38 Replies Latest reply on Jul 24, 2014 6:14 PM by A.T. Romano
    Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
    SetAdMichael Level 1
      Hi all,
      have spent my hole day at my brother but still no idea what this error could be. After having this project in APE 8.0 and editing it now with the newly bougt Verion 10.0, everything was fine... Opened and saved it several time but today there were suddenly problems: Even a complete new project with the same material and same cut is now broken after having saved and exportet it....
      When we are trying to open the project, we're getting the error:
      "Premiere Elements has encountered an error.
      [d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142]
      CONTINUE
      And in the next window:
      Project could no be loaded. It's damaged oder has old elements (not same words, cause my brother is using the german version)
      I have tried everything so long: new installation, opening the damaged project on another computer with ELements 8.0 (identical error also there), deleting cahe, deleting Prefs, loading Auto-Backup (also damaged) and so on... Another "Test-Project" I have created with 2 clips is working fine.... I have no idea what to to else... The project is just a "normal" HD project with 20 Minutes and 20 Clips...
      Everything on google (about 8 sites) I have tried - no success until now... :-(
      so: any ideas???
      Thanks a lot!
      Michael
        • 1. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
          the_wine_snob Level 9
          Michael,
          I am not familiar with that particular error, but I would immediately look in the PrE AutoSave folder, and Copy those PREL files to another folder. If the PrE 8.0 Project is still intact, I would do the same with the AutoSave PREL files from it to.
          Then, I would explore Opening the AutoSave PREL's, to see how things behave. Note: AutoSave files are FIFO (First In - First Out), and are being constantly overwritten, as one edits over time. That is why I suggest doing the Copy action immediately. If the default has not been changed, there should be five PREL's, in each of those two folders (the PrE 10, and PrE 8 Projects' folder hierarchy). When looking at the files in Windows Explorer, set the View to Details, so that you can see the Date/Time of each file. The AutoSave PREL, marked 3, may well be more recent, than say 5.
          Good luck, and maybe others will have more input, specific to the exact error messages.
          Hunt
          • 2. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
            Hi Hunt,
            thanks for your answer - but all the AutoSave projects are incorrect, too... Have already done the step you suggested - but they are all incorrect... That's what makes me so crazy...
            Michael
            • 3. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
              OK, quick question: As PrE will continue doing AutoSaves, while you edit, so that with a long session, if something has gone wrong early, the older AutoSaves will have likely been overwritten - on the PREL files, do any date from back when things worked well? If so, and as you say, they are also showing problems, my question would be, what has changed with the system, from the time that things worked, until now? Have you added any new software, or hardware? Have you reconfigured anything that you can think of?
              As a test, create a new System Restore Point for now, and then reboot to Safe Mode, choosing to use another System Restore Point, from when things worked well. Reboot, and attempt to load one of the PREL's. Do you get the same errors?
              Good luck, and let us know how this test goes, please,
              Hunt
              • 4. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                well, this could in fact track the error and of course I have changed a lot but just since the error came up the first time...
                The give you the concrete example: the hole last week i converted two projects to AVCHD, MP4 in differenz bitrates... I wanted to find out the "perfect" bitrate for my purpose... Therefore I rendered the two projects alternatly.
                On saturday then suddenly the error came up - so nothing changed in hardware (notebook) or software as I am writing my master thesis in these days and I would never change a running system! :-)
                The hint with the system restore point is a really good idea but I have to confess: I never worked with this feature so the there's no system restore point in the extended list - even if I check the toolbox "show all"...
                I'm still hoping that the error can be fixed by adobe.... ?
                Michael
                • 5. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                  Blackbird-28 Level 1
                  i have exactly the same problem. since i used it the first time. i really hate this programm!
