3 Replies Latest reply: Nov 9, 2011 7:34 AM by maxotics RSS
    [VBS] Upload file FTP
    GunIva Community Member
      On my Mac I used this line in js to upload files to my print shop
      var myCurlScrpt = 'set curlShlScrpt to "curl ftp://myProxy.local:8021 -T \\"{" & "' + gDonePdfArray.join() + '" & "}\\" -u xxxx@ftp1.vvv.se:zzzzz"\ndo shell script curlShlScrpt';
      app.doScript(myCurlScrpt,ScriptLanguage.applescriptLanguage);
      Now I need to o this on a win box. I suppose VBScript is the way to go, unfortunately I have never written a single line in VBS and an example how to do this would be much appreciated.
        • 1. Re: [VBS] Upload file FTP
          John Hawkinson CommunityMVP
          This is not all that helpful, but:
          Your above script leverages the MacOS command-line tool "curl" to upload files to an ftp server. Windows does not ship with an analagous tool, unfortunately.
          You could download and install curl for Windows: http://curl.haxx.se/download.html, then you could use an analagous VBscript to construct a command-line to run curl. Otherwise, you'll have to find some other way to do it. You could script access to the command-line ftp client in VB, or perhaps find a VB library that supports ftp.
          Anyhow, hopefully that gives you a better idea what is going on...
          • 2. Re: [VBS] Upload file FTP
            Thanks, I was hoping for some kind of native support. I seems a little to complicated for me att the moment. I will have to do with the upload service on my print shops website.
            • 3. Re: [VBS] Upload file FTP
              maxotics Community Member
              TECHNIQUE using Windows Command/Dos .bat file.
              This is a technique for creating a .BAT file from a BAT file to.  I'm not modifying to your purpose, because I haven't worked with this in a while.
              @ECHO OFF
              :: Create the temporary script file
              > script.ftp ECHO username
              >>script.ftp ECHO mypassword
              >>script.ftp ECHO cd myremotedir
              >>script.ftp ECHO binary
              >>script.ftp ECHO prompt n
              >>script.ftp ECHO put C:\ff_Factory2007\MatchFunds\somefile.mdb
              >>script.ftp ECHO quit
              :: Use the temporary script for unattended FTP
              :: Note: depending on your OS version you may have to add a '-n' switch
              FTP -v -s:script.ftp ftp.fundexpenses.com
              :: For the paranoid: overwrite the temporary file before deleting it
              TYPE NUL >script.ftp
              DEL script.ftp
              GOTO End
              :End
              TECHNIQUE #2
              VBS.
              Option Explicit
              Dim objFSO, objMyFile, objShell, strFTPScriptFileName, strFile2Get
              Dim strLocalFolderName, strFTPServerName, strLoginID
              Dim strPassword, strFTPServerFolder
              'Customize code here to fit your needs
              strLocalFolderName = "My Folder Name where we put the file to be FTPed"
              strFTPServerName = "FTP Server Name"
              strLoginID = "FTP Server Login ID"
              strPassword = "FTP Login ID Password"
              strFTPServerFolder = "Folder Name on FTP server where the file resides"
              'The following code converts date to the right format, YYYYMMDD
              strFile2Get = DatePart("yyyy",Date)
              If DatePart("m",Date) < 10 Then
                      strFile2Get = strFile2Get & "0"
              End If
              strFile2Get = strFile2Get & DatePart("m",Date)
              If DatePart("d",Date) < 10 Then
              End If
              strFile2Get = strFile2Get & DatePart("d",Date)
              'The following code generates the file name on the FTP server you want to get
              strFile2Get = "Data" & strFile2Get & ".csv"
              'The follow lines of code generate the FTP script file on the fly,
              'because the get file name changes every day
              strFTPScriptFileName = strLocalFolderName & "\FTPScript.txt"
              Set objFSO = CreateObject("Scripting.FileSystemObject")
              If (objFSO.FileExists(strFTPScriptFileName)) Then
                  objFSO.DeleteFile (strFTPScriptFileName)
              End If
              Set objMyFile = objFSO.CreateTextFile(strFTPScriptFileName, True)
              objMyFile.WriteLine ("open " & strFTPServerName)
              objMyFile.WriteLine (strLoginID)
              objMyFile.WriteLine (strPassword)
              objMyFile.WriteLine ("cd " & strFTPServerFolder)
              objMyFile.WriteLine ("ascii")
              objMyFile.WriteLine ("lcd " & strLocalFolderName)
              objMyFile.WriteLine ("get " & strFile2Get)
              objMyFile.WriteLine ("bye")
              objMyFile.Close
              Set objFSO = Nothing
              Set objMyFile = Nothing
              'The following code executes the FTP script. It creates a Shell
              'object and run FTP program on top of it.
              Set objShell = WScript.CreateObject( "WScript.Shell" )
              objShell.Run ("ftp -s:" & chr(34) & strFTPScriptFileName & chr(34))
              Set objShell = Nothing
              If you need more help, I may not check forum, so email me at max [at] htgrp dot com
