1. Re: Color management for web and print.
Tai Lao Nov 4, 2011 1:26 PM (in response to brwmmw)If you want to maintain maximum image quality, you do have to produce separate copies of your edited files, one for print and one for web.
2. Re: Color management for web and print.
Tai Lao Nov 4, 2011 1:28 PM (in response to brwmmw)The easiest way to accomplish that is to save a copy of your for-print finished file through Save For Web and Devices. It's not rocket science.
3. Re: Color management for web and print.
brwmmw Nov 4, 2011 1:55 PM (in response to Tai Lao)Thank you. I knew of this option but did not know if it was optimal quality. I assumed it wasn't "Rocket science" but unaware what the best option is since there are several. If someone is completely self taught you have to find things out some way. My photography business is growing fast and wanted to make sure I am saving files for maximum quality for clients. I have just been using the defaults in photoshop and using same files for web and print. I wanted to increase quality across the board in print and web.
What mode do you use for prints? I am giving prophoto rgb 16bit with raw files from d7000.
Thanks again for your response.
4. Re: Color management for web and print.
Tai Lao Nov 5, 2011 2:50 AM (in response to brwmmw)brwmmw wrote:
…I knew of this option but did not know if it was optimal quality…
You define the quality of the saved image in the Save for Web and Devices dialog box.
brwmmw wrote:
…I have just been… using same files for web and print. I wanted to increase quality across the board in print and web…
That is absurd! (Sorry.) By doing that you are generating unconscionably and unnecessarily large image files. You're clients won't like that.
Remember that you have no control over how anyone sees your images on the web. Something like 97% of Internet users are running non-color-managed web browsers and uncalibrated monitor.
You and you're clients are best served when you stick to the lowest common denominator, namely sRGB images, for web.
brwmmw wrote:
…What mode do you use for prints?…
Personally, I like to stay in 16-bit ProPhoto RGB when I print my images myself. If sending them to a pro lab, I discussed it with the lab techs. But I have gathered a lot of experience by now. One really has to know exactly what one's doing to edit in ProPhoto RGB and stay in that color space. If sending my images to a cheap lab like Costco, I stick to 8-bit tagged images that I soft-proof with the specific printer profile that will be used by the local store.
You should—and probably do—know that ProPhoto RGB has a very wide gamut that includes colors that cannot be printed by many printers, and it's up to you to compensate for that. If you run into problems with ProPhoto RGB consider converting to Adobe RGB for print. Make sure the printer drivers that will be used to print actually support 16-bit printing, otherwise convert to 8-bit.
Since you're a pro, I would warmly recommend you watch the video tutorials comprising the "From Camera to Print - Fine Art Printing" series by Jeff Schewe and Michael Reichmann, that are/were available for download from the Luminous Landscape. They're working on a new 2011 edition, but the 2008 edition was just superb. Best $35 or so I've spent in a long time.
http://www.luminous-landscape.com/videos/camera-print.shtml
____________
Wo Tai Lao Le (no connection to Adobe or Schewe/Reichmnan/Luminous_Landscape.)
我太老了
5. Re: Color management for web and print.
Tai Lao Nov 5, 2011 2:58 AM (in response to brwmmw)Incidentally, an image on the web that is created and saved with ProPhoto RGB is going to look like absolute cr@p to the millions (billions?) of Internet users who are using non-color-managed web browsers.
6. Re: Color management for web and print.
brwmmw Nov 5, 2011 7:45 AM (in response to Tai Lao)Well, I try to push my clients to the best lab in town, but I have no idea where they take them. I am sure there are some that go to cheaper places. I personally use smug mug and their printer is bay photo. I do anywhere from 5 minutes to 2-3 hours editing on a single picture. There are some I do quite a bit to and that is why I was trying pro photo as I have seen in several places on the web.
I guess maybe I am going to do this batch from my latest session in prophoto and do some test prints. I have seen a lot who do rgb1998 too.
I will definitely get the download. Thank you so much for the help. Are you on Nikon Rumors Forums by the way?
7. Re: Color management for web and print.
Tai Lao Nov 5, 2011 2:48 PM (in response to brwmmw)brwmmw wrote:
…Thank you so much for the help. Are you on Nikon Rumors Forums by the way?
You're welcome. Nope, I don't own a Nikon.