                  • 6. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                    Mohammad Tahseen Adobe Employee
                    Try following which is workaround for this problem, should resolve the issue:
                    For the issue that ends up in a corrupt project, please do the following:
                    1.     Download perl from http://www.activestate.com/activeperl...
                    2.     Open cmd prompt
                    3.     Run this command from there
                    perl -p -e "s/([-0-9]+?),([0-9]{12,24})/$1.$2/g" damaged.prel >working.prel
                    4.     Please specify the path for the prel files that cause the issue in place of the text “damaged.prel”
                    5.     Reopen the project and let me know how it goes.
                    Exact command with paths should go like
                    perl -p -e "s/([-0-9]+?),([0-9]{12,24})/$1.$2/g" C\Users\...\Desktop\AVCHD.prel >C\Users\...\Desktop\AVCHD_working.prel
                    Please let us know if this is resolved or not.
                    Tahseen
                    • 7. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                      Hi Tahseen,
                      thanks for your help but unfortunately the error is the same again... The Script is working as it's creating a new file named "XYZ_working.prel" - i just had to edit the path from d\project.prel to d:\project.prel
                      Any other ideas?
                      Michael
                      • 8. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                        Well, then share the project file with us. Sent you a mesaage about where to send the file.
                        Tahseen
                        • 9. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                          Hi Tahseen,
                          I have sent the projects via mail - hope you'll find a solution!
                          Michael
                          • 10. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                            cloud565 Level 1
                            Hello Mohammad,
                            I get the same error Message after replacing the "," with "." in the Keyframe sections. Unfortunately most of the backup files contain the same error. Only those still existing from Premiere Elements 9 (still installed) are correct. Can you please give a clue what's wrong with the new files. - I could send you my project file too, if it helps.
                            I am using a German version of Windows 7 - 64bit and Premiere Elements 10 - 64bits.
                            Greetings,
                            Jens.
                            • 11. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                              cloud565 Level 1
                              Hello SedAdMichael,
                              it seems Adobe Software has problems on system using non-dot decimal separators. To verify this, could I ask about the decimal separator your system is using (language setting). Is it a comma "," or a dot "."?
                              Greetings,
                              Jens.
                              • 12. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                Hi Jens,
                                thanks for trying to help us... But unfortunately this didn't resolve the problem - I changed the separator to "." instead of "," but the same error occured when trying to open the project....
                                I habe already sent my files to adobe - hopefully they are able to find a solution... I already got some messages that also other people are having this strange error...
                                Greetings,
                                MIchael
                                • 13. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                  cloud565 Level 1
                                  Hi Michael,
                                  it's correct that changing the dot separator will not make PRE 10 able to load the file correctly - I had no doubt in that, but having a system with "," supports my theory that this breaks the prel-files on saving. Using the dot separator in the system might not lead to corrupted files when saving the projects (that's my theory, I'd like to have confirmed).
                                  I'm not just trying to help, I like my file getting fixed too
                                  • As the Problem seems to lie in keyframe.h: Can someone please tell the correct format of all keyframe lines, so we could find out which lines are incorrect and fix those. - Until a patch is released.
                                  • I have two hours of video in my prel file and it's about 5 MB large and spent a week of working hours. The perl replacement was successfully but is still not working - my file now fails when loaded at 86 percent with exactly the same error message. How do I find out which line or element fails, so I can replace more dots by commas
                                  Greetings,
                                  Jens.
                                  P.S. I hope Adobe will give us a patch soon and a fix-tool or a description how to fix the old files. Many language settings are using "," as a decimal separator, so whole countries are affected.
                                  • 14. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                    cloud565 Level 1
                                    Hello,
                                    HANDLE WITH CARE - I found a solution for my file!
                                    My Theory seems to be working: It seems be the wrong interpretation of language settings.
                                    1st fix (see above, you did this already):
                                    • This fix replaced all numbers having "," as a separator and 12 or 24 digits after the separator. Numbers like "0,000000000000" or "0,000000000000000000000000" were replaced by the same values with "." instead of ",".
