Could somebody tell me what is causing Adobe LiveCyle to lose its mind and generate hundreds of lines that are merely repeats of this:
<?templateDesigner StyleID aped0?>
Here's an example of what it looks like for one field on a form. The tag is border.
<border presence="hidden">
The line is repeated 250 times !!
Is this a LiveCycle bug or did I do something screwy to cause this?
Could I just delete the duplicate lines from the XML?
<field minH="8.2042mm" minW="33.02mm" name="CPN" x="99.1101mm" y="8.2042mm">
<ui>
<textEdit>
<?templateDesigner StyleID aped0?></border>
<margin/>
</textEdit>
</ui>
<font typeface="Arial" weight="bold"/>
<margin bottomInset="0.254mm" leftInset="1mm" rightInset="1mm" topInset="1mm"/>
<para vAlign="middle"/>
<caption placement="top" reserve="2.54mm">
<font baselineShift="0pt" size="5.8pt" typeface="Arial"/>
<para marginLeft="0pt" marginRight="0pt" spaceAbove="0pt" spaceBelow="0pt" textIndent="0pt" vAlign="middle"/>
<value>
<text>4. COMPLAINT NO</text>
</value>
</caption>
<border>
<edge presence="hidden"/>
<corner presence="hidden"/>
<edge/>
<edge/>
<corner/>
<corner/>
</border>
<event activity="enter">
<script contentType="application/x-javascript">if (testscripts.enterFld(this)) {
var back="parent.Ten98";
var next="parent.IncidentNature";
jscripts.setTab(this,next,back);
jscripts.boxEdges(this);
}</script>
</event>
<event activity="exit">
<script contentType="application/x-javascript">if (testscripts.exitFld(this)) {
this.rawValue = IncidentNumber.formatIncNum(this.rawValue);
MNPD.Form130.MNPDTrackingNumber.rawValue = TrackingNumber.createTrackingNumber("AFR-FORM130",
MNPD.ND_Host.rawValue,
MNPD.ND_atsEmployeeNumber.rawValue,
this.rawValue);
console.println(MNPD.Form130.MNPDTrackingNumber.rawValue);
xfa.resolveNode("MNPD.#pageSet[0].PageArea1.CPN").rawValue = this.rawValue;
var r = testscripts.validateFld(this);
jscripts.unboxEdges(this);
testscripts.stepFld(this,r);
}</script>
</event>
<event activity="change">
<script contentType="application/x-javascript">xfa.resolveNode("MNPD.#pageSet[0].PageArea1.CPN").rawValue = this.rawValue;</script>
</event>
<bind match="none"/>
</field>
Solved! Go to Solution.
Total Likes
That was a bug in ES and was fixed in SP2..
http://blogs.adobe.com/ADEP/2009/03/post.html
Either you can manually delete those statements or upgrade your Designer with SP2.
Srini
Total Likes
Srini
Total Likes
Thank you so much!
Total Likes
I am using LiveCycle 7.1. Does SP2 also apply to that?
Total Likes
I’m using LiveCycle 7.1. Does SP2 also apply to that?
Total Likes
I'd suggest contacting technical support. They can work through this with you pretty easily.
Total Likes
Will do. Tomorrow morning.
Total Likes
