38 Replies Latest reply on Jul 31, 2017 3:46 AM by TheBlackBinLiner88
    Introducing: Insert Page Numbers
    CarlosCanto Adobe Community Professional & MVP
      Hi all, about three weeks ago a user asked about something like this, I thought it was a good idea to have it scripted.
      Have a use for it? Let me know if there are questions, bugs...
      #target illustrator
      // script.name = UI_insertPageNumbers.jsx; // works with CS4 & CS5
      // script description = Inserts page numbers (or any other text) to all artboards in the active document;
      // script.required = at least one open document
      // script.parent = CarlosCanto // 11/14/11;
      // script.elegant = false;
      // Notes: The script creates a new layer (Page Numbers) then adds a text frame per Artboard that act as footer or header text.
      //                     Its primary function is to insert Page Numbers, but it could be used to insert any other kind of information.
      if (app.documents.length > 0) // continue if there's at leat one document open
                          // start building User Interface
                          var win = new Window("dialog","MTools - Insert Page Numbers");
                          var panelMargins = win.add("panel", undefined, "Margins");
                          var lblMargins = panelMargins.add("statictext",undefined,"How far from the edge:");
                          var txtMargins = panelMargins.add("edittext",undefined, 0.25);
                          var lblUnits = panelMargins.add("statictext",undefined,"inches");
                          var panelLocation = win.add("panel", undefined, "Location");
                          var radTop = panelLocation.add("radiobutton",undefined,"Top");
                          var radBottom = panelLocation.add("radiobutton",undefined, "Bottom");
                          var panelAlignment = win.add("panel", undefined, "Alignment");
                          var radLeft = panelAlignment.add("radiobutton",undefined,"Left");
                          var radCenter = panelAlignment.add("radiobutton",undefined, "Center");
                          var radRight = panelAlignment.add("radiobutton",undefined, "Right");
                          var panelFooter = win.add("panel", undefined, "Text to insert");
                          var grpPages = panelFooter.add("group");
                          var btnPage = grpPages.add("button",undefined,"Insert Page");
                          var btnPages = grpPages.add("button",undefined,"Insert Pages");
                          var txtFooter = panelFooter.add("edittext",undefined, "[Type text to insert here]");
                          var btnOk = win.add("button", undefined, "Ok");
                          radRight.value = radBottom.value = true;
                          win.alignChildren = panelFooter.alignChildren = "fill";
                          panelMargins.spacing = 3;
                          panelMargins.orientation = panelLocation.orientation = panelAlignment.orientation = "row";
                          win.helpTip = "Coded by CarlosCanto";
                          btnPage.helpTip = "Adds *page* keyword, it represents a single page";
                          btnPages.helpTip = "Adds *pages* keyword, it represents total number of pages";
                          txtFooter.helpTip = "Type \r\t'Page *page* of *pages*' \rto get \r\t'Page 1 of 3' \rfor example";
        btnOk.onClick = function(){
        doSomething(); // call main function
        win.close(); // close when done
        btnPage.onClick = function(){
        footer("*page*");
        btnPages.onClick = function(){
        footer("*pages*");
        win.center();
        win.show();
                          function footer (page) //
                                              txtFooter.text = txtFooter.text + page;
                          function doSomething()
                                              //alert("I'm doing something");
                                              var idoc = app.activeDocument;
                                              var ilayer = idoc.layers.add();
                                              ilayer.name = "Page Numbers";
                                              var pages = idoc.artboards.length; // number of artboards
                                              var footerPages = (txtFooter.text).replace("*pages*",pages); // replace the "*pages*" keyword with the actual number fo pages (artboards)
                                              var margins = Number(txtMargins.text)*72; // get margins in points
                                              //$.writeln(margins);
                                              for (i = 0; i<idoc.artboards.length; i++) // loop thru all artboards, and add input text from UI
        footerPage = footerPages.replace("*page*",i+1); // replace "*page*" keyword with the actual page Number
        var itext = ilayer.textFrames.add();
        itext.contents = footerPage; //"page 1 of 1";
        var fontSize = itext.textRange.characterAttributes.size;
        var activeAB = idoc.artboards[i];
        var iartBounds = activeAB.artboardRect;
        var ableft = iartBounds[0]+margins;
        var abtop = iartBounds[1]-margins;
        var abright = iartBounds[2]-margins;
        var abbottom = iartBounds[3]+margins+fontSize;
        var abcenter = ableft+(abright-ableft)/2;
        if (radRight.value == true)
        //var msg = "right";
        itext.left = abright;
        itext.textRange.paragraphAttributes.justification = Justification.RIGHT;
        else if (radCenter.value == true)
        //var msg = "center";
        itext.left = abcenter;
        itext.textRange.paragraphAttributes.justification = Justification.CENTER;
        else
        //var msg = "Left";
        itext.left = ableft;
        itext.textRange.paragraphAttributes.justification = Justification.LEFT;
        if (radTop.value == true)
        var msg = "top";
        itext.top = abtop;
        else
        var msg = "bottom";
        itext.top = abbottom;
                                                        } // end for loop thru all artboards
                                    } // end function doSomething();
       else
              alert ("there's no open documents");