                                    • perl -p -e "s/([-0-9]+?),([0-9]{12,24})/$1.$2/g" damaged.prel >working.prel
                                    2nd fix (I found out this works for me):
                                    • The second error is in the <Keyframes> lines. When I replaced the ";" by "," or ":" (see below) the file could be opened successfully. But I don't know if this is causing other problems with keyframes.
                                    • HANDLE WITH CARE
                                      perl -p -e "s/([-0-9]+?)\.([0-9]{12,24});([0-9]{15})/$1.$2,$3/g" damaged.prel >working.prel
                                      HANDLE WITH CARE
                                    • A sample Line before replacement looks like this:
                                      <Keyframes>914457600000000,-0.027113247662782669000000:0.647517740726470950000000,0,0,0.00 0000000000000000000000,0.166666666666666660000000,0.000000000000000000000000,0.16666666666 6666660000000,0,0,0.000000000000000000000000,0.000000000000000000000000,0.0000000000000000 00000000,0.000000000000000000000000;914711616000000,-0.027113247662782669000000:0.64751774 0726470950000000,0,0,0.000000000000000000000000,0.166666666666666660000000,0.1157127932576 03460000000,0.166666666666666660000000,0,0,0.000000000000000000000000,0.000000000000000000 000000,0.000000000000000000000000,0.000000000000000000000000;915981696000000,0.49961149692 5354000000000:0.408149182796478270000000,0,0,0.115712793257603460000000,0.1666666666666666 60000000,0.000000000000000000000000,0.166666666666666660000000,0,0,0.000000000000000000000 000,0.000000000000000000000000,0.000000000000000000000000,0.000000000000000000000000;91623 5712000000,0.499611496925354000000000:0.408149182796478270000000,0,0,0.0000000000000000000 00000,0.166666666666666660000000,0.000000000000000000000000,0.166666666666666660000000,0,0 ,0.000000000000000000000000,0.000000000000000000000000,0.000000000000000000000000,0.000000 000000000000000000;</Keyframes>
                                    • Can Adobe please confirm these problems. I could send my broken file too if it helps.
                                    1 person found this helpful
                                    • 15. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                      RainerBl Level 1
                                      Hi everyone,
                                      after getting some hints from you about the possible cause of this error, I have been able to fix my project and I'd like to give you back my insights...
                                      First, I uploaded the project file in the Windows Editor. By comparing the file to an earlier backup version which worked fine, I found the following:
                                      At one point in time PE10 corrupts the .prel file by inserting "," in decimal numbers instead of the required "." for the <StartKeyframe> as well as for the <Keyframes> tags. The correct syntax of both these tags seems to be as follows:
                                      <StartKeyframe>-xxxx,yyyy,0,0,z.,z.,z.,z.</StartKeyframe>
                                      <Keyframes>-xxxx,yyyy,0,0,z.,z.,z.,z.</Keyframes>
                                      xxxx is a 17 digit (integer) number
                                      yyyy is either a (decimal) number z. or a range z.:z. or a boolean value (true or false)
                                      z. is a decimal number (number followed by a ".")
                                      In my corrupted .prel file, all numbers which were supposed to be "z." were actually "z," which caused the error.
                                      Only some of the occurrences of this error can be captured by the script described above, namely replacing the "," followed by 12 or 24 "0" with a ".". Unfortunately, there are a lot of other occurencences which have to be dealt with in order to correct the .prel file. One can get a number of algorithms for speeding up the process of replacing the erroneous "," with ".",
                                      e.g. search for ",000000" and replace it by ".000000"  (similar to the scipt above) but you also have to consider
                                      search for ",," and replace it by ".,"
                                      search for "0,5" and replace it by "0.5",
                                      search for ",<" and replace it by ".<  etc., you get the idea....
                                      This list is not complete, you still have to search manually for some odd numbers!! However, as you progress with replacing the erroneous "," you will see the perceantage of the .prel file loading successfully increase and at the end of the day (more an hour really) the file will load completely. I have not tried to fully automate the process. Hope this was a one time effort!
