Caption Widgets for Success, Failure and Hint
Oct 31, 2011 Oct 31, 2011
Is it possible to use the out of the box 5.5 caption widgets as the Success, Failure and Hint actions?
I can't seem to figure it out. Thanks for your help!
Getting started
809
Nov 01, 2011 Nov 01, 2011
Hello and welcome to the forum,
The default captions are built into the default quiz slides, they do not have a separate timeline. I do not believe you can replace them by a widget.
Lilybiri
Nov 02, 2011 Nov 02, 2011
Thanks Lilybiri. I wasn't using a quiz slide, just a regular button. Does that change anything?
You should be able to do it but it will take some work:
  • uncheck all captions in the Options accordion of the button
  • insert two widgets to be used for the Success/Failure caption and set them to invisible in the Properties panel
  • add the actions to show the proper widget as Success/failure actions for the button
  • for the Hint caption, you'll have to use a rollover slidelet with a widget on it
Lilybiri
Thanks! I will try that out. Doesn't seem too hard. That's unfortunate you can't do that with the button options.
Help resources
