Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
"Using ColdFusion with Flex" samples dont work!
Avatar
Level 2
Has anyone successfully gotten ANY of the FDS samples to work
from the Flex and Coldfusion Dev Center?
I am about to give up on using FDS, lack of documentation, no
working examples, bugs, problems galore, grrrrrr!
If you have gotten
Using ColdFusion with Flex – Part 1: Creating and
running a Contact Manager application
or
Using ColdFusion with Flex – Part 2: Creating and
running a CRM application
please post a step by step on how you got it to work. Thank
you sooooooooooo much!!
Avatar
Level 2
Level 2
This is not the ONLY way but here is a simplified
step-by-step approach to running the CRM Sample on Windows in 7
Steps:
1. Download and Install Flex Data Services 2 Express to the
built-in web server on port 8700 (default installation)
http://www.adobe.com/go/tryflex
2. Open a command window and go to
c:\fds2\jrun4\bin
3. Start the default server by typing
jrun –start default
4. Open a browser and request the sample apps page at
http://localhost:8700/samples
5. Click
CRM Sample
6. Click
Run CRM
7. Respond to the prompts to install Flash Player 9 if
necessary
(If mxml page is blank, close the browser and click on
Run CRM again)
You should see the Flex CRM sample application and data
Avatar
Level 2
Level 2
Sorry, I gave you instructions on the FDS CRM sample without
the CF backend.
Here are the steps to getting the Contact Manager application
from
http://www.adobe.com/devnet/flex/articles/coldfusionflex_part1.html
up and running:
2. Download and install ColdFusion MX 7.02 to the built in
web server on port 8500
http://www.adobe.com/go/trycoldfusion
3. Download and install Flash Player 9
http://www.adobe.com/go/getflashplayer
4. Download and install Flex Builder 2 (for the ColdFusion
Extensions)
5. Download contact_sample.zip
6. Unzip contactmgr.mxml, Hourglass.mxml, mini.mxml,
wait.png, and Contact.as to C:\fds2\jrun4\servers\default\samples
and
be sure “Use folder names” is checked!
7. Open C:\fds2\resources\config\services-config.xml in your
favorite text editor
8. Select and copy:
<!-- ColdFusion specific RTMP channel -->
<channel-definition id="cf-dataservice-rtmp"
class="mx.messaging.channels.RTMPChannel">
<endpoint uri="rtmp://{server.name}:2048"
class="flex.messaging.endpoints.RTMPEndpoint"/>
<properties>
<idle-timeout-minutes>20</idle-timeout-minutes>
<serialization>
<!-- This must be turned off for any CF channel -->
<instantiate-types>false</instantiate-types>
</serialization>
</properties>
</channel-definition>
<!-- ColdFusion specific HTTP channel -->
<channel-definition id="cf-polling-amf"
class="mx.messaging.channels.AMFChannel">
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/messagebroker/cfamfpolling"
class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<serialization>
</serialization>
<polling-enabled>true</polling-enabled>
<polling-interval-seconds>8</polling-interval-seconds>
</properties>
9. Open
C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\services-config.xml
in your favorite text editor
10. Paste the copied text just under the last
</channel-definition> tag and above the closing
</channels> tag
11. Save
12. Open
C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml
13. copy and paste the following to just under the last
<adapter-definition id> tag and just above the
</adapters> tag:
<adapter-definition id="coldfusion-dao"
class="coldfusion.flex.CFDataServicesAdapter"/>
14. Open C:\fds2\resources\config\data-management-config.xml
15. Select and copy:
<!-- ColdFusion Sample - Contact sample application
<destination id="cfcontact">
through all of this code (roughly lines 288-395):
Determines whether order is important for this filled
collection. Allows for
performance optimization when order is not important.
Optional. Default value is true.
<ordered>true</ordered>
</fill-method>
</server>
</properties>
</destination>
16. Paste the copied text to
just under the last </destination> and just above the
</service> tag
17. Unzip Contact.cfc, ContactDAO.cfc, ContactAssembler.cfc,
test.cfm and contact.mdb to C:\CFusionMX7\wwwroot (Built-in web
server root on port 8500) and
18. Logon to the Coldfusion Administrator
19. Create a datasource called FlexDataServices and point it
to
C:\CFusionMX7\wwwroot\contact_sample\samples\contact\db\contact.mdb
(Be sure the datasource verifies ok)
20. Create a mapping called samples mapped to
21. Test the Coldfusion side of the application by requesting
http://{server_name}:8500/contact_sample/samples/contact/testContactAssembler.cfm
You should see the following output:
Output from Fill
8 records
Tom Jordahl
Joe Doe
Randy Crew
Testing Man
Jim Dandy
Bill Sahlas
William Chan
Jack Sahlas
22. Open
C:\fds2\jrun4\servers\default\samples\contact_sample\dataservice\contact\contactmgr.mxml
in your favorite text editor.
23. Find this line of code: ds = new
DataService("cfcontact");
24. Change cfcontact to cfcontact-default
25. Save and exit all edited files
26. Start Flex by typing “jrun –start
default” at c:\fds2\jrun4\bin
27. Request the Contact Manager sample by requesting
http://{server_name}:8700/samples/contact_sample/dataservice/contact/contactmgr.mxml
28. You should see the Contact Manager application data
Avatar
Former Community Member
Hi, I have a similar problem, as shown below: I think it is
where I place the contact.as. I have moved this file to various
positions but always get the same results. Can someone pse help
cause 'I am dying here'.
