Is it possible to use the out of the box 5.5 caption widgets as the Success, Failure and Hint actions?
I can't seem to figure it out. Thanks for your help!
Hello and welcome to the forum,
The default captions are built into the default quiz slides, they do not have a separate timeline. I do not believe you can replace them by a widget.
Lilybiri
Thanks Lilybiri. I wasn't using a quiz slide, just a regular button. Does that change anything?
You should be able to do it but it will take some work:
Lilybiri
Thanks! I will try that out. Doesn't seem too hard. That's unfortunate you can't do that with the button options.
