?
Or do you mean the Windows? Look under Window/Object & Layout.
quote
Just like AI, they are on the Window menu; Window > Object & Layout
Participant ,
Oct 04, 2017 Oct 04, 2017
Brilliant!
