17 Replies Latest reply: Nov 11, 2011 6:16 AM by Harm Millaard RSS
    Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
    Dvico Community Member
      Dear All!
      Id like to ask your opinion about this: is it worth to switc from pc to mac with this hardware : iMac i7 3,4Ghz Quad core 16GB 1333MHz AMD RAdeon 6970M 2GB DDR5 256GB SSD for OS, and 1TB 7200rpm HDD for data store.
      My current desktop pc now:
      - I7 Sandy Bridge 2600 (3,4GHz)
      - ASUS P8P67 Deluxe MOB
      - 16GB DDR3 RAM
      - Nvidia GTX470 Asus
      - OCZ Revodrive x2 (PCI-E SSD) for OS Windows7 Pro
      - Corsair 240GB SSD for cache files
      - 2pcs Samsung spinpoint 7200rpm 1TB each in RAID
      - WD 2TB HDD data store
      - Corsair 850W PSU
      S what do you think.?Im curious about your experience.I never used mac (except Iphone4 :-)
      Thanks.
        • 1. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
          lasvideo CommunityMVP
          My overall impression from reading posts on this forum is that PCs seem to get better performance from Premiere Pro than Macs.
          • 2. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
            Mostly I would use for  editing avchd 1080p footages , with AE graphic titles and effects.
            • 3. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
              JSS1138 CommunityMVP
              For the money, you will get better performance out of a PC than a Mac.  So whatever you spend on a new Mac, you can get something that will perform better in a PC for the same price.  (Especially if you build it yourself.)
              Plus, a PC has the added advantage of not being a Mac.
              • 4. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                hiphopsuperman Community Member
                That's asking a very loaded question. You will pull your hair out trying to find a concrete answer to that because everyone seems to be an expert. For me, it was simple. I realised that more often than not, when I watched a Pr or Ae tutorial online, the person was using a Mac. My logic may be flawed, but I figured that was a good sign.
                But, as mentioned above, you will get a more powerful PC than Mac for the cost.
                • 5. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                  PeertjeX10
                  The best thing you could do is installing OSX on your PC. Google for Hackintosh (tonymacx86).
                  For the best comparing, make your system dualboot and install Pr and AE on Windows and OSX (lion).
                  Good luck and let me know.
                  • 6. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                    Thanks for all.I google this question, and lot of people said that after than switched to new iMac 2011 i7, they dont want to go back a PC.I know more expensive a Mac.But I use a hardware ( see top of the conversation) and Im not satisfied.More precisely not satisfied to work together AE and PP CS5.5.Premiere alone is great.But the realtime preview in AE is very poor, and to render every 5 minutes the composition to see the result is very time-consuming.But I checked all the settings, what Adobe sites and forums offer.
                    And  I talked to a Mac distributor and he said they edit hd videos on Macbook and the editing was great.Cause Apple optimised
                    a software & hardware together on a Mac.(Of course they want to sell their products).
                    And in the past I spend more time to figure out the best config, to replace hardware items one to one.Reinstall windows again and again.These are the things why Im thinking about iMac.
                    Is there somebody who used win7 on pc and OSx on a mac for AE and PP CS5.5? Who knows de difference?
                    Thanks again.
                    • 7. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                      A Mac distributor has a bias, of course hes going to tell you they are great.  Ive had this Mac Pro and it worked fine with FCP. But as much as I like it, I will be switching to a PC in the near future. Most high end folks that do compositing for films use PCs, not Macs.  Mac is on a downhill slide and more and more professionals will be abandoning it. There will be no more Mac Pros which is the work horse for most pro editors. I have had and loved this maschine for 4 yours, but the writing is on the wll. Careful research will reveal PC users have less problems with CS5 than Macs do. Your system may not be ideally designed for video work . On this forum Harm is the fellow you should speak to. He could help identify any issues you might have.
                      • 8. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                        Harm Millaard CommunityMVP
                        If you want to burn money, this is the way to go. Your PC is much faster than a MAC, you will lose the hardware MPE, you lose lots of expansion capabilities, you lose affordable access to all kinds of utilities, you lose overclocking capabilities, etc., but if you want to spend lots of money and are only willing to plug in the machine to a wall outlet, forget about tuning and take all the limitations for granted, the MAC may be the right choice.
                        • 9. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                          Harm, looking at his specs at the top, can you give him any insight about its strength and weaknesses and make some suggestions what he can do to enhance its performance with CS5?
