I have a 64bit acer aspire 4741 laptop - Intel Core i5 CPU M 430 @ 2.27GHz 2.27GHz & 4GB Ram.
I have had flash player on it fine before, but it only works the 1st time it's downloaded as soon as I closed my laptop lid or shutdown, the plug in stopped working & I had to re-install it- a hassle but do-able.
I have sims 3 pets on it & it was working fine untill today when pets wouldnt open then crashed due to flash player not working (flash player worked fine for 2dys-which was a 1st & i thought that version had fixed the problem untill it wouldnt work today). I uninstalled flash player & tried to reinstall it again from the adobe site & this is what happens:
Click download
Click Save file - it downloads to downloads folder
double click flashplayer 11 installer\
dialog box with run comes up
Click Run, it closes
mouse icon shows processing circle for 10sec's then Nothing.............7 times this is what has happened!!!
There is no flash player installed at all - I installed flash player 10- the installer worked fine so think it's the fact my laptop is 0.03-0.06 GHz lower than required according to flash player 11's system requirements (figured this out AFTER deleting ALL flash players off of my system, so dont know what version of flash player I had yesterday!) & now cant play any games due to not being able to install flash player AT ALL- 10 didnt cut the mustard & pets along with a few other games wont open to play.
I have tried restarting my PC between installs- deleting all previous versions from my system (including from recycle bin)- All that seems to happen after clicking run is Adobe flash play installer shows up in task manager under running processes & I have to end it there inorder to try install flash player again other wise a dialog box saying only one instance of this can run at a time.
I need to know how to get flash player back on my system so I can use my computer & play my flippn games - I'm not a PC wizz, so basic & easy to follow would be good thanks lol
UPDATE...
After all of the above I THINK I've managed to get it flash player 11 to install by going to http://www.adobe.com/software/flash/about/ & using the pop up message that appeared under the taskbar saying 'missing plug-in' & having that directly install it on to my laptop - it did crash twice while installing but I just waited it out & it started working again- will remove this update if the games & what not still wont work....fingers crossed.
Message was edited by: Amaunet
Go through the following steps
1.Download it on the desktop by clicking on this link http://get.adobe.com/flashplayer/
2.close all the application's and the browsers.
3.uninstall the old version before you download the latest version and make sure all the application's and the browser's must be closed.
4.click this link to uninstall for window's http://kb2.adobe.com/cps/141/tn_14157.html
5.clik this link to uninstall for Mac http://kb2.adobe.com/cps/909/cpsid_90906.html
And then it will work fine trust me.......All the best
Thanks for that- that did not work, I dont know why as I had deleted adobe Flash player totally off of my system- every version of flash player right down to the icon (not even a search would bring anything up, so it was gone!) What ended up working was downloading it directly through the missing plug-in popup that appeared when I went onto the what version of flash player page
Hello,
I have the same problem with my Asus P52F under windows 7 pro 64 bits.
Everytime i reboot my conputer i need to reinstall flash player.
The web page show "an error has occured with this directive", i can see that the latest version of the player is installed but it don't work's.
I try the solution given by SUNNYCHATLANI but the is still present 😞
Does anyone have the solution ?
Use the installer from http://forums.adobe.com/thread/909550
Thank's but the problem is not resolved
Everytime i reboot my pc FP don't run correctly under IE and the windows desktop.
With Firefox, FP runs correctly without needed a reinstallation.
The problem is coming from the activex version under windows 7 64 bits.
See if any of these FAQ entries help:
thanks
My problem is not resolved
You need to provide some details, e.g. after a reboot, is the Shockwave Flash Object still enabled, or disabled, or missing? Is the ActiveX (OCX) still present in C:\Windows\system32\Macromed\Flash and C:\Windows\syswow64\Macromed\Flash ?
After reboot the shockwave Flash Objet is still enabled.
In the folder C:\Windows\SysWOW64\Macromed\Flash there is these files :
Flash11c.ocx
FlashInstall.log
flashplayer.xpt
FlashUtil11c_ActiveX.dll
FlashUtil11c_ActiveX.exe
FlashUtil11c_Plugin.exe
NPSWF32.dll
In the folder C:\Windows\System32\Macromed\Flash there is these files :
Flash64_11_0_1.ocx
FlashInstall.log
FlashUtil64_11_0_1_ActiveX.dll
FlashUtil64_11_0_1_ActiveX.exe
FlashUtil64_11_0_1_Plugin.exe
NPSWF64_11_0_1.dll
That looks all perfectly correct...
Can you see the Flash animation at http://www.adobe.com/software/flash/about/ (after the reboot)?
No, you can see on my message from 8 nov. that the site returns [an error occurred while processing this directive]
in the Version Information frame i have : You have version 11,0,1,152 installed
If i try this site with Firefox, the animation run correctly.
Sorry for that; yes, you already posted that information.
Just to make sure:
If both the above are true, can you try to install the latest Flash Player version 11.1.102.55?
I have the same problem with FP 11.1.102.55
