I have a project where I have scrolling slides and I was wondering if I could delay the scrolling section of the slide while some text is being displayed, does anyone know if this is possible?
Thanks in advance
Assuming that you need to pause the slide somewhere in the middle of the video capture, you could try and copy paste a segment of the FMV several times where you want the pause to try and fudge it.
However, if you want better control over the duration of the pause, I would suggest the following:
Not sure I understand what you mean by "scrolling slides".
Do you mean that these are FMV slides capturing a scrolling window, and you want to pause the slide video while some text is displayed?
Rodward you are correct, how would I be able to paused a slide video?
This should give you roughly what you want. The first slide will begin playing the FMV, then the final frame of the video will remain visible while your text box displays near the end of that slide. Once the text box fades out and the next slide seamlessly transitions in, the rest of the FMV capture will continue to play. If you do it correctly, your audience should not be aware that what they're seeing is actually spread over two slides.