                          • 10. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                            Fuzzy Barsik Community Member
                            Who knows the difference?..
                            Ask ExactImage - he is probably the most recent switcher from Mac to PC on this Forum...
                            • 11. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                              Harm convinced me again.I will continue to find out to make it faster my pc.:-)
                              Or find out what would be the problem of AE and hw settings...
                              Thanks.
                              • 12. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                With over 540 systems now in the benchmark, I hope you forgive me for not remembering your submission, if you ever did, but try it out here: PPBM5 Benchmark
                                or give me your compouter ID and I will have a look at your results. Your system should run perfectly stable and fast. If not, I may have some suggestions for you to improve performance. If you don't shoot, you will never score.
                                • 13. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                  jasonvp Community Member
                                  I'm not going to get into the architecture pissing wars that always break out here, but you're saying a couple of things that need to be corrected.  The first is that there will be no more Mac Pros.  Absolutely incorrect.  Apple is waiting for the Sandy Bridge multi-chip server processors to become available from Intel (later this month) before they release a new Pro.  Mac Pros are always built with server chips, for better/for worse.  It's what makes them cost so damn much money.
                                  As far as the "less problems" line, that's an Adobe thing.  The platform is there and ready to be used, it's just going to take some effort on Adobe's part to get their specific applications working properly with OS X.  That's not the fault of the Mac, or OS X.  It's an application development issue.  Note, of course, that within the last few years, Apple and Adobe haven't been best of friends unlike the 80s and early 90s.  So we'll just have to see where that pans out.
                                  For the OP: I'd shy away from using an iMac for editing with PPro.  You're very limited as to the hardware you can add to it, such as extra disks, a better video card for CUDA processing, etc.  It's not a very idea system, even if it does have a fast processor in it.
                                  jas
                                  • 14. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                    Dear Harm!
                                    I prepaired my results now.You will see on the site soon.My comp ID : SanchoPPMB5.Based on this results you can give me advice for dynamic link and AE too? Cause I dont have problem with the speed of PP5.5 itself.
                                    Except I use together with AE + dynamic link.
                                    I checked an After Effects RAM preview and its slow, while the computer just  use less than 10GB RAM from the available 13GB ( other 3GB for other apps.)
                                    Anyway Im pleased to your advise, so if you have time snd me a post.I read on the web for dynamic link and for AE better to use 24GB RAm, or more.(This means needs 6core cpu,cause in SB motherboards can install 16GB only)
                                    Thanks.
                                    • 15. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                      I added your data to the results page. You rank currently at #221. Easy to find if you click twice on the Date header to sort descending and your results are right at the top of the list. What is disappointing in your results is the MPEG score as you can see in comparison to the entry of keroppi right below your own entry with an almost identical system. Your MPEG score is 172 and his score is 47 seconds. One major difference is of course that you use 5.5 and keroppi uses 5.03, but even with that in mind your score is not up to par. I would have expected a score around 120 seconds. Again easy to find if you select only CS5.5 on the version tab and i7-26xx on the CPU tab and compare your results with others. That indicates to me that you have some background processes that are clear memory hogs and that also explains why the AE renders are relatively slow, because then the remaining 3 GB for non-Adobe applications may become a bottleneck. Before going thru all your running processes, you could try to reserve 4 GB for other applications and see if that solves the slow rendering in AE. If not, make a screenshot from Process Explorer (http://technet.microsoft.com/en-us/sysinternals/bb896653) and post it here.
                                      • 16. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                        Im sorry but not clear what you mention here: "Before going thru all your running processes, you could try to reserve 4 GB for other applications and see if that solves the slow rendering in AE" I dont know what I have to do.When  I  made  the PPBM5
                                        I set the memory use setting like this (totally I have 16GB) : 13GB for Adobe ( AE & PP & A Media Encoder ) and 3GB for other apps.If I set leave 4GB for other apps there will be any difference?I think I missunderstood something.
                                        Later I download Process explorer and send the result, but when I have to make a screenshot? during AE RAM  preview or during render the benchmark process again?
                                        Thanks !
                                        • 17. Re: Switch to Mac from PC to get a better performance AE & PP CS5.5 ?
                                          Generally I like to keep things very simple. In this case you may - maybe - be helped by increasing the amount of memory for other applications from 3 GB to 4 GB in the Preferences. If that does not work to your satisfaction, then let's take the next step and you start Process Explorer and post the screenshot of the list of processes.
