I have been trying to install Flash Player off and on since June when I have had time to worry about it. I have Vista Home Premium and Firefox, 32 bit. I get a message saying that I have "insufficient permissions". I am the only user and I am the administrator. Flash does not show in Control Panel but when I use the version information on the Adobe Website I am told that I have 10,2,152,26 installed. I downloaded installer and ran it but I am still getting the same results. Please help.
OK, this gives all information that I need. Try the following:
You may need to use Unlocker if you have troubles deleting some files in the Flash folder.
Can you please post the contents of the FlashInstall.log file from C:\Windows\system32\Maccromed\Flash, or put the file as an attachment to your post.
Here is what I found:
=O====== M/10.1.53.64 2010-06-23+16-56-31.737 ========
0000 00000010 "C:\Users\Jack\AppData\Local\Temp\FlashPlayerUpdate.exe"
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
0012 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.53.64 2010-06-23+16-56-57.415 ========
=O====== M/10.1.82.76 2010-09-16+19-38-09.282 ========
0000 00000010 "C:\ProgramData\NOS\Adobe_Downloads\install_flash_player.exe"
=X====== M/10.1.82.76 2010-09-16+19-38-27.044 ========
=O====== M/10.1.85.3 2010-10-20+00-23-58.773 ========
=X====== M/10.1.85.3 2010-10-20+00-24-18.242 ========
=O====== M/10.1.85.3 2010-10-26+22-42-04.892 ========
0000 00000010 "C:\Users\Jack\AppData\Local\Temp\6BDF.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
0010 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.85.3 2010-10-26+22-42-24.860 ========
=O====== M/10.1.102.64 2011-01-30+18-55-46.110 ========
0000 00000010 "C:\Users\Jack\Downloads\install_flash_player.exe"
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
=X====== M/10.1.102.64 2011-01-30+18-56-46.696 ========
=O====== M/10.2.152.26 2011-02-18+19-04-38.369 ========
0000 00000010 "C:\Users\Jack\Downloads\install_flash_player(2).exe"
=X====== M/10.2.152.26 2011-02-18+19-04-52.509 ========
=O====== M/10.2.152.26 2011-02-18+19-11-53.944 ========
0000 00000010 "C:\Users\Jack\Downloads\install_flash_player(3).exe"
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10m_Plugin.exe
=X====== M/10.2.152.26 2011-02-18+19-12-22.847 ========
=O====== M/10.2.152.26 2011-02-18+19-17-35.707 ========
0001
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash10m.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10m_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10m_ActiveX.dll
=X====== M/10.2.152.26 2011-02-18+19-17-46.114 ========
=O====== M/10.2.152.26 2011-02-18+19-51-19.497 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil10m_Plugin.exe"
=X====== M/10.2.152.26 2011-02-18+19-51-34.693 ========
=O====== M/10.2.152.26 2011-02-18+19-51-50.776 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil10m_ActiveX.exe"
=X====== M/10.2.152.26 2011-02-18+19-51-54.091 ========
I cannot see any installer activity in that log since February 2011; it seems the installer aborted before it even opened the log file.
Can you try to download the installer from http://forums.adobe.com/thread/909550 and save it to disk. Then (after closing all browser windows) right click on it, and select 'Run as Administrator').
I still get the "insufficient permission" message. It is getting somewhat frustrating but I will stay with it as long as you do. Thanks.
Sorry, I have been away for a week.
Can you try to run the downloaded installer again, running 'as administrator' as described in my previous post?
If you still get the same message, can you check the Event Viewer for the time when the installation failed, if there are any further information on what permissions exactly are insufficient?
I do not know how to use "Event Timer". I did snip the message that I get and will try to put it in this message in .jpg format. If you can tell me how to use "Event Timer" I will try itThanks.
It worked. Thanks a million.
To the other place search
