I installed Active Directory Certificate Services. Now I want setup LDAP over SSL. Unfortunatelly it doesn't work. I pressed "Test" and always get "Invalid username or invalid password" (
German: "Ungültiger Benutzername oder ungültiges Kennwort"). I'm pretty sure username and password are fine (it worked before I installed Active Directory Certificate Services and used LDAP without SSL).
On server.log, I got this:
2011-11-12 00:51:28,202 INFO [com.adobe.idp.um.businesslogic.synch.LdapHelper] Following stacktrace is generated due to the Test LDAP Server Configuration action
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1]
at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3041)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2987)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2789)
at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2703)
at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:293)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:175)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:193)
at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:136)
at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:66)
at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:667)
at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:288)
at javax.naming.InitialContext.init(InitialContext.java:223)
at javax.naming.ldap.InitialLdapContext.<init>(InitialLdapContext.java:134)
at com.adobe.idp.um.businesslogic.synch.LdapHelper.createContext(LdapHelper.java:663)
at com.adobe.idp.um.businesslogic.synch.LdapHelper.testServerConfig(LdapHelper.java:682)
at com.adobe.idp.um.ui.config.ConfigDirectoryEditAction.testServerSettings_onClick(ConfigDirectoryEditAction.java:215)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.cc.framework.adapter.struts.ActionUtil.handleFormAction(Unknown Source)
at com.cc.framework.adapter.struts.FWAction.handleFormAction(Unknown Source)
at com.cc.framework.adapter.struts.ActionUtil.execute(Unknown Source)
at com.cc.framework.adapter.struts.FWAction.execute(Unknown Source)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.adobe.framework.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:173)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.adobe.idp.um.auth.filter.AuthenticationFilter.doFilter(AuthenticationFilter.java:154)
at com.adobe.idp.um.auth.filter.PortalSSOFilter.doFilter(PortalSSOFilter.java:91)
at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:433)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:543)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:580)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Do you have some Idea?
cu Floh
Total Likes
