recently i uninstalled flash in order to install a new version,
after this i discovered i could not install flash, and although
flash had been removed some animations could play,
furthermore the "about flash" or whatever ensured me that flash was still installed.
i uninstalled it through the control panel, a fatal mistake.
since then i have tried many times to use the flash uninstaller.
i have tried downloading special system tools.
i have searched and removed every folder and every registry entry
named "flash", "macromedia", "adobe" etc.
i have removed every visible trace of any adobe product just to be certain, with "Revo uninstaller".
i have uninstalled/reinstalled opera.
and i have then used a registry cleaner repeatedly.
i have looked through countless discussions to get help.
i cannot install any version of flash.
the "about flash" page still tells me i have flash installed.
is there anything more to do?
the only thing i can think of is reinstalling windows,
or buying a new computer.
or if someone let me know the location of every file
and registry entry associated with flash so i could remove them.
On Windows 7, 32bit the installation paths for the plugin are
For Microsoft Internet Explorer
C:\windows\system32\Macromed\Flash\Flash10x.ocx
For Mozilla Firefox
C:\windows\system32\Macromed\Flash\NPSWF32.dll
Read http://kb.mozillazine.org/Flash and http://kb2.adobe.com/cps/141/tn_14157.html
For Mozilla Firefox
I should have mentioned that i have Windows XP,
using Opera, as mentioned.
i did not find any flash10x.ocx,
i did however find a few flash.ocx files
on various places, which i removed.
i also found and deleted
NPSWF32.dll
NPSWF32_FlashUtil.exe
and flashplayer.xpt
mentioned in http://kb.mozillazine.org/Flash
there must be some traces left in the registry
since the installer constantly fails to initialize.
i have tried disabling the firewall and antivirus
while running the installer.
and i have tried all the standard instructions.
The browser does not claim that flash is installed anymore,
but the installers still fail to initialize when they start.
Download the installers from http://forums.adobe.com/thread/909550
If this installer also fails, please post the content of the FlashInsall.log file in C:\Windows\system32\Macromed\Flash
Also post what other files are in that folder.
apparently deleting:
NPSWF32.dll
and flashplayer.xpt
in addition to all the other registry search and destroy missions
erased the last traces of flashplayer.
i had to install it by clicking on a "broken" flash plugin window
rather than using the conventional installer.
so the problem is solved.
the world is safe, for now.
but i think there should be a flashing warning and a siren
whenever you try to remove flash from the control panel.
thank you for your assistance nonetheless.
Not quite sure what you mean by that; can you clarify?
there was an empty flash panel which said i had to
install flash for the panel to work,
so i clicked on that rather than downloading the usual
flash installer (which wouldn't work anyway).
Your computer may poisoning
umm... i don't think my computer is "poisoning",
though i'm not sure how to verify that.