Watson
Compilation Results
Errors, warnings or exceptions were found while compiling
/contact_sample/dataservice/contact/contactmgr.mxml. Visit the
online Flex documentation or API reference for further information.
4 Errors found.
Error /contact_sample/dataservice/contact/contactmgr.mxml:31
Definition samples.contact could not be found.
30: import mx.rpc.events.*;
31: import samples.contact.*;
32:
Error /contact_sample/dataservice/contact/contactmgr.mxml:37
Type was not found or was not a compile-time constant:
Contact.
36: [Bindable]
37: public var contact:Contact;
38:
Error /contact_sample/dataservice/contact/contactmgr.mxml:81
Access of undefined property Contact.
80: dg.selectedItem = event.item;
81: contact = event.item as Contact;
82: }
Error /contact_sample/dataservice/contact/contactmgr.mxml:102
Call to a possibly undefined method Contact.
101: dg.selectedIndex = -1;
102: contact = new Contact();
103: }
Avatar
Level 2
Level 2
It looks like your contact.mxml can't find the contact.cfc
Be sure you followed step #17 correctly.
Was the test in step #21 successful?
Avatar
Level 2
Level 2
In response to a comment from
this
thread
regarding steps #23 and #24, apparently they are not
necessary:
An edit must have been made to the
":\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml"
file in the walk-through used for this step-by-step.
Avatar
Level 2
Im sorry, this is just exremely fustrating. I had it working
once, now i cant get it to work again. When i had it working the
first time, i modified the {server.name} with my IP address and it
seemed to work. Doing it again however does not.
Now when i run this app at
http://localhost:8700/samples/dataservice/cfcontact/contactmgr.mxml
I receive an immediate error stating: "error invoking
fill-method 'fill' for destination cfcontact: Permission denied"
Question on #17 "be sure “Use folder names” is
checked!" what is this referring too?
Here is what my configuration looks like:
<adapters>
<adapter-definition id="actionscript"
class="flex.data.adapters.ASObjectAdapter" default="true"/>
<adapter-definition id="java-dao"
class="flex.data.adapters.JavaAdapter"/>
</adapters>
<adapter ref="coldfusion-dao"/>
<channels>
<channel ref="cf-dataservice-rtmp"/>
<channel ref="cf-polling-amf"/>
</channels>
<properties>
<component>samples.contact.ContactAssembler</component>
<scope>request</scope>
<access>
<method-access-level>remote</method-access-level>
</access>
<property-case>
<force-cfc-lowercase>false</force-cfc-lowercase>
<force-query-lowercase>false</force-query-lowercase>
<force-struct-lowercase>false</force-struct-lowercase>
</property-case>
<metadata>
<identity property="contactId"/>
</metadata>
<network>
<!-- Add network elements here -->
</network>
<server>
<fill-method>
<use-fill-contains>false</use-fill-contains>
<auto-refresh>true</auto-refresh>
</fill-method>
</server>
</properties>
</destination>
<properties>
<serialization>
</serialization>
</properties>
<endpoint uri="
<properties>
<serialization>
</serialization>
</properties>
<pattern>DataService.coldfusion</pattern>
CFCs are located at: C:\CFusionMX7\wwwroot\samples\contact
mappings: /samples C:\CFusionMX7\wwwroot\samples
http://localhost:8500/samples/contact/testContactAssembler.cfm
is showing data returned.
Flex app is at:
My application files are at:
C:\fds2\jrun4\servers\default\samples\dataservice\cfcontact
updated contactmgr.mxml with ds = new
Thanks for any ideas!!!
Avatar
I am getting this error
Compilation Results
1 Exception found.
Exception flex.messaging.config.ConfigurationException
Configuration error encountered on line 94, column 7: 'The
element type "services-config" must be terminated by the matching
end-tag "</services-config>".'
Any Ideas? I can't find the unterminated element.
Avatar
Level 1
Level 1
hi,
i have teh same problem as "dr. goomba", but with the CRM
sample.
i receive the error eror message:
"error invoking fill-method 'fill' for destination cfcompany:
Permission denied"
coldfusion
http://localhost
fds
i have changed all config files as described here:
www.adobe.com/devnet/flex/articles/coldfusionflex_part2_02.html
the console output does NOT display this infos:
[Flex] [CFDataServicesAdapter] Configuring CFC adapter for
destination cfemployee
thanks in advance
herbert
Avatar
Level 1
Before I discovered this forum thread, I fumbled through the
application, but eventually figured out the various little problems
with it. I blogged my annotations to the article here:
http://www.talkingtree.com/blog/index.cfm/2006/12/20/FDS-CFMX702-ContactManagerApp
In particular, I found that the most critical correction
regards making the DataService creation match the same name used in
the destination id for the Contact App destination.
The destination id already is "cfcontact" not
"cfcontact-default", and by default the contactmgr.mxml initApp()
method uses
ds = new DataService("cfcontact-default");
so that must be chnaged to
ds = new DataService("cfcontact");
to match the desintation id