                                      The above procedure is a pain in the neck, but if your son has spent an entire weekend on a project it is worth the effort! Hope this will work for you as well. Adobe should be able to fix this easily. Good luck!
                                      Best regards, Rainer
                                      • 16. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                        Hi Rainer,
                                        that's it - everything is working... What have I done?
                                        I used both (!!) scripts from cloud565 with the following command lines via cmd:
                                        C:\Perl64\bin>perl -p -e "s/([-0-9]+?),([0-9]{12,24})/$1.$2/g" D:\We.prel >D:\We1.prel
                                        C:\Perl64\bin>perl -p -e "s/([-0-9]+?)\.([0-9]{12,24});([0-9]{15})/$1.$2,$3/g" D:\We1.prel >D:\We2.prel
                                        Note: C:\Perl64 is the install path of pearl, We.prel is the damaged existing initial project. We1 and We2 are going to be created by the script.
                                        Then I opend We2.prel in notepad++ and followed the instructions of Rainer, but just 2 of them:
                                        search for ,< and replace by .<
                                        search for 0,5 and replaxe by 0.5
                                        And that was all I had to to - after this PE10 was able to open the projects, I didn't have to replace other lines / expressions like Rainer.
                                        So glad that the projects are working again, thanks all of you for helping us and leading us to the solution!
                                        Cheers!
                                        Michael
                                        • 17. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                          Kinou31 Level 1
                                          Hi everyone,
                                          I have the same problem after many hours on this project.
                                          My project weighs 3 499 038 octets.
                                          without explanation, suddenly, my project has been altered and also all versions of the same project automatically saved in Adobe Premiere Elements 10.
                                          This is the first project that I create with Adobe Premiere Elements 10 on my new pc.
                                          I use a Intel Core I7 with Windows 7 Pro FR 64bits, 120Go SSD Harddisk and 16Go DDRAM.
                                          I have applied all solutions proposed above without success.
                                          I would like to have your opinion on two points.
                                          1 - do you think it is possible to find a solution to my problem?
                                          2 - how to be on not to meet again this problem on other projects?
                                          Best regards,
                                          Kinou
                                          Balma, France.
                                          • 18. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                            Steve Grisetti Adobe Community Professional
                                            If your problem is exactly the same, you should start by using exactly the same solution that worked for the original poster.
                                            • 19. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                              Kinou31 Level 1
                                              Thanks Steve,
                                              but that's exactly what I did.
                                              I applied SetAdMichael solution first
                                              and after RainerBl solution
                                              and after cloud565 solution
                                              and even several times each. I thank them for their work.
                                              I will completely recreate my project, if I have the same problem again I will choose, with regrets, another video editing software. Indeed Adobe seems unable to explain and fix this bug. Adobe Premieres Element 10 is not sufficiently reliable to be used resulted seriously.
                                              It is unacceptable to lose the result of a several days, including backups.
                                              I feel like I have been deceived by purchasing this version which ultimately cost me a lot of time and money spent unnecessarily.
                                              Best regards,
                                              Kinou
                                              Balma, France.
                                              • 20. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                RainerBl Level 1
                                                Hi Kinou,
                                                I know how you feel, it's really frustrating. Just one hint, though... In my solution, I did not list all erronous occurrences of "," ! I listed some of the common patterns, but there are other lines where you really have to do a search/replace on an individual basis. So, if you really want to recover your project, it is my experience that you have to go through the entire file looking for the tags and the syntax that I described above. One missed "," where a "." should be will corrupt the project! I could see my progress in the increase of the percentage the project loaded before I got the error message. Hope this helps...
                                                Good luck, Rainer
                                                • 21. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                  sgm_maffe Level 1
                                                  Adobe i have also this problem. I spend lots of hours to a project. All went fine till now with those error:
                                                  I don't have a D: drive ??
                                                  My project was ready in the first place. I saved it. The only thing i did was: Share it with YouTube. I choose the setting "High definition 1920 ...." rendering starts en uploaded it to Youtube.
