1 Reply Latest reply on Nov 3, 2011 9:14 AM by Zac Lam
    Encore "Don't Transcode" condition bug?
    Rallymax-forum Pioneer
      Zac et al,
      What are the conditions for Encore to leave a .264 stream alone (“Don’t Transcode”)?
      If you compare my PAL 576i25 H.264 stream (576i25_bff_letterbox_3.264) to the output of the CS5.5 bundled Main Concept version (576i25_bff_letterbox_MC.m4v) of the exact same footage the only difference seems to be interlaced method being “INTERLACED” vs “MBAFF” for interlaced material.
      I think this a bug on Encore’s part because MBAFF & INTERLACED are legal Blu-ray modes of interlaced media.
      I’m HOPING it’s not because I want this to work on CS3,4,5 and bugfix will presumably not get pushed back to older versions.
      If not, what is the condition that Encore doesn’t like?
      Note that Interlaced by MBAFF with NTSC (480i29.97) comes in fine.
      As does Progressive 1080p24 & Interlaced 1080i29.97 footage.
      It seems to only be PAL 576i25
      Also, fyi, I tried Upper and Lower Field First and they both acted the same way (as they should since field order doesn't matter it just has to be defined).
      General
      Complete name                    : M:\My Videos\576i25_bff_letterbox_MC.m4v
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      File size                        : 20.5 MiB
      Video
      Format                           : AVC
      Format profile                   : Main@L4.1
      Format settings, CABAC           : Yes
      Format settings, ReFrames        : 3 frames
      Bit rate mode                    : Variable
      Maximum bit rate                 : 6 000 Kbps
      Width                            : 720 pixels
      Height                           : 576 pixels
      Display aspect ratio             : 4:3
      Frame rate                       : 25.000 fps
      Standard                         : PAL
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Interlaced          <<<<<<<<<<
      Scan order                       : Bottom Field First  <<<<<<<<<<
      And here is my .264
      General
      Complete name                    : M:\My Videos\576i25_bff_letterbox_3.264
      Format                           : AVC
      File size                        : 20.3 MiB
      Video
      Format                           : AVC
      Bit rate                         : 5 000 Kbps
      Width                            : 720 pixels
      Height                           : 576 pixels
      Standard                         : PAL
      Color space                      : YUV
      Bit depth                        : 8 bits
      Scan type                        : MBAFF        <<<<<<<<<<
      Bits/(Pixel*Frame)               : 0.482
