12 Replies Latest reply: Nov 13, 2011 1:58 PM by shooternz RSS
    distorted movie file
    robirdman1 Community Member
      PP 5.0: I worked with an AVI file from the Nikon D300s camera. I had read the info on choosing the right parameters and have it as 1280x720.  It appears correct proportionally in the monitor windows.  When I go to export it, I choose Quicktime movie. There are a number of choices such as PAL DV Widescreen, NTSC DV, etc.  It seems not to matter what I choose, visually in the preview..  When viewed in Bridge or played they appear stretched vertically or compressed horizontally. With the NTSC it says that they are now 720x480. How do I get them to appear undistorted?
      Also, when I try to browse in Bridge in PP it doesn't come up.  Where is it supposed to be in the file directory to correctly appear?
        • 1. Re: distorted movie file
          Bill Hunt CommunityMVP
          What is your intended delivery format.
          What is the PAR (Pixel Aspect Ratio) of your footage. 1280 x 720 is usually anamorphic, so will likely have a PAR = 1.3333. If the footage is not Square Pixels, then that could be part of the issue.
          With DV NTSC, one has a choice of 0.9, or 1.2 PAR's.
          Good luck,
          Hunt
          • 2. Re: distorted movie file
            JSS1138 CommunityMVP
            You have to tell your media player to play it that way.  Most times it doesn't happen automatically.
            • 3. Re: distorted movie file
              shooternz Community Member
              Forget about the media player suggestion.
              Here is how I do it from any  HD source ( ie. from the edit sequence / timeline).
              In AME I immediately go to the output tab after selecting .wmv, QT, flv ..whatever...
              I choose a square pixel output. ( Very Important Step - do not choose a PAR apart from square!)
              I unlock the proportional setting for the pixel dimesion so that I can vary it...then  trial and error either, the Vertical or horizontal  (depending on the particular output requirement)  so as that I do not have any black bars  on  sides or top/bottoms showing in the "Output Tab"
              That exported  file will always play perfectly and correctly in any media player without compression or squeeze.
              Only other step I use in this process  : - Data Rate. (to control file size for various reasons)
              FWIW: I have presets for a variety of  these I regulalrly use ... but all are based on this process.
              • 4. Re: distorted movie file
                Ann Bens CommunityMVP
                1280x720 will always be square pixel never a par of 1.33.
                • 5. Re: distorted movie file
                  Except it won't go onto a DVD, and probably won't be accepted for broadcast.  Square pixels are a valid option for web or computer playback (the preferred option even), but folks should know about the manual unsquishing for media that needs an NTSC or PAL defined ratio.
                  • 6. Re: distorted movie file
                    Make sure you update to 5.0.3.
                    • 7. Re: distorted movie file
                      Yes but the problem is... the OP is attempting to use a DV Codec (DV)  instead of  something that suits his 16:9 footage (timeline).  I do not believe he is particularly wanting it in a DV (SD) format.
                      Jim : I also dont think the OP was talking about broadcast or DVD in this instance.
                      • 8. Re: distorted movie file
                        One could also set the crop proportions in the export settings to 16:9 if its for the web etc.
                        If its broadcast or dvd then export to mpeg2-dvd and not dv avi.
                        • 9. Re: distorted movie file
                          Oops - caught me. Should have been HDV Anamorphic 1440, which has a PAR - 1.333 (and not 1280. My bad).
                          Thanks for that correction,
                          Hunt
                          • 10. Re: distorted movie file
                            I want to put the videos on a DVD that can be played in common usages.  According to the file properties, it says PAR is 1.0.
                            • 11. Re: distorted movie file
                              I seem to be missing something.  I have a sequence in the timeline.  I choose FIle> Esport > media > Quicktime. There is an output tab to the right of source tab. I don't see anything about the PAR to choose.
                              • 12. Re: distorted movie file
                                Export directly to Encore for a DVD. (Dynamic Link.)