                                                  I was very angry because the output on youtube was very bad. The 720p and 1080p where not as good as on my timeline. It was very late so i closed Adobe Premiere, and the pc asked me to save the file?
                                                  I thought: save the file? i did nothing change? ... but i did choose yes... stupid... maybe i must choose No.
                                                  Just now i would like to render again but i get the Keyframe problem..
                                                  Why Adobe why? Please can you fix this problem with a simple workarround? I have a deadline.
                                                  Have no time to do the scripting with Perl. Do you have a faster way.?
                                                  • 22. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                    sgm_maffe Level 1
                                                    I spend some time, same as you. Did al those 3 things. script1, script2 and replace ,,  0,5  and the ,< thing. But again same error.
                                                    And there is post above with text "This list is not complete"
                                                    What need to be done more?
                                                    I find this very annoying!
                                                    All Automatically created recovery/saved files have different date and timestamps and i thougth to use one of the latest. But that also does not work? Same Keyframe.h-142 error.
                                                    When will the fix come Adobe?
                                                    • 23. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                      Remember, this is a user-to-user forum.
                                                      If you'd like to contact Adobe, click the Contact Adobe button at the bottom of any page on this web site.
                                                      They are open to bug reports and feature requests.
                                                      • 24. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                        Sanctus799 Level 1
                                                        Made a console application (Windows) that solved this problem for me (based on the above regex but with some modifications). Make sure to backup your data before trying this! You need .NET4.
                                                        http://www.slottet.org/downloads/Premier10ProjRepair.zip
                                                        Usage:
                                                        Premier10ProjRepair.exe <input.prel> <output.prel>
                                                        Thanks to SetAdMichael for the help with this. Hope this will be resolved properly soon! My experiences with Premier was so good until this fatal error occured .
                                                        • 25. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                          sgm_maffe Level 1
                                                          After running your exe, i have the same h-142 problem.
                                                          But i did find out something else.
                                                          The last working backup from my prel file is from 5-1-2012. This file is 3.223 kb
                                                          I then worked some hours and the corrupt prel file is from 8-1-2012. But this file is smaller: 2.462 kb ?
                                                          When you work at a projects, for as far as i know, the prel file will each time growing ... or not?
                                                          Can i send my files to someone who can look at whats going wrong with my last working good en defective prel file?
                                                          Would be very pleased....
                                                          • 26. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                            With a PREL, the file size will depend on what one is doing. If a Project is Trimmed, Assets are Deleted, etc., the size of the file may well shrink. It is, after all, just an XML database, and contains links to Assets, plus instructions, that will be used, when one Exports/Shares to an AV file.
                                                            Good luck,
                                                            Hunt
                                                            • 27. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
                                                              Viba IT
                                                              Could all of you that still have this problem go to http://feedback.photoshop.com/photoshop_family/topics/pre10_project_open_fail and click the "+1" (Add my vote) to make sure Adobe gets the extent of this problem.
                                                              • 28. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        sgm_maffe Level 1
        Yes yes,my prel is working again, thanks to tip in that post:
        upload your defect prel file and get a working back!
        http://www.vibait.com/software/premiere-fix-keyframe.h-142/
        Nice job!
        Only "one little thing", you need to check all the video- and audio fade-in and fade-outs!
        • 29. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        ERognlid Level 1
        I have the same problem. I have tryed all the solutions and are currently browsing trough my prel file for dot or comma errors that this solutions dont catch. But how do I know if this key frame is correct
        <Keyframes>914305190400000,264,93505859375,0,0,0.,0.16666666666666666,-39.557989075251342, 0.16666666666666666,915205848338028,124.675323486328,0,0,-39.557989075251342,0.16666666666 666666,0.,0.16666666666666666;</Keyframes>
        or it shoud be 264.93505859375
        I also have another recurrent keyframe
        <StartKeyframe>-91445760000000000,0.500000000000000000000000:0.500000000000000000000000,0, 0,0.000000000000000000000000,0.000000000000000000000000,0.000000000000000000000000,0.00000 0000000000000000000,5,4,0.000000000000000000000000,0.000000000000000000000000,0.0000000000 00000000000000,0.000000000000000000000000</StartKeyframe>
        How can I know that 5,4 is correct, not 5.4?
