1. Re: Bizarre TOC bug from Find & Replace window
Captiv8r Nov 14, 2011 7:44 AM (in response to steverile2)Hi there
You likely aren't aware of this, but most seasoned RoboHelp users long ago learned it's best to avoid going near the "Find and Replace in Files" feature of RoboHelp. You are much better off using a separate utility such as FAR.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
2. Re: Bizarre TOC bug from Find & Replace window
steverile2 Nov 14, 2011 9:21 AM (in response to Captiv8r)...it's not the first bug I've reported in F&R. I've got FAR anyway, so will back away and use that. Unless I'm looking for some danger. Odder still, I duplicated the bug 3 or 4 times consistently and then showed a colleague. It worked flawlessly then of course.
3. Re: Bizarre TOC bug from Find & Replace window
Captiv8r Nov 14, 2011 9:26 AM (in response to steverile2)steverile2 wrote:
...It worked flawlessly then of course.
LOL, isn't that always the case? Sort of like the "critical need" sensor built into every PC. It senses you really need something and promptly crashes and refuses to come back until the time of need has passed. Then, of course it resumes operation as if nothing was ever wrong!
Cheers... Rick
