When I print out of CS5 on my Epson 7900 printer, the area around the photograph that is suppose to just be paper white (no ink) is printing a light grey. The grey fills the entire printable area of the sheet of paper. That grey does not print though, on the actual photograph....the photo prints fine. I thought it was the printer, but then I fired up CS4 and printed with no problems at all.....then I went back to CS5 and got the problem again.
I'm using all the current drivers etc. for the printer. I'm on a Mac Pro running SnowLeopard 10.6.3. If anyone has any ideas about what this might be, I'm listening!
You will need to use version 2 ICC profiles.
What are "version 2 ICC profiles"?
How are they different that the one's I have been using?
Update:
It seems to only do it with certain profiles but not all.
Correct - this is due to a MacOS ColorSync bug when using ICC version 4 profiles (which are included with the Epson drivers on MacOS 10.6).
To avoid that problem, you need to use ICC version 2 profiles (which were included in the 10.5.x drivers).
Also, Apple and the printer vendors are still working on fixes to this issue.
Considering I'm not using just Epson papers and profiles, I guess I'll have to wait to buy the license after the demo expires and see if this gets resolved.
I just tried the Canson Infinity Bayrta Photographique (with their ICC profile) and it too printed gray where it was suppose to be white.
Thanks Chris for your comments....at least now I know that it's not my printer screwing up.
Couldn't they have just left well enough alone, and however it was done in CS4...just transfered that over to CS5?
If it ain't broke, why fix it!
Back to CS4 I guess......too bad, I was really liking CS5.
CameraGuy - what license?
This has nothing to do with Photoshop. It's an acknowledged bug in MacOS.
The problem showed in Photoshop CS4 as well -- it first appeared (as far as we can tell) with MacOS 10.6.0. But we don't know where the bug is in ColorSync or when exactly it was introduced. So we don't know if it was added in 10.6 or of the newer printer profiles just exposed the bug at that point.
Chris....I only meant that after the demo expires that I would hold off buying the license until these issue were resolved, for I need to be able to print out of Photoshop with various papers and ICC profiles.
I guess I have been fortunate in that I have had no trouble printing out of CS4 with lot's of Epson and non-Epson papers. So I'm just saying that I will just stay with CS4 until this is resolved. What else can I do.
Thanks for your help in this matter.
Hi Chris -
Please see my response below. It has been over 7 months since your post and there still is no solution to the problem - I think you guys need to re-evaluate your role in solving this, because CS5 is the only application that does this on my workstation - I understand you believe there are framework issues you need to wait on from apple but please read the following:
If I print a 16 bit tiff in apple's Preview app and use colorsync to manage profile conversion for the paper type there are no problems with these 3rd party profiles - "pure white" is treated as such and the print head skips over areas that are "pure white".
However, printing with CS5 while using any non-epson ICC profiles causes the printer to print in areas that should be "pure white".
Are you 100% confident that the "canvas/background" set up in the CS5 print window is not also affected by the color management selection? Is it possible that the white area of the canvas is being sent as a Flattened image to be converted instead of just the image on the canvas?
I have this problem with my HP Pro B9180 as well. Hope Apple solves this soon…
This problem should be fixed in the 10.6.4 release of Snow Leopard.
Yes it has been fixed in 10.6.4. Images converted to Version 4 printer profiles now print without the gray.
Doyle
That's weird, I'm running 10.6.4 and for me it hasn't been fixed. I'm using Photoshop CS5 in combination with an HP Pro B9180 printer and Calumet's Brilliant Glossy paper and profile. Any idea what I can do to fix this?
Hayo
Yes there is something weird going on.
I just did a quick test again with CS5. When I printed using a Monaco generated V4 profile with perceptual rending intent I am getting no gray but with a ProfileMaker Pro V4 profile and relative colormetric I am getting a very light gray almost blue, but not the darker gray like before.
This needs a lot more testing.
Doyle
Thanks Jeffrey for posting -
There are still problems with CS5 printing ink in areas that should be "pure white" - everything works fine using Apple preview. Please look into this some more on your end now.
I set the canvas size to be the size of the paper..... and it worked... when you get the cyan y open the top of the printer and see how the head moves across the whole paper. then when you do the canvas size and make sure it is white I do both foreground and background then print head goes straight to the image and only prints the image.... same for PSE9 but not for LR3 that works perfectly
there are other profiles from monaco that works fine epson profiles only profiles from some supplier do this.....
cheers keep me informed..
I will be away from my printer for another week and cannot help you any more than from what I remember and wrote down...
cheers elo
what profiles do you use
open them up and check to see the maker... see tag "Pmtr"
Mac OS 10.6.4 did not do the trick...
I have the same problem with Photoshop CS5 (12.0.1), Mac Os 10.6.4 and Epson stylus Pro 4800.
The light cyan tone shows with every tested paperprofile so far (from hahnemuehle, sihl and my own custom-made profiles from a service provider).
I had my profiles checked from Phil Green from icc.org.
He says that they were fine.
At the moment I have an open case at Epson and here at Adobe.
I hope there is a solution - going back to 10.5.8 is not an option, as my brand new MacPro does not run under 10.5.8 any more....
Michael
That sounds like the ICC V4 profile bug in MacOS/ColorSync.
Using an older, V2 profile should avoid the problem.
Specificationversion of the profiles are 2.0.0 and 2.4.0
I am not really familiar with those specifications, as I am not profiling myself.
Among them are up to date profiles from the manufacturers website - hahnemuehle and sihl.
Both companies have discussed the issue and both say the profiles are o.k.
The same does Phil Green.
I could deliver the profiles for further investigation...
The only situation in which the issue does not appear:
1. Setting the printerprofile, Photoshop shall use, to sRGB
2. Setting the printerprofile, Photoshop shall use, to the paper profile, belonging to the media type chosen in the Epson Printer settings.
So something goes wrong in the transition from document profile over the papermedia-profile (embedded in the epson printer-driver) to the custom-paperprofile.
P.S. Absotute Colorimetric shows exactly the same behaviour around the picture.
Am 16.09.2010 um 00:25 schrieb Chris Cox:
The profiles might be ok, by themselves.
But MacOS 10.6 has some bugs in ColorSync that cause white areas to show gray or a color tint when you use version 4 profiles.
The OS and the printer driver use ColorSync, and can run afoul of this OS bug.
Yes, the problem happens when Photoshop hands the data to the OS, and the OS hands it to the printer driver. ColorSync makes a mistake in the conversion (even when there should be no conversion made).
these are the headers of two of the profiles...
How could I see if they are version 4 profiles?
Your profiles appear to be V2 (»Spezikikationsversion«), but the preferred CMM (»Bevorzugte CMM«) is set to Apple, which means ColorSync is being invoked. ColorSync (Apple's conversion engine) has been a mess for years. I'm always set to ACE (Adobe Color Engine).
____________
Wo Tai Lao Le
我太老了
The preferred CMM in the profile is ignored.
And yes, they are version 2.
So now I'm not sure why you'd be getting gray, unless the printer has it's own V4 profile getting into the mix.
Chris Cox wrote:
The preferred CMM in the profile is ignored…
That's a good thing—and a very wise feature.
Good to know. Thanks.
____________
Wo Tai Lao Le
我太老了
