1. Re: Issue with importing effects settings from 3.0 to CS5.5
SuiteSpot Oct 30, 2011 7:47 AM (in response to Eric S 1)Are these fx or racks native internal fx or external vsts?
Can you give some example of the fxs you mean?
2. Re: Issue with importing effects settings from 3.0 to CS5.5
Eric S 1 Oct 30, 2011 6:10 PM (in response to SuiteSpot)Hi Michael,
These effects are mostly external VSTs, but a few of them are native
(Parametric EQ). The program will just not import the settings .xml
file or the vstmanager settings .xml. The VSTs seemed to have been
found easily by the program. I have not yet gone through them all to
see if they will pop up.
Another interesting thing - when I installed AACS5.5 I lost the ability
to open AA 3.0.1. I had to reinstall 3.0.1 in order to be able to use it.
I'm not liking this program at all. I don't like the interface, the
GUI, or the navigation through the program.
3. Re: Issue with importing effects settings from 3.0 to CS5.5
Eric S 1 Nov 14, 2011 7:51 PM (in response to Eric S 1)So nothing? No one else has experienced the issue of importing failure?
4. Re: Issue with importing effects settings from 3.0 to CS5.5
SuiteSpot Nov 16, 2011 12:24 AM (in response to Eric S 1)Sorry Eric - I have moved to Win7 x64 and IE9 and can no longer access this forum unless I use my XP test PC.
If you want to send one or two of your ses files I will see what I can do regarding converting the settings of the external VSTs.
What would also be helpful is an sesx file which has these vsts in it and maybe a screen dump of each vsts setting in the fx rack.
Contact me via the aatranslator web site if you want to pursue this with me
M
