I have tried since i dled the new firefox to unistall and use other suggestions here to fix this issue. Nothin unistalled all the way redid jack squat. All i care about is a fix for it to work.
64 bit windows 7
with 4gb ram
ANY freaking good idea on how to fix this perfecto sides a link to the unistall reinstall thing. The main page that does that sucks donkey!
Sorry, it is not clear what your problem is.
Installers and uninstallers are here http://forums.adobe.com/thread/909550 - make sure Firefox is closed when running the uninstaller / installer.
My problem is with the last verison of firefox. Adobe wouldnt work so i tried updating and didnt work. Unistalled and reinstalled (total pain in the tail didnt work). Got here did some of the links i found installed but wont show up as working with firefox. The plugin never comes up i think. I need a freakin soultion to this.
What "last version" of Firefox?
Did you run the 32-bit or 64-bit installer?
Do you see Shockwave Flash under about:plugins
and is it enabled?
The brand new updated 8.0 and i did the one that is on the first dl page that includes both. *it didnt work* . Then i tried to do the seperate one of 64 bit it didnt work. 32 didnt either and at first Shcokwave did show it was up but wouldnt work then i ran the unistaller and it quit showing up. Tried running them again and jack squat .
Flash Player 11 works fine on my 64-bit system with Firefox 8.0
After you run the uninstaller, what files do you have left in
The unistaller its self is there and two files that go with it. I deleted them and now still nothing any ideas on how to get thsi fixed? I am going crazy not playin some of my games cause of it.
Try running only then 64-bit installer, then post the contents of the FlashInstall.log files here.
For C:\Windows\SysWOW64\Macromed\Flash
=O====== M/11.1.102.55 2011-11-14+21-53-00.604 ========
0000 00000010 "C:\Users\EMACHI~1\AppData\Local\Temp\2711.dir\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32.dll
0014 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11e_Plugin.exe
0015 00000017 C:\Windows\SysWOW64\Macromed\Flash
0016
=X====== M/11.1.102.55 2011-11-14+21-53-01.415 ========
=O====== M/11.1.102.55 2011-11-15+02-52-12.345 ========
0000 00000010 "C:\Users\EMACHI~1\AppData\Local\Temp\3F76.dir\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0018
0019
0020
0021
0022
0023
0024
=X====== M/11.1.102.55 2011-11-15+02-52-12.455 ========
=O====== M/11.1.102.55 2011-11-15+02-52-43.545 ========
0000 00000010 "C:\Users\EMACHI~1\AppData\Local\Temp\B7C1.dir\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011
0012
0016
=X====== M/11.1.102.55 2011-11-15+02-52-44.450 ========
=O====== M/11.1.102.55 2011-11-14+21-52-55.830 ========
0000 00000010 "C:\Users\eMachines\Desktop\install_flash_player_11_plugin_64bit.exe"
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002
0003
0004
0005
0006 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_1_102.dll
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_Plugin.exe
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00000011 1
=X====== M/11.1.102.55 2011-11-14+21-53-02.367 ========
=O====== M/11.1.102.55 2011-11-15+02-52-09.771 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_Plugin.exe" -maintain plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000011 1
0013 00000012
=X====== M/11.1.102.55 2011-11-15+02-52-12.642 ========
=O====== M/11.1.102.55 2011-11-15+02-52-38.803 ========
0001
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_1_102.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_Plugin.exe
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00000011 1
=X====== M/11.1.102.55 2011-11-15+02-52-45.605 ========
There seems to be a problem writing flashplayer.xpt to C:\Windows\SysWOW64\Macromed\Flash - did you delete that file from the folder after uninstalling?
Usually I see this error (5) if a file cannot be deleted from a folder.
I think so on the first run after finding it. But how can i fix that?
I don't know why it cannot write to that folder. You are running the installer as an Administrator user?
Yeap and its not doing jack. Really sucks being honest
Next try to delete both install folders; the installer should recreate them with proper permissions.
