Show 2 replies
1. Re: Robohelp 9 numbered HTML lists problem
ZeBarron Nov 11, 2011 12:42 AM (in response to tetard911)Are you sure it actually restarts from zero? Have you checked the HTML code? My initial thought after reading this was that you might have some issues with CSS margins and alignments hiding the number in front of your zero. Numbers that should be 10, 11 etc. but shows up as 0,1, 2,3 etc.. Anyways, I would post an image that visualizes your output from RH.
Edit: Have you tested a larger list (20+) to see if things are repeated?
2. Re: Robohelp 9 numbered HTML lists problem
tetard911 Nov 11, 2011 1:54 AM (in response to ZeBarron)Many thanks the margins were the problem.
Of course I should have thought of the margins in the CSS but it's a rush job with not much time to think of anything!