        Is there a way of knowing where in the file Premier Elements find the error?
        • 30. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        ERognlid Level 1
        Puh, solved my problem.
        I found a relativly easy way of figuring out the odd numbers Rainer talked about in his post. My solution:
        I run the perl script from Michaels post.
        Then did the ,< and ,, replace from Rainers post.
        Ending up with finding the odd numbers
        1) I made a copy of the perl file and change the filtype to .txt
        2) Opend this file in Excel
        3) Used filter sorting for <keyframe
        4) kopied that into a new workbook witch I saved as a txt fil
        5) I opend this file in notepad uses and replaces all the , with |
        (This step should not be necesary, but excel did not sort out the colums in my next step if I did not replace hte , )
        6) opend the new txt file and selected colums separated with |
        7) then I looked trough the file for abnormalities. It was relativly easy spotting the errors.
        8) When spotting an error, I searche for the number in my original PREL fil, witch I had opend in notepad and fixed the error
        I then repeated the proces from step 3 sorting for <startkeyfram
        I saved my project, but it is stupide that this error occure and Adobe has not mad a fix for it. If my memory is not wrong the exact same problem occured in an earlyer version of Premier 5-6 years ago.
        • 31. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        PelleV Level 1
        All,
        first of it is unbelievable that this still is an issue in Premiere Elements 10, when the issue is known for at least half a year. That just ruined my morning. Thanks everyone for the fixes here, that saved me 3 hours of redoing everything from the last working auto-save.
        Thanks to VibaIT for hosting a website with the script, so everything was working again in 3 minutes.
        Cheers
        Pelle
        • 32. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        ichbinneuhier Level 1
        hello... i found a really really easy solution for your/my problem on the internet!
        just upload your corrupt file and the fixed file will be automatically downloaded to your PC! it helped me a lot and my project works fine again!!!
        best regards and hope it will help you (although it's been a while since you posted it here)
        • 33. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        Larryc004 Level 1
        I don't have more solutions, but an observation on specific actions that may have caused this.  I have created more than 10 DVD's with no problems.  Then I used the "Fun in the Sun" disc menu on two projects an both were corrupted.  Another video created between theswe two was fine and used a different menu.  I always create a file version on my network storage to view for errors prior to burning DVD's.  The menus did not work correctly on these disk based versions, although the moves did play.  I just could not navigate the menu correctly (no highlights appeared).  The only other difference I can think of is the use of fade in at the beginning and fade out at the end.  I believe I have used this before, but perhaps not.  Although I can't be 100% certain, I hope this gives Adobe a clue as to where to look and may help some of you.
        • 34. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        martin_jernberg_tibble Level 1
        Thank you this fix, fixed our problems here at Tibble Gymnasium
        thank you so much <3
        • 35. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        A.T. Romano Level 7
        martin
        What version of Premiere Elements are you using and on what computer operating system is it running?
        Just curious....Rainer (post 15) is marked as the correct answer, but you seem to have found your correct answer in the post of Sanctus (post 24). Did you try both or just the one? If both, did Rainer's suggestion work for you also?
        Thanks.
        ATR
        • 38. Re: Elements 10 Error: d:\pre\mediacore\mediafoundation\api\inc\Keyframe/Keyframe.h-142
        A.T. Romano Level 7
        bonberris
        Please continue the discussion in the other thread to which you have attached yourself.
        Re: Problems with Premiere Elements 12
        Or better yet, if our discussions continue on your Premiere Elements issues, it might be a good idea to start your own new thread so that we
        can find each other. I nearly missed your display error screenshots in this thread that we are in now.
        Thanks.
        ATR
